Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jun 19, 2020 at 4:29 PM
    #5521
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
  2. Jun 20, 2020 at 11:35 AM
    #5522
    Micatom33
    Santa Cruz,CA
    2008 BSP DCSB
    It has begun...
    Taco-Obsessed and EatSleepTacos like this.
  3. Jun 20, 2020 at 11:36 AM
    #5523
    Micatom33
    Santa Cruz,CA
    2008 BSP DCSB
  4. Jun 20, 2020 at 11:36 AM
    #5524
    Micatom33
    Santa Cruz,CA
    2008 BSP DCSB
  5. Jun 20, 2020 at 11:38 AM
    #5525
    Micatom33
    Santa Cruz,CA
    2008 BSP DCSB
    Had to cut this mount off and adjust it a bit.
    tyfoon11 and Taco-Obsessed like this.
  6. Jun 20, 2020 at 11:39 AM
    #5526
    Micatom33
    Santa Cruz,CA
    2008 BSP DCSB
  7. Jun 20, 2020 at 11:44 AM
    #5527
    Micatom33
    Santa Cruz,CA
    2008 BSP DCSB
    At this point all is installed.
    These things need moar space.. I already have the rubbing right by the rim edge and now contact with the bypasstube at full lock not sure how much more room there is in there even if I do relocte the uppershock mount tabs.
    So the next question is how to avoid knocking the bottom of the dual bypass off like @nudavinci64
    I really dont want to run a 2 inch spacer.
    For now I have ordered 2inch spacers to replace the 1.5s and am hoping that will take care of it for now:fingerscrossed:
    Looks like some BR6 17s with 3.5bs?
    Tacoma_build2020 likes this.
  8. Jun 22, 2020 at 12:17 PM
    #5528
    EchoLake
    EchoLake Well-Known Member
    Sacramento
    '15 MGM TRD OR AC 6MT
    Magnuson Supercharger, Speedhut AFR and Boost Gauges, TRD ECU Reflash, Factory Nav Unit, TRD Skidplate, VIP alarm, 265/75R16 Cooper Discoverer ATP, 1" KSP Spacers, hub centric (hold comments lol), TRD Pro Grill, Raptor Lights on with ignition. Upcoming - purchased, not yet installed: Body matched rear bumper (rattle can), Kicker Hideaway, JL Audio 6x9 components w/80Hz Bass Blockers, Hellwig anti-roll bar, TRD Short Shifter, Knock-off TRD Shifter (non-Qball), black throwback plates. Plans: more.
    Been reading this thread for a little while, 'bout to ask some really stupid questions, trolling expected, but Google is not cooperating today.
    What exactly increases (down)travel on IFS?
    For instance, if one were to install say a basic Old Man Emu kit with longer springs and shocks, I am assuming downtravel would decrease.
    What specific component(s) limit downtravel, and how does replacing them allow for longer droop?
  9. Jun 22, 2020 at 12:34 PM
    #5529
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Well with the shocks installed they are your limiting factor...which is why you use limit straps to protect your shocks from being the limiting factor.
    Take the shocks off and you limiting factor will be some kind of mechanical stop....depending on the geometry of the LCA to the UCA and the spindle it could be the ball joints...or uniballs depending on your current suspension set up because at some point the balljoint/uniball runs out of movement...it could be the bolt or misalignment spacer coming into contact with the uniball cup the ball joint maxing out its travel....the UCA may contact the top of the spindle...it goes on and on from there.
    The one component that limits down travel can vary...any one of the components in your suspension...all depends on the geometry of how they all work together but at some point some movable part will reach its max travel and that will be your limiting factor.
    whatstcp and EchoLake[QUOTED] like this.
  10. Jun 22, 2020 at 1:04 PM
    #5530
    EchoLake
    Sacramento
    Thank you for the info.
    So it sounds like on a mild lift, say 2", I would likely not run into any of the above you listed as limiting downtravel factors?
  11. Jun 22, 2020 at 1:18 PM
    #5531
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Your OEM LCA bushings are the main thing limiting droop on the stock set up. Loosen the alignment bolts with the truck in the air and you'll see the spindle droop another half inch or so.
    Next is the UCA hitting the springs on your coil over.
    Around the same time the UCA hits the spring your ball joint starts the bind and run out of articulation. And your OEM shocks will run out of extension.
    Next the inner CV will reach its maximum allowable angle. You can push it further, but when loaded and spinning it will bind, then fail.
    The design of this front end is highly frustrating from a performance perspective, but Toyota did a good job designing something that makes it hard for a single failure to set of a cascade of failures. i.e. both the shock and the UCA/Spring interference protect the CV.
