Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Feb 23, 2016 at 11:43 AM
    #1261
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Still working on that one :anonymous:
    Never was any good at coloring :p
  2. Feb 23, 2016 at 11:55 AM
    #1262
    Dogg23
    Dogg23 I like big tires
    Nate
    Rochester, NY
    16 DC OR MT 10 Sport MT & 16 4R Trail
    Big tires
    You only tryed them 10 times. lol
    They are OEM but rebuilt and for $82 a side I just kept the old ones so I can put some new/better boots on them later. I do believe u get what u pay for but with 8 months and no issues I'm happy so far. I did lower the front from 3+ in. of lift to just over 2in when I switched from OME to ADS a few months after I put them on. That 1in. made a huge difference with boot rub. No more black ring of death and I have over 3in of down travel now :taco:
  3. Feb 23, 2016 at 12:00 PM
    #1263
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    FTFY :D Theres a reason they are priced way less, I would only get one to use as a spare..
  4. Feb 23, 2016 at 12:13 PM
    #1264
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    They are not OEM rebuilt. You may get lucky and get OEM, but they are not all OEM. Out of the 10, 2 were all OEM parts. Some have different inners, different outers, different shafts. It's whatever they get in china.
  5. Feb 23, 2016 at 1:08 PM
    #1265
    Dogg23
    Nate
    Rochester, NY
    Big tires
    The two I received had OEM inner and outer CV housings and autozone told me they were reman OEMs. That's why I said oem. I completely agree with u guys that they are not the best option. If I didn't lower the front the boots would be F'd already. (fuck, the new ones from Advance were shorter so didn't even try them and picked up the ones from Azone because the front was already apart). Atleast people will see not to buy them and I assume u did get 10 cv's for the price of one and it gave u an excuse to work on your truck :notsure:
  6. Feb 23, 2016 at 3:52 PM
    #1266
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    10 between left and right side. So, for the price of two.
    My time spent working on the same broken shit is worth more to me than free replacements. I'm over it so I bought OEM.
    Sacrifice and deadhed61 like this.
  7. Feb 23, 2016 at 5:27 PM
    #1267
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Any thoughts?
  8. Feb 23, 2016 at 5:34 PM
    #1268
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  9. Feb 23, 2016 at 5:36 PM
    #1269
    JustDSM
    Justin
    Ogden, UT
    Damn.. Thanks for the info!
  10. Feb 24, 2016 at 5:59 AM
    #1270
    IAH78
    IAH78 Well-Known Member
    Houston
    2012 Baja TX
    Hey fellas, I'm trying to finalize my mid travel choice and I'm hoping y'all can help me answer a few questions I haven't been able to answer in my research. Any help is much appreciated.
    My plan is kings on all corners. Front is "extended" oem performance series 2.5"rr w/700lb coils. All pro expedition leafs with flip kit and timbren bumps. Bumper and winch on front = 160lbs. Bumper with tire carrier on rear = 180-200lbs. Part #25001-119 and 25001-121. Are these the shocks guys running this setup get? Does "extended" mean just longer rods to meet the need of the specific vehicle?
    Most of my questions concern proper shock length.
    I measured my leaf travel extended at 27.5 inches and with compressing the bumps its at about 17.5-18 inches. Rear Center Hub to fender is 25 inches but I expect it to be 24" once I put the bumper on.
    Front question
    Do the King coilovers guys are running (I believe these are the performance series oem "extended") have added travel or is the rod just 1" longer?
    Rear question
    For the guys running this setup, what length rear shock did you go with(is this also just the oem King shock with a longer rod or is there more travel)? Do you have the compressed and extended measurements?
    At full extension should the shocks be the limiting factor? The guy at allpro I spoke with said its fine for the axle to hang on the shocks but from what I've read this can damage the shocks and leafs should be the down travel limit and bump stops the up limit.
    Thanks for the help guys!
  11. Feb 24, 2016 at 6:05 AM
    #1271
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Did you read the FAQ? Cause much of what you ask is in there.
