Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jan 25, 2016 at 9:01 AM
    #821
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    On another note. I messed with my spring pack, BAMF relocation towers and figured out how I am going to mount the 12" Shocks.
    I am going to set it up so the shock has 5" up travel and 7" of down. I think by removing the upper overload leaf in my dakars I can get close to the 5" of up. The main leaf goes into negative arch but according to ARB that is typical of the dakars.
    I probably wont be able to get the full 7" of down without reworking the shackles as they seem to limit the last few inches but it will work for now.
  2. Jan 25, 2016 at 9:01 AM
    #822
    zscott
    Zach
    Utah
    I think I linked that thread in my brief writeup of rear mid travel setups too so it should be in here somewhere.
  3. Jan 25, 2016 at 9:04 AM
    #823
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I pm'd him
  4. Jan 25, 2016 at 9:11 AM
    #824
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Added info. Thanks
  5. Jan 25, 2016 at 1:54 PM
    #825
    TacoSTIG
    TacoSTIG Untamed Member
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Thanks man, I honestly don't understand the 'difficulty' hype with shackle flip. Perhaps most people are using lower grade drill bits without lube? I barely spent any time with the drill, and heck my pilots were mostly off center... and crooked. Can't say it enough, quality tools make this job a breeze.
  6. Jan 25, 2016 at 1:57 PM
    #826
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    The plasma cutter made short work of my rivets
    TacoSTIG[QUOTED] likes this.
  7. Jan 25, 2016 at 2:10 PM
    #827
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    :laser:
    Can't beat plasma, it's the optimal route for sure.
    I'm still impressed with what a quality bit can do. Glad this job forced me to upgrade from the crap I normally use.
    2ndGenJonny[OP] likes this.
  8. Jan 25, 2016 at 2:12 PM
    #828
    DCLBFTW
    Minnesota
    06 dclb
    Otherwise i use bits in my shop made by norseman drill and tool
    The bits are made in the usa and they are a local company
  9. Jan 25, 2016 at 2:13 PM
    #829
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Are you utilizing all of your shock when drooped? Looks like it should be drooping more with a shackle flip.
    This is mine without:
    LTDSC likes this.
  10. Jan 25, 2016 at 2:18 PM
    #830
    DCLBFTW
    Minnesota
    06 dclb
    No im not the shock mount tabs on the axle need to rotate down to fix up travel issues and also dakars dont flex for shit
  11. Jan 25, 2016 at 2:19 PM
    #831
    deeezy
    Dana
    Hawaii
    Oh okay. Could be camera angle making it look like that too.
  12. Jan 25, 2016 at 3:16 PM
    #832
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Mine were a total bitch. Although I didn't have a HC rear or remove my bed to do it at the time so really getting decent angles for drilling were out. Air hammer did nothing cause my compressor was shite, so then I just used a torch and those rivets were out in 40 minutes for both sides. Also my ATO mount holes didn't quite line up with my OEM holes so I had to drill those out some more. Most of the time it doesn't go as easy as you made it sound haha.
    AZ2013 likes this.
  13. Jan 25, 2016 at 3:37 PM
    #833
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    :confused: Dakars flex just fine
    llibrm, tacomgee, AZ2013 and 3 others like this.
  14. Jan 25, 2016 at 3:38 PM
    #834
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Showoff
  15. Jan 25, 2016 at 3:38 PM
    #835
    zscott
    Zach
    Utah
    Do you have the D29 XL add a leaf?
  16. Jan 25, 2016 at 3:42 PM
    #836
    ckeene9
    Chesterfield, VA
    See Build Thread
    No, ran it for a month or two but went with a different set up after messing around with some things. Spring rate was way to high with that AAL.
    Bsheriff11 likes this.
  17. Jan 25, 2016 at 3:42 PM
    #837
    ckeene9
    Chesterfield, VA
    See Build Thread
    :laughing: Just showing what can happen if people spend the time to tweak and tune their set up.
    2ndGenJonny[OP] and zscott like this.
  18. Jan 25, 2016 at 3:46 PM
    #838
    zscott
    Zach
    Utah
    Is it the shackle setup that ended up working better or did you add/remove leafs?
  19. Jan 25, 2016 at 3:49 PM
    #839
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    So.. all this shock relocate, shackle flip, and flex talk have me feeling inadequate.. :pout:
    I dont think I use my truck to its full potential to require all this MT maximization..
    My Kings with the BOSS pack have served me well for the trips and terrain we do.. but.. I cant help to want more and get everything I can out of my setup. Maybe down the road.
  20. Jan 25, 2016 at 3:53 PM
    #840
    zscott
    Zach
    Utah
    To be honest what you have is probably more than adequate for most people. I debated for a long time to do a relocation and even now I wonder if I should have just put the OEM replacement kings in and went with those.
    In the end I have an addiction to tinkering and I will admit it, sometimes I tinker without even needing to. :oops:
    Glueman likes this.
