Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jun 5, 2024 at 12:24 PM
    #6261
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Are those bushings you installed two piece or how do you get the grease from the zerks where it’s needed?
    danielgonzzz likes this.
  2. Jun 5, 2024 at 12:25 PM
    #6262
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I have a set of my original Toyota arms I am about to do this to.
    Which lower ball joint did you use?
    Were the White Line bushings difficult to push in?
  3. Jun 5, 2024 at 12:30 PM
    #6263
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    After I pressed the bushings in, I just drilled a hole all the way through the arm and bushing.
    OEM ball joints sourced from ebay overseas.
    Bushings were a little bit of a trick, but once I got the press setup right they went easy.
    Taco47 likes this.
  4. Jun 5, 2024 at 12:37 PM
    #6264
    TireFire
    Olympic Peninsula
    Where does the old grease exit when you pump in more?
  5. Jun 5, 2024 at 12:56 PM
    #6265
    Squeaky Penguin
    Brett
    You need to loosen the cam bolt, and then it comes out either side of the bushing.
    TireFire[QUOTED] likes this.
  6. Aug 16, 2024 at 10:41 AM
    #6266
    danielgonzzz
    danielgonzzz Well-Known Member
    Daniel
    2019 Tacoma TRD Sport 4x4
    Stawk as FUCK!
    Are the Whiteline poly bushings the same exact part for 2nd gen & 3rd get lower arms?
  7. Aug 16, 2024 at 3:31 PM
    #6267
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    My guess would be no. They use different size bolts/sleeves between the gens
  8. Aug 21, 2024 at 1:52 PM
    #6268
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    Don't mind me I'm hopping in here because the 4Runners mid travel thread sucks.
    Anybody been able to compare 8112's to 6112's on their trucks? Mainly looking to see how much speed they were able to gain by adding the bypass bits.
  9. Aug 21, 2024 at 2:10 PM
    #6269
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    And squeaking or added vibration?
  10. Aug 21, 2024 at 2:13 PM
    #6270
    Scott B.
    Scott
    Georgia
    How necessary/important/suggested is welding up the holes in the LCAs?
    I am rebuilding a set of Toyota arms (Toyota ball joints, White Line bushings) and deciding if I will weld up the holes or not.
  11. Aug 21, 2024 at 2:15 PM
    #6271
    Squeaky Penguin
    Brett
    If you're worried about that, you're in the wrong thread. :p
    No idea. I just had the welder going and decided to do that. I also live in a dry climate, you may be better off with drain holes in GA. :notsure:
    AShive92 and Arcticelf like this.
  12. Sep 15, 2024 at 7:22 PM
    #6272
    danielgonzzz
    Daniel
    Stawk as FUCK!
    You’re fine, I’d be worried about warping with the heat at that point if filling it with weld.
    Scott B.[QUOTED] likes this.
  13. Oct 8, 2024 at 11:08 AM
    #6273
    CajunCrawler
    CajunCrawler Well-Known Member
    Cooper
    2015 Black Tacoma
    JL audio speakers, amp, sub Black method 305 wheels 285/75r16 BFG KM3 Bilstein 6112/5160 JBA uca total chaos diff drop
    I have a base 2nd gen with 4wd. It is upgraded a good bit with 6112 and 5160s + other little things. I'm trying to do mid travel and sticking with the theme of cheap truck. Cheaper mid travel aka under 1k setup any good suggestion and should I make a build thread.
    Arcticelf likes this.
  14. Oct 8, 2024 at 11:15 AM
    #6274
    CajunCrawler
    Cooper
    2015 Black Tacoma
    The plan is Chevy 63 kit
    Chevy 63's (junk yard) add new bushings
    BAMF shock relocation
    Bilstein 7100's
    welding isn't a problem no cost I have a guy thats good gets practice on my truck so he does it for free
    palmertacoma likes this.
  15. Dec 4, 2024 at 2:02 PM
    #6275
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Does anybody have any Uca washers for aftermarket arms left over? For icon but most are the same
  16. Dec 13, 2024 at 4:31 PM
    #6276
    4runnersr569
    4runnersr569 Well-Known Member
    West Valley, AZ
    4Runner
    For those of you that have limit straps on your front mid travel set ups, how much of or at all does the double nutted clevis with spring float upwards when you have uptravel?
  17. Apr 9, 2025 at 8:22 PM
    #6277
    370HSSSV
    370HSSSV Active Member
    Hey guys, I couldn't figure out the clunking noise on my truck 2013. King 25001-119A. 2.5 front coilover with kibbetech UCA, OEM lowers (put new ones on when I updated the suspension)
    Clunking come from driver side front when it's unloaded. Meaning when I am turning left (truck leans to the passenger side), driver side suspensions unloads (less compression on driver side when turning left) If the road surface is uneven, that's when the clucking noise happens when suspension is unloaded and going over bumps.
    Passanger side is fine, no noise, only driver side does this. Visual inspection didn't show any signs of abnormal things...
    Any ideas on where the noise is coming from?
  18. Apr 9, 2025 at 9:37 PM
    #6278
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    You sure it's the suspension and not loose LCA cams? I was getting some intermittent clunking when turning moderate to hard driver (mostly in reverse backing into my carport, but also intermittently when making U-turns), and it went away when I installed new LCAs with new OEM hardware.
  19. Apr 11, 2025 at 12:01 PM
    #6279
    4runnersr569
    West Valley, AZ
    4Runner
    Lca tabs are most likely loose
  20. Apr 14, 2025 at 7:53 PM
    #6280
    370HSSSV
    I will have to double check that, it did get new cam hardware and new lowers, cause the old ones are seized up there.