  12. Feb 24, 2016 at 6:15 AM
    #1272
    IAH78
    Houston
    2012 Baja TX
    I did read ALL the FAQ and mid travel stickies at least once over the last few months. Didn't want to waste anyone's time.
    I couldn't find specifics though on King brand length, part #, etc. or the other questions specific to my setup and what I want to do. Mostly they answer the general knowledge questions.
    I have also made phone calls to dsm and allpro and more or less got the run around or general answers like "you'll be fine as long as your shock doesn't measure more than 15.25inches compressed".
  13. Feb 24, 2016 at 6:34 AM
    #1273
    2ndGenJonny
    Jon
    Gilbert, AZ
    You asked a lot, so ill pick a few points and answer.
    Ok so " extended " means the internal spacer in the front CO is removed. This is to compliment the approx 1" extra droop that the UB UCAs give. That is all listed in what is mid travel and the VERY lengthy shock threads.
    As for the right shock/pack for the rear, we have no exact answer becuase leaf packs differ. I know that DSM will swap the rod end on a King for the expo pack when requested. This is to be more functional with the extra droop from the expo pack.
    If you are going with OEM replacement rears (meaning the shocks use OEM mounts) the shock will almost always be the limiting factor for droop. The relocate with a longer shock is the best way to get full use of a good aftermarket leaf pack.
    *disclaimer
    Im not saying that an OEM replacement and expo pack isn't good. It is actually more than enough for most and works.
    *disclaimer for my disclaimer
    All opinions are my own cause I really dont want to start a dick measuring contest.
    Old School likes this.
  14. Feb 24, 2016 at 6:42 AM
    #1274
    IAH78
    Houston
    2012 Baja TX
    I did ask a lot and I thank you for your quick answers! This helps. It's easy to get confused after reading hundreds of pages on other builds and sometimes contradicting info. Thanks for your patience with this newb!
  15. Feb 24, 2016 at 6:45 AM
    #1275
    lockwire24
    lockwire24 Well-Known Member
    Mark
    Vancouver
    2012 MG DBL cab LB TRD sport
    Cobra CB, Firestik II w/ Relentless hood mount, 4x Innovation sliders, Level 8 tracker pro, TRD exhaust, home made grill insert, Leer XR, led bed lights, King shocks, LR uca, Pelfreybuilt front/rear bumpers and skid plates, B.A.M.F. rear shock relocate.
    This my setup: kings ext rr front, steel front bumper, 2.5 12" rr with BAMF relocate on rear, steel back bumper with tire carrier, canopy and dakars hd.
  16. Feb 24, 2016 at 6:45 AM
    #1276
    IAH78
    Houston
    2012 Baja TX
    I like to operate on a trust-but-verify philosophy on subjects I'm not a pro at so I'm just looking for some confirmation and a little clarification from my more knowledgable/experienced peers! Thanks guys
  17. Feb 24, 2016 at 6:48 AM
    #1277
    2ndGenJonny
    Jon
    Gilbert, AZ
    Is that a custom Dakar pack? I really thought you were shackle flipped with how much your tuck is stinkbuggin. Im expecting to look like that unloaded after this weekend
  18. Feb 24, 2016 at 6:49 AM
    #1278
    IAH78
    Houston
    2012 Baja TX
    Nice setup lockwire! I like the idea of the shock relocation in the rear but it's more than I think I want to get into got now with the cutting welding etc. I like its advantages though. Maybe in a few years:rolleyes:
  19. Feb 24, 2016 at 6:54 AM
    #1279
    2ndGenJonny
    Jon
    Gilbert, AZ
    Well OEM kings are about 800$ where the 12s are 500$.
    The BAMF tower is 100 (DIY kit)
    Extended brakelines 80
    All pro flip 100ish
    So you can do more of the relocate for less but it also depends on if you can weld or know a good welder.
  20. Feb 24, 2016 at 6:59 AM
    #1280
    IAH78
    Houston
    2012 Baja TX
    Johnny, have you done the bamf relocate yet? We're you running kings in the rear before with the custom deaver pack? What lengths?
    Also I like your tire/bed rack. Did you build it or buy it? I don't know how to weld yet but it's on the list for this year and I'd like to build my own bed rack.
