Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jul 13, 2021 at 7:10 AM
    #5901
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Idk what they’re asking but a JD or TC race +2 would be my go to or stock length TC or DK. Found out the hard way that even good companies don’t have their new products fully dialed right when they’re released.
    Supra4x4[QUOTED] likes this.
  2. Jul 13, 2021 at 7:30 AM
    #5902
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Slightly confused at your label of this new kit being "mid travel." I guess there is really no clear definition between the two as far as numbers go, but are you basing this off the use of a stock length replacement shock? Is the shock travel how you identify each kit?
    In that case, I would argue that they likely designed the kit with a different motion ratio and the shock is likely mounted inboard on the lower arm so they can net greater travel numbers without having to replace the shock with an 8". My concern would be the additional leverage applied to the shock would make valving for this kit vastly different from any other which is why they probably opted for a 2.5" bump on a slapper arm.
    Either way, it's an interesting idea and exciting to see something new come to the market. Not for everyone but I definitely see this being for the "overland" market more than any other.
    Airdog and snowsk8air2 like this.
  3. Jul 13, 2021 at 10:04 AM
    #5903
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    07taco likes this.
  4. Jul 13, 2021 at 10:08 AM
    #5904
    desertjunkie760
    Shane
    Check My Sig.
    Using a slapper arm allows the bump to contact the lower arm further out, therefore engaging much later in the travel. It's a solid concept and addresses why I personally don't like running bumps on these trucks up front but a 2.5" seems excessive for a Tacoma. I could be totally wrong though. I've not messed with the kit yet.
    not_nick likes this.
  5. Jul 13, 2021 at 10:08 AM
    #5905
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahhh, that makes sense. Pretty neat. I look forward to seeing travel numbers on this setup.
  6. Jul 13, 2021 at 10:26 AM
    #5906
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    knowing the cost of my dual shock "mid travel" now.. I probably should have done TC +2 or 3.5, but I also dont have wide trails to run at high speed. Im happy with my purchases, even though the LCA was the craziest
    cdex8357 likes this.
  7. Jul 13, 2021 at 10:52 AM
    #5907
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Yup. You summed up what I was saying. They even said in the video “still mid travel.”
  8. Jul 13, 2021 at 12:37 PM
    #5908
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    That "slapper arm", for the lower bump stop pivot mount, is there to prevent scraping across the strike pad (like most tradition set ups). With the lower bump mount following an arc AND having the upper and lower bump stop mounts on pivoting joints , allows the bump stop to move with the lower control arm exactly like a shock (having a motion ration with it too). No need to have a strike pad that gets worn out . It's not just for leverage because you can just mount the traditional "can" out further.
    Also a 2.5" bump is not overkill for a truck weighing over 4,000lbs. For bumps mounted 1/2 up the lower arm , like most A arm LT "kits", there is a lot of leverage on them . They are acting more like a secondary shock in this type of application, so having all that extra oil and larger piston helps a lot.
    If you really wanted to use a hydro bump at it's full potential or for "what it's intended for", then you would mount it up high off the engine cage and striking the upper arm at the uniball pivot (or very near the tire). less leverage . like this:
  9. Jul 13, 2021 at 4:07 PM
    #5909
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Wondered when the new Camburg kit would surface here. Knowing the wait time for shocks is crazy right now you could probably sell these if the stock (King/Fox) coilover valving works well with it and the pricing is reasonable. However their Raptor kit without slaps is $4995.00 and I don't see the Tacoma kit being significantly cheaper to produce. At 5k for arms, axle shafts and tie rods I would be ditching my oem fitment Kings and buying a jd kit with upgraded cv's for the same rough price though. Broverlanders may buy it but I think the cost is going to push people away from it and into other options.
    Dayman Karate and Dalandser like this.
  10. Jul 13, 2021 at 4:11 PM
    #5910
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Had they made a TC +2 / 3.5 Race equivalent and sold it for roughly the same price I think they would have had a bigger market.
  11. Jul 13, 2021 at 4:26 PM
    #5911
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    This low rider wheels harder than most in here
  12. Jul 13, 2021 at 4:34 PM
    #5912
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you could use air shocks to raise and lower single wheels that would change things a lot.
  13. Jul 13, 2021 at 4:40 PM
    #5913
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Dalandser[QUOTED] likes this.
  14. Jul 13, 2021 at 4:42 PM
    #5914
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Hard with air shocks but doable with air cylinders. You can pressurize either side of the piston and pickup a wheel, they rode terrible though.
  15. Jul 13, 2021 at 4:43 PM
    #5915
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    EatSleepTacos[QUOTED] likes this.
  16. Jul 14, 2021 at 4:49 AM
    #5916
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    i follow this dude on insta "ramsayy" and they do hardcore snow wheeling. they use hydraulic shocks and 4 wheel steer. amazing setups.
  17. Aug 12, 2021 at 3:43 PM
    #5917
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    So I'm switching to spring under axle with archive hammer hangers and deavers but as I'm cycling the suspension it feels like its binding slightly that last couple inches of droop travel where the shackles are about flat. Is this normal? Am I letting it droop too far? I had 3.6 shackles but it was worse like that so I extended them as much as could fit (4.25 ish) and its still doing it a little :/
  18. Aug 12, 2021 at 3:45 PM
    #5918
    Abject4x4
    Abject4x4 Just another idiot on the internet
    Marcus
    White SR5 Access Cab
    Doesn't @ARCHIVE have a shackle specifically for SUA?
  19. Aug 12, 2021 at 3:49 PM
    #5919
    not_nick
    Yea I didn't order it with that one cause I didn't think I'd go sua but I changed my mind. Maybe they're different besides the length? They should be fine since I made em longer
  20. Aug 12, 2021 at 5:21 PM
    #5920
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Why wouldn't you just call me up and ask for assistance in figuring it out?
