Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jan 19, 2016 at 7:35 PM
    #581
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
  2. Jan 19, 2016 at 7:56 PM
    #582
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    So just thinking out loud here, but i know @jberry813 has suggested using a string eye to eye on the leaf pack to determine the main leaf length. Then using this string on the forward mount and shackle to determine where the string goes flat (aka bump).
    Is there any reason, the string cant also be used to determine droop? Just keep it on the forward mount and rotate the shackle till its at maximum droop but not to the point it could invert(aka the maximum possible if the shackle would rotate all the way)? Breaking down the leaf pack to only the main leaf gets rid of any pack restrictions anyways, so this would just save time from breaking down the pack.
    tacobienhecho likes this.
  3. Jan 19, 2016 at 8:13 PM
    #583
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    you dont want to guess you want to take the time to do it right. Jon, do you remember where I out the post with pics about how to cycle leafs and do the block etc ?
  4. Jan 19, 2016 at 8:33 PM
    #584
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I know how to do it. Was just thinking out loud. mechanically it would be doing the same thing, would it not? The only difference being how far the shackle will truly drop forward, but with a string it would give you the absolute maximum without the hassle of breaking the pack down.
  5. Jan 19, 2016 at 8:46 PM
    #585
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    If I were to guess it would be because a leaf spring that is flat from shackle to shackle is the same as a piece of string, straight. But the shape of a leaf will not reflect a piece of string at full droop cause they are formed with a predetermined shape. :notsure: just a guess
  6. Jan 19, 2016 at 8:48 PM
    #586
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    I don't see how a piece of string could accurately mimic a leaf bending at droop ? shock tab and hoop placement is so critical I would not ever risk it
    Rattletrap66 likes this.
  7. Jan 19, 2016 at 8:54 PM
    #587
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    So I get how using the main leaf of the pack will give you your maximum droop and bump numbers but like I mentioned before in my case, the overload leaf limits how much I can stuff the axle and thus limits "bump." So using the main leaf with the block to simulate the rest of the pack is essentially going to give me false hope.
  8. Jan 19, 2016 at 8:56 PM
    #588
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Maybe so, it was just a thought and i was wondering if anyone had an answer.
  9. Jan 19, 2016 at 8:58 PM
    #589
    Sacrifice
    KS
    DCSB OR 4X4 LT
    The overload shouldnt prevent the pack from flattening completely though. It may take more force to get there but shouldnt prevent it. Now if you were bumping in negative arch it would effect travel
  10. Jan 19, 2016 at 9:26 PM
    #590
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    It could be in my thread or it may have been in the old MTBS.
  11. Jan 19, 2016 at 9:58 PM
    #591
    zscott
    Zach
    Utah
    My dakars are pretty much flat always. Have been since I got them and it is normal for dakars. According to others who have spoken with ARB they are made to go into negative arch Under full compression.
    AaronArf likes this.
  12. Jan 19, 2016 at 10:28 PM
    #592
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    So I am completely paranoid about my Fox shocks rusting out, this last little bit of snow has the roads literally dusty with salt and I found my self washing the truck to get the salt off the shocks in 14 degree weather today sooo
    Is there any "common" product such as WD40 for example I could spray on the shocks every once in a while to help prevent them from rusting? Something you could pick up from the local auto parts store?
  13. Jan 19, 2016 at 10:29 PM
    #593
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    A lot of people Fluid Film their frames, not sure about using that on coil overs but something to look into
  14. Jan 19, 2016 at 10:32 PM
    #594
    Josh828
    Josh
    Avery NC
    Yeah Ive heard of that and may look into it but I'm hoping someone has some secret spray that works kinda the same way, like I've always heard WD40 prevents rust, but I figured some of these guys would know for sure before I go to spraying all kinds of crap all over them!
  15. Jan 19, 2016 at 10:33 PM
    #595
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    @iJonny there is another question that gets asked frequently in the MT and LT threads. Maybe add a "shock care" link for all things related? :notsure:
    Josh828[QUOTED] and TacoSTIG like this.
  16. Jan 19, 2016 at 10:33 PM
    #596
    TacoSTIG
    TacoSTIG Untamed Member
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    I run Boeshield, very similar to Fluid Film. http://www.amazon.com/Boeshield-T-9-Waterproof-Lubrication-aerosol/dp/B001447PEK
    Josh828[QUOTED] likes this.
  17. Jan 19, 2016 at 10:33 PM
    #597
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    If you don't care about how they look check out "corrosion x". Sprayed that stuff all over my Dakars which fixed the squeak and coated them.
  18. Jan 19, 2016 at 10:40 PM
    #598
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Forgot that about the dakars. Then yes an overload would prevent some travel. The pack could still go negative, its just going to take a lot more force to get there.
  19. Jan 19, 2016 at 10:44 PM
    #599
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Unless you weld the lower shock mounts below the axle you won't have enough up travel to go so negative to hit your overload springs.
  20. Jan 20, 2016 at 3:23 AM
    #600
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Oh really? Stock shock tabs and my Dakars go negative every time I wheel.
