Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Feb 2, 2016 at 10:52 AM
    #1041
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Nice info Jason! That is some savings over the Fox ones.
    LTDSC likes this.
  2. Feb 2, 2016 at 10:55 AM
    #1042
    2ndGenJonny
    Jon
    Gilbert, AZ
    They have 2 different leaf packs for that kit and a few builds to look at. The Morroco Taco and the 2013 builds use that kit. Call over there and talk with Pat about it!
    I was going this route when I purchased some 14s. I have since decided to just remail SOA and keep the money I have invested in it vs starting over again.
  3. Feb 2, 2016 at 10:56 AM
    #1043
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I should say too that you don't actually need to use a pinch style mounting can with these, you can weld the steel body of the bump itself straight to the truck. I wanted to use the can just for the long term stupidity upgrade possibilities ...because I tend to get stupid like that :facepalm: Pinch cans are only $25 each just about anywhere so for $100 total for all 4 corners and the upgrade capability the cans were worth the $ for me.
  4. Feb 2, 2016 at 10:58 AM
    #1044
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Might be a good like for the OP page ?
  5. Feb 2, 2016 at 11:00 AM
    #1045
    2ndGenJonny
    Jon
    Gilbert, AZ
    Yea, I should add a can/ bump section in the FAQ. Who just bought the Fox bumps? Was it @Palehorse1 ?
  6. Feb 2, 2016 at 11:04 AM
    #1046
    G.T.
    G.T.
    CONUS
    Yup, pics somewhere in my build+bs thread.
  7. Feb 2, 2016 at 11:15 AM
    #1047
    2ndGenJonny
    Jon
    Gilbert, AZ
    I'll start a Can/bump section in the FAQ
  8. Feb 2, 2016 at 11:34 AM
    #1048
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    you're a saint.
  9. Feb 2, 2016 at 12:54 PM
    #1049
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    These are sweet! Does anyone have a direct comparison vs actual air pumps?
  10. Feb 2, 2016 at 1:06 PM
    #1050
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    An air bump is more fine tunable because you can vary the PSI...and they say King or Fox on them which pulls way more ho's at the mall :thumbsup:
    With the Daystars you have three options :
    2 - black EVS inserts = stiff
    2 - blue EVS inserts = soft
    1 black + 1 blue = medium
    ...and you still have $400 extra to spend on beers :cheers:
  11. Feb 2, 2016 at 1:14 PM
    #1051
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    And hos.
    Are you planning to replace with air bumps eventually?
  12. Feb 2, 2016 at 3:35 PM
    #1052
    G.T.
    G.T.
    CONUS
    Glueman likes this.
  13. Feb 2, 2016 at 6:00 PM
    #1053
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    You can even buy fox or king stickers and put them on yourself
    Skootter14 likes this.
  14. Feb 2, 2016 at 10:40 PM
    #1054
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Prob not, my truck is mainly an expo rig.
  15. Feb 2, 2016 at 10:44 PM
    #1055
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
  16. Feb 3, 2016 at 7:20 AM
    #1056
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    If you look at the difference in the cans from Fox to King on the TC site you will notice that the King can sits higher on the mount. I would bet TC accounted for the correct full bump location in the King mount. King bumps have a threaded back end so they screw into their can but you can mount them in a regular pinch can too.
  17. Feb 3, 2016 at 3:31 PM
    #1057
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
  18. Feb 3, 2016 at 7:19 PM
    #1058
    mutilatedjak
    WA
    Ahhhh OK good to know. I would want to buy the Fox mounts, cheaper, and adjustable, then just put some king bumps in them. Any reason why the threaded mount would be significantly better than the pinch one?
  19. Feb 3, 2016 at 7:23 PM
    #1059
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
  20. Feb 3, 2016 at 7:24 PM
    #1060
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Best guess is the can is easier to slip through a pinch mount vs rotational. Probably not anything to be worried about either way as long as there is routine checking
