Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Feb 29, 2016 at 6:30 PM
    #1401
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    Just dropped the icons off for rebuild. He's going to mess with the valving for me a bit after telling him my concerns and driving patterns and showing him my Pismo videos. He just did something similar to his from what it sounded like mine are doing. Should have back end of the day tomorrow.
  2. Feb 29, 2016 at 6:37 PM
    #1402
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I was super happy hitting whoops last weekend after gaining some ride ht by installing some longer shackles. As shocks need rebuilding I am definitely going to adjust valving, but down south motorsports did a damn good job with the valving before I could give any feedback. My problem before was bottoming and bucking through whoops with the rear, but adding that 1.5" of ride ht with longer shackles made a noticeable difference. Gives the suspension more time to do it's job before bottoming. Now just need some air bumps for those bigger hits :D
  3. Feb 29, 2016 at 6:38 PM
    #1403
    HHIRunner
    HHIRunner Former Heep Traitor
    Jake
    ATX
    ‘20 Taco
    Go LT
  4. Feb 29, 2016 at 6:38 PM
    #1404
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    Let me get your routing and account number. Only need it for approx 2.3 min
    Willbeck and 12TRDTacoma like this.
  5. Feb 29, 2016 at 6:42 PM
    #1405
    HHIRunner
    Jake
    ATX
    ‘20 Taco
    We can trade
  6. Feb 29, 2016 at 6:50 PM
    #1406
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Total chaos lower long travel arms cost about 800$ a piece last time I looked, set of Hiemed upper I wanna say are like 700$? Hence I'm building my own for my 3.5", cost of materials is about 200$ for 1" uniball,3/4" rod ends and 1.25" DOM
  7. Feb 29, 2016 at 7:05 PM
    #1407
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    That sounds more like the stock length TC uppers.
    I bought my heimed at 750$ and they are 945$ now.
  8. Feb 29, 2016 at 7:06 PM
    #1408
    Basikbiker
    Trav
    Yea it was more like per arm I think lol
    12TRDTacoma likes this.
  9. Feb 29, 2016 at 7:15 PM
    #1409
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Mine still needs better valving. As my compression is set to 10/12 right now but I think revalving to 15/12 will do the job just fine for the rear as long as I can fit an extra 80-100lbs in the bed (usually an additional spare tire helps). I am running 10" stroke with hydro bumps for the rear as well. What was your valving from DSM if you don't mind me asking?
    I don't think extended shackles would work for me, as I alreasy have a notable amount of rake going on as it is. An extra inch and a half would make it look even more funky.
  10. Feb 29, 2016 at 7:17 PM
    #1410
    Basikbiker
    Trav
    Reduce your rebound dampening....leaf springs are slow droopers as it is.
    I ran 15 comp, 8 reb in my old setup and was pretty dang sweet, running 12-15 comp and 8 reb in my bypasses with the rebound full open .....
  11. Feb 29, 2016 at 7:21 PM
    #1411
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    .012 rebound? When did you get links?
  12. Feb 29, 2016 at 7:21 PM
    #1412
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Really? I would had figured leafs were super quick rebounders so you needed higher rebound settings on the shocks to slow things down. I'll have to give that a shot! Hell I think I still may have 8 rebound discs from fox lying around somewhere. I'll have to look and see if I have 15's for the compression stack.
    llibrm likes this.
  13. Feb 29, 2016 at 7:22 PM
    #1413
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't have links for the rear? Lol.
  14. Feb 29, 2016 at 7:23 PM
    #1414
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Fail. Bushings from leafs slow rebound.
    #pogostick
  15. Feb 29, 2016 at 7:25 PM
    #1415
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Are the stock bushings for the leaf packs garbage or what? I would had always figured the arc of the pack themselves were what either accelerated or slowed the rebound on them.
  16. Feb 29, 2016 at 7:29 PM
    #1416
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    All bushings slow down spring movement. You are sandwiching the pivots with a flexible cushion.
    12TRDTacoma[QUOTED] likes this.
  17. Feb 29, 2016 at 7:30 PM
    #1417
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Learn something new every day. What do you think about the stockers compared to poly replacements? Good as is or would poly be a better fit?
  18. Feb 29, 2016 at 7:32 PM
    #1418
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Quoted you because you seem to have an answer every now n again. What valving would you use for an FOA 14" shock if you were to not run expo but might do the occasional hauling of a trailer like a boat or ATV. Maybe a roof tent in the future. I'm going to do a shackle flip and longer shackles with a mount relocate, and shock mount relocate. Would 5150s be good for a crawler? I'm probably not as hard on my stuff as some members but I rough it up a bit. Also, resi or no resi? How necessary are these.
  19. Feb 29, 2016 at 7:33 PM
    #1419
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    not a clue what valving spec they put in. I'll find out though, if not for you, for my own knowledge. but i'm running the bamf relocation kit and 12" rears, and wheelers bumps. after setting my new shackles at about 1.5" of lift, at ride ht i've got about 6.5 inches of shock shaft showing, so slightly more uptravel than down. but like i said, went through a smaller set of whoops at speed and was super happy
  20. Feb 29, 2016 at 7:34 PM
    #1420
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I don't have a second gen. Nor do I have anything stock in terms of bushings. If it's a loaded rubber bushing, it's only use is in the third gen forum.
    deadhed61 likes this.
