Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Feb 18, 2016 at 7:41 PM
    #1201
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    OP has failed us...
  2. Feb 19, 2016 at 5:42 AM
    #1202
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
  3. Feb 19, 2016 at 5:47 AM
    #1203
    05tacomabro
    05tacomabro will work for truck parts...
    Alex
    Tucson
    05 dcsb trd OR, 06 xrunner, 73 fj 40
    Icon ex. Travel co's, spc uca's, bamf lca skids, 1" body, all pro heavy duty sliders, expo springs, BAMF shackle hangers, 14" bilstein 7100, rear frame box, custom rear frame crossmember, ifs skid, transmission skid, t-case skid(modified by @jeepandrew for exhaust reroute and more beef), custom k&n intake, flowmaster, diff breather mod, stereo with nav/speakers/subs, coverking tactical ballistic seat covers, Baja utility rack, lots of bed liner, anytime fog mod and steel braided brake lines, energy suspension rad support bushings, abs kill switch, cali raised ditch lights, fsr rtt. Lots of plans, little money....
    Where's my stapler
  4. Feb 19, 2016 at 5:52 AM
    #1204
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    It's not privilege if it doesn't help you win Mario cart.
  5. Feb 19, 2016 at 5:59 AM
    #1205
    2ndGenJonny
    Jon
    Gilbert, AZ
    :D
    12TRDTacoma likes this.
  6. Feb 19, 2016 at 7:50 AM
    #1206
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I don't think it's an opinion. Mid travel implies having more travel then stock while using stock length a-arms in the front and stock length springs on the back. You don't have to relocate your rear shocks as you can run a 10" shock in the stock mount
  7. Feb 19, 2016 at 8:46 AM
    #1207
    SilverSurfer
    SilverSurfer Well-Known Member
    Mark
    Los Angeles
    2013 4X4 LT
    Cool thanks!
  8. Feb 19, 2016 at 12:28 PM
    #1208
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Going to the powdercoater today...
    @Pelfreybilt gas tank skid going on tomorrow...
  9. Feb 19, 2016 at 4:46 PM
    #1209
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Damn I thought you was an O/R
  10. Feb 19, 2016 at 4:55 PM
    #1210
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Nope. I'm not that cool :(
    Acerwin[QUOTED] likes this.
  11. Feb 19, 2016 at 4:58 PM
    #1211
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Least your rear axle is better than mine
  12. Feb 19, 2016 at 5:17 PM
    #1212
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Yup!
  13. Feb 19, 2016 at 6:32 PM
    #1213
    2ndGenJonny
    Jon
    Gilbert, AZ
    Referring to Inboard 12s?
  14. Feb 20, 2016 at 7:30 PM
    #1214
    Glueman
    Utah
    The Plague....
  15. Feb 21, 2016 at 4:18 PM
    #1215
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Hoping to get a little bit of educating regarding the Deaver J66 pack. I understand this pack has some mixed reviews and I've gathered that much of the disappointment with these springs is that the end user had chosen a spring that was not matched for the intended use.
    I understand this pack is meant for little to no additional weight, increasing the wheel travel, and reducing axle wrap. What would be the ideal use of these springs and how would (or.. should!) your shocks be setup for them to be a viable option? I've seen DSM mention that even the standard bolt-on King's aren't ideal.. What does it take to "properly" run these?
  16. Feb 22, 2016 at 7:36 AM
    #1216
    Arcticelf
    Gladiator
    Another update for the definition of 'Mid Travel': must make at least one Race Truck noise. Squeak, thump, rattle, etc.
    llibrm and 12TRDTacoma like this.
  17. Feb 22, 2016 at 8:00 AM
    #1217
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    then im 100% covered with that notion.
  18. Feb 22, 2016 at 8:10 AM
    #1218
    2ndGenJonny
    Jon
    Gilbert, AZ
    I 2nd this! I think ive finally got over all of the noises my lowers and Heimed uppers make. Even though ive found the perfect lube to keep them not as noisy, its still there.
    Arcticelf likes this.
  19. Feb 22, 2016 at 8:11 AM
    #1219
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    my front end hates life right now with all the sand. I need to hose it down and grease it up tonight before it does any damage.
  20. Feb 22, 2016 at 8:15 AM
    #1220
    2ndGenJonny
    Jon
    Gilbert, AZ
    After using both the Triflow spray and drip ive now found Bell Molylube spray. This stuff coats and last much longer than triflow. Ive had no issues with dirt sticking to it also.
    12TRDTacoma and LTDSC[QUOTED] like this.