    Now, to make mid travel IFS suck less:
    1) Replace the LCA with an after market one, this gives you more articulation and more room for the spring.
    2) Replace the shock with a King Extended Travel version (Or Fox or Icon).
    2)a) OME shocks are okay, but you won't see any increase in wheel travel)
    3) Replace the LCA bushing with a white-line bushing or go all in and buy new LCAs.
    4) Limit straps so you don't blow up your CVs with the extra 3/4" of travel you just payed 4 grand to acquire.
    If you actually want more travel it's probably less heartache in the long run to just buy a Dirt King long travel kit and bolt it on.
  12. Jun 22, 2020 at 1:19 PM
    #5532
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Nah, you would only run into those if your shock was removed. With shock installed you will only droop what you have left in the shock shaft (most OEM replacement coilovers run 5.5”-6.5” travel), but keep in mind, shock travel is just at the shock. Your wheels travel a bit more because of the double wishbone design of IFS. A 2” lift is a good spot to be in with stock geometry, it still allows for good up travel compression while leaving you some droop to play with.
  13. Jun 22, 2020 at 1:36 PM
    #5533
    EchoLake
    Sacramento
    Perfect, thank you for consolidating all of that for me. Now I'm starting understand how everything works together.
  14. Jun 22, 2020 at 1:38 PM
    #5534
    Arcticelf
    Gladiator
    No problem.
    If you go back to the first page of this thread there's a bunch of build threads linked, tons of good knowledge there.
    EchoLake[QUOTED] likes this.
  15. Jun 22, 2020 at 1:43 PM
    #5535
    EchoLake
    Sacramento
    Perfect, thank you for the info.
    I was just interested in this because I had a '98 Ranger and turned the torsion bars to get a little over an inch IIRC. I also installed some RS5000s on it at the same time and remember downtravel was significantly limited. Mayne that was because the shocks were designed for stock travel.
    I'm deciding whether or not to just go with a simple OME or something full blown like discussed on this thread. If the OME is going to limit downtravel like on my Ranger then I'll have to look into something more complex.
    I work for the CA DOJ, so just took a 10% pay cut, so I have to consider cheaper options now I guess.
  16. Jun 22, 2020 at 1:45 PM
    #5536
    EchoLake
    Sacramento
    Yeah I was there, almost made my head explode.
    Glad you guys could dumb it down for me.
  17. Jun 28, 2020 at 5:02 PM
    #5537
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    going with 10" 5165s on rear of my 1st gen. no extra weight on the rear. anybody have recommendations on valving best suited for washboard. running the 255 valved 5125s now which have leaked out. was thinking about going down to the 170 valved shocks
    Tacotruck7 likes this.
  18. Jun 30, 2020 at 9:41 AM
    #5538
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    2025 SR5 4x4
    Hey guys, been lurking for a while. A lot of you are running some substantial setups. I've been learning a lot by browsing the pages here. That being said, I'm looking for some advice.
    I have a 1gen Prerunner double cab. I use it as a DD and to go camping. So it gets loaded with gear and stuff from time to time. Most of the "remote" camping I do isn't as close to as remote as a lot of guys on here due to not having 4x4. I mostly go to Joshua Tree, Pismo, Mex (not right now), Big Sur, State Parks, Utah, that sort of stuff. I'm not interested in crawling, but I do like having comfort on dirt roads the street and like the idea of playing around out in the desert more than crawling in the mountains. Not like I can do it anyway with my truck.
    Right now: I'm running an OME set up with 881's, Dakars, and stock uppers.
    My plan: Camburg Uni Uppers, Fox Fabtech 2.0's freshly rebuilt from a TW member (cheap $200), and some non-resi fox 2.0's in the rear. I know the 2.0's don't have the extended travel, so I'm not sure if I should get a different shock in the back. I plan to keep my stock LCA's and replace the bushings with the Whiteline ones everyone recommends. I also plan to replace my Outer Tie rods and steering rack bushings. I did my LBJ's a week ago. I'd like not to have to replace the inners if I dont have to due to budget constraints. I'm at 210k currently. I know this set up isn't very "mid-travel," but I thought it would be good to ask here and hopefully get pointed in the right direction. I'm on a tighter budget than most on here and just want something that will ride nice and offer me to have some fun without killing my wallet. Which, I know is sort of an oxymoron. Thanks, everyone!
  19. Jul 28, 2020 at 4:56 PM
    #5539
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Anyone know of any companies making bedside support brackets for high clearance bumpers? I know Pelfreybilt used to make them and that what I have on my stock fenders, but looking to get another set for my neighbors truck since we did a high clearance on that.
    Thanks
  20. Jul 28, 2020 at 4:58 PM
    #5540
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Mobtown does, or at least did. You could reach out to them.
