Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jan 22, 2016 at 6:57 PM
    #761
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    I'm not bashing the idea, I think it's got a good meaning behind it. But, I'm just pointing out some flaws you might want to take into consideration.
    Now the thing with not going into boost, is that if you're in deep enough water to need a snorkel, you're more than likely going to be in 4L which is going to bump up your rpms. Cool, no problem right? Except the supercharger builds boost with the higher rpms you go. You hit 2k, and I'm sure you've got at least 2-3lbs of boost pumping into that motor, and that's on the low side of my guesstimate. Which could cause problems if it's choking down and not getting that air. Just be rich for a bit, nothing too crazy I'm sure.
    Best bet before going through with all of this would to call Arb because I'm sure they've flow tested them to chec the cfm.
  2. Jan 22, 2016 at 7:03 PM
    #762
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Cause itd still pull dirty air. But thats not the reason he wants one either.
    Wouldnt you want it to fail closed? That way youre using the snorkel in case you happen to go in water?
    You can be in higher rpms and not be in boost. Theres a bleed off valve (wastegaste-esque) for that.
  3. Jan 22, 2016 at 7:04 PM
    #763
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Once again we switched the topic from MT :facepalm:
    Stryker420 and Kerleyfries like this.
  4. Jan 22, 2016 at 7:05 PM
    #764
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Not entitely true, you can still go into high rpms and not build boost. I've found its more based on throttle position. When my clutch started slipping everytime I boosted I learned really quick how much throttle I could use and not go in to boost. Also remember I've got a 6 speed so I can control RPMs alot better than autos. But yea, like you said, worst case is I run rich during the crossing before I can swap back over. I won't be tuning super close to lean either since I dont want to burn up an engine. I'm probably going to be building my own snorkel since with all that BS smog shit I'm gonna have to get creative with my piping arrangements and still try to maintain the least amount of bends
  5. Jan 22, 2016 at 7:08 PM
    #765
    VolcomTacoma
    Jeff
    NorCal
    I thought about having the solenoid fail closed, but a) I dont really plan fording and rivers lol, so at most jist big puddles and the occasional stream lol, and B, if I'm on a trail or on the road and it fails, I dont want to be stuck pulling air through just the snorkel if I'm tuned for both, you know?
  6. Jan 22, 2016 at 7:09 PM
    #766
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    If your in deep enough water that you NEED a snorkel there's a ton of other stuff needing to be water proofed or relocated. Snorkel is for dust and the mall
    Anyways enough cfm measurments who's got the tape measure, let's measure travel next ! Lol
  7. Jan 22, 2016 at 7:13 PM
    #767
    Kerleyfries
    Zack
    Lebanon
    Ahh. I'm not the most knowledgable on SC's, I used to have a big turbo WRX so that's where I obtained my limited tuning knowledge.
    But if that's the case and you can keep it out of boost when switched to the snorkel, I see no problem with going through with it. Worst comes to worst, the valve sticks open. In that case, keep a piece of pipe that would be interchangeable with the piece containing the valve so you can pull it out and replace it with a straight through pipe to either the CAI or snorkel if need be.
  8. Jan 22, 2016 at 7:14 PM
    #768
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    I'd go with reservoirs for the rear or move up to 2.5s if anything. Not really necessary though.
    2ndGenJonny[OP] and SC2SC like this.
  9. Jan 22, 2016 at 7:17 PM
    #769
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I agree they arent necessary for the most part, but they dont hurt any.
    Im going 2.5s with resi f/r. I cooked my stock shocks on the last trip
    SC2SC likes this.
  10. Jan 22, 2016 at 7:18 PM
    #770
    VolcomTacoma
    Jeff
    NorCal
  11. Jan 22, 2016 at 7:19 PM
    #771
    SC2SC
    SC2SC Likes Pineapple on Pizza
    Jonathan
    South of Charlotte
    2014 DCSB MGM TRD OR 4X4
    Icon Custom Build Custom Exhaust • SOS Sliders• RokBlokz
    :thumbsup:
  12. Jan 22, 2016 at 7:19 PM
    #772
    Kerleyfries
    Zack
    Lebanon
    I prefer to use the bottom one when measuring.... Everything
  13. Jan 23, 2016 at 4:56 AM
    #773
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Sounds like a good setup. What specs are you getting the rears built to?
  14. Jan 23, 2016 at 4:59 AM
    #774
    Arcticelf
    Gladiator
    ^^This.
    Good luck on the Ypipe build though, its a cool idea.
  15. Jan 23, 2016 at 6:15 AM
    #775
    SC2SC
    Jonathan
    South of Charlotte
    The rear is Cb non resi 2.0 made to work with Dakar. Icon refused to state exact compressed and extended lengths. Maria at Headstron told me 15.9" x 26.5"-- which should be an excellent product at a great price.
    Contemplating if i actually need rear resi too, which would add appx $200.00 or so.
    Have done lots with stock trd OR suspension- just need more lift and dont like the marshmellow feeling of stock.
  16. Jan 23, 2016 at 6:16 AM
    #776
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    I've run close to that set up. Non resi ext c/o, icon uca, but I had the 2.0 resi rears. Plus dakars. I liked it. I never noticed the shock fade from temps or anything. But most my off roading is lower speed and lower shock speeds so it's not working super hard. You'll like it and be fine unless you plan on mobbing through the bumps.
    I've since upgraded the fronts to resi with the cdc. I don't notice any difference when set on the 4 (same performance as non cdc). Same I haven't noticed any real difference between the non resi and resi. But I do like the cdc to be able to change up how it feels on the road. Windy mountain roads I can crank it to 9 and help with body roll. Then back it to softer for the forest service roads, or even lower.
  17. Jan 23, 2016 at 6:28 AM
    #777
    SC2SC
    Jonathan
    South of Charlotte
    Nice! Didyou stick with 650# coils? How much threads do have showing- and what size tire? Please advise, thanks! :)
  18. Jan 23, 2016 at 6:41 AM
    #778
    freddirt
    freddirt Well-Known Member
    Clint
    Southern Utah
    Usedtahave'21 CMNT GRY DCSB TRD OR 4x4
    Wheels: Helo HE900 17x9 -12 offset. Tires: Toyo open country AT3 265/65. JLT catch can. RSG sliders. Diff breather mod. Wheelers extended rear brake lines. LED interior lights. Front suspension: Accutune King 2.5 ext travel w/ adjusters, Icon tubular uca w/ delta joint, Wheelers super bumps. Rear suspension: Accutune Tundra 2.5 remote resi Kings w/ adjusters, Icon RXT leaf pack, U Bolt flip w/ Wheelers super bumps.
    subbed... I like the info! :thumbsup:
  19. Jan 23, 2016 at 6:51 AM
    #779
    Arcticelf
    Gladiator
    That's bizzar, you can get extended/compressed lengths about 30 seconds after you open the box...
    Sounds like a good set up.
    SC2SC[QUOTED] likes this.
  20. Jan 23, 2016 at 6:56 AM
    #780
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    This is such a fuckin douche comment. So you bring up a topic in a thread that has nothing to do with what you're talking about then tell everyone that unless they agree with your opinion to shut the fuck up? You don't wanna get it right, you just wanna be right. To this point in yalls conversation, you have been the only one to show any kind of butt hurt and immaturity while everyone else seems to be having an intelligent, OPINION BASED adult conversation.
    ckeene9, tacomgee, agunday21 and 3 others like this.
