Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Feb 24, 2016 at 2:17 PM
    #1301
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Im just messing with you man...
    But i am an ex Icon customer
  2. Feb 24, 2016 at 2:18 PM
    #1302
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    So now is the chance to get the 14" spring, should i get the king 14" #650 springs now? for less preload.
    @jberry813 drop some knowledge on me for my situation.
  3. Feb 24, 2016 at 2:48 PM
    #1303
    2ndGenJonny
    Jon
    Gilbert, AZ
    I dont imagine that hybrid bumper is very heavy so why are you wanting to jump to 700s?
    Have you revalved the compression side to be stiffer? Or thought about moving the battery into the back area to get some weight off the front ?
    The reason I ask is one of our locals with pelfrey plate, winch and other goodies went 15% stiffer on the compression side to fix his Icon bottoming due to added weight issue.
  4. Feb 24, 2016 at 2:49 PM
    #1304
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    I also have the heavy V8. Im looking to keep the #650 rate, just 14" long spring, instead of the 13"
  5. Feb 24, 2016 at 2:52 PM
    #1305
    2ndGenJonny
    Jon
    Gilbert, AZ
    Ok, thats a good option as well but why not look at the valving if you are in there anyways?
  6. Feb 24, 2016 at 2:53 PM
    #1306
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    IIRC, your preload will be the same as you have now if that makes sense. You'll still have to crank down your collar the same as before, except it'll look like less preload because of the extra inch of spring.
    LTDSC[QUOTED] likes this.
  7. Feb 24, 2016 at 2:53 PM
    #1307
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
  8. Feb 24, 2016 at 2:53 PM
    #1308
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i like the way it drives now, just would like less pre load unless its a moot point and just rebuild and move on.
  9. Feb 24, 2016 at 2:55 PM
    #1309
    2ndGenJonny
    Jon
    Gilbert, AZ
    Have you put in a call to icon to see what they say/to do?
  10. Feb 24, 2016 at 2:56 PM
    #1310
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    they've told others to go to 14" springs and now they even offer a 14" spring for these when they originally were shipped with 13" #650 springs.
  11. Feb 24, 2016 at 3:02 PM
    #1311
    2ndGenJonny
    Jon
    Gilbert, AZ
    When I had my Icons and I was trying to get info from them i couldnt get the same answer twice. It was very frustrating. Now that ive jumped ship to a custom valved King I see such a difference. But i cant judge a off the shelf Icon to a custom valved anything, that wouldnt be fair.
    I guess what im saying is that therr is a whole better world of shock performance once you start to get into the guts and start changing shims. I think its worth the research since youre going to be in there anyways and who knows, you coukd love them even more after a full rebuild like that.
  12. Feb 24, 2016 at 3:03 PM
    #1312
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i know my rebound could be a lot better. I basically landed twice on my jumps in pismo.
    2ndGenJonny[OP] likes this.
  13. Feb 24, 2016 at 3:50 PM
    #1313
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Better jump on here before Jberry shows up and :smash:
    A longer spring of the same rate will not affect pre load or anything else for that matter at all. The only thing a longer spring will do is cover up threads at the top of your shock body. You will still have to pre load the longer spring the same amount to hold the front end up where you want it...so technically it is a waste of money. Take your springs off, sandblast and repaint.
  14. Feb 24, 2016 at 3:51 PM
    #1314
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    I welcome the JBerry rage, if i learn from it then im good to go.
    What you're saying makes sense. Spring rate is spring rate.
  15. Feb 24, 2016 at 3:57 PM
    #1315
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    If you are going to get new springs get Eibach...a spring is a spring is a spring but for some reason they feel mo betta ...might be a mental thing because of the price tag but for real...they feels sexy
  16. Feb 24, 2016 at 4:37 PM
    #1316
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Sam, IMO you need valving changes, not spring rate or length changes. @LTDSC
    LTDSC likes this.
  17. Feb 24, 2016 at 6:32 PM
    #1317
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    That sucks. Seems like a good time for a medium sized UPS to cover the gap.
    Although today is not usual weather.
  18. Feb 24, 2016 at 6:52 PM
    #1318
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    This. My severely limited grasp of valving told me at least rebound needed to be reduced a little. Although new springs could help a little depending on how used the springs are.
  19. Feb 24, 2016 at 7:09 PM
    #1319
    lockwire24
    lockwire24 Well-Known Member
    Mark
    Vancouver
    2012 MG DBL cab LB TRD sport
    Cobra CB, Firestik II w/ Relentless hood mount, 4x Innovation sliders, Level 8 tracker pro, TRD exhaust, home made grill insert, Leer XR, led bed lights, King shocks, LR uca, Pelfreybuilt front/rear bumpers and skid plates, B.A.M.F. rear shock relocate.
    No, just dakars with the add a leaf to make it HD. Also, I forgot to mention LR uca's and Wheeler's rear bumpstops.
  20. Feb 24, 2016 at 10:22 PM
    #1320
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I was going to rebuild my icons and replace the springs since they have 80000 miles on them. Should I just get the same ones that are on it? 13" 650# or do they come stock with 600#? Keep getting different answers. And should I buy from Icon or get some king or eibach springs?
