Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Mar 2, 2016 at 6:10 PM
    #1481
    336
    336 Well-Known Member
    Kendrick
    Ashe/Boone
    4x4 6 Speed
    4.56 with manual transmission? Regearing isn't too expensive unless you get air lockers right? Are you guys using ECGS for gears?
  2. Mar 2, 2016 at 6:10 PM
    #1482
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    good to know.. I've been thinking of making the move to 295's myself in the next year or so (hopefully I can make it that long) from my current 285 ATII's.. definitely interested in the regear if you do go that route.. that has also been on the list.
    yes..yes.. you'll do nicely as my guinea pig.. :D
  3. Mar 2, 2016 at 6:13 PM
    #1483
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I am partial to pizza cutters, but that's just me.
  4. Mar 2, 2016 at 6:17 PM
    #1484
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Dude, that doesn't sound like your tires are rubbing. It sounds like your traction control is kicking on in sharp turns causing you to lose some steering. It doesn't happen to me but I read about it and you need to try and recalibrate your VSC.
    Bsheriff11 likes this.
  5. Mar 2, 2016 at 6:19 PM
    #1485
    336
    Kendrick
    Ashe/Boone
    4x4 6 Speed
    How do I recalibrate VSC?? Which is vehicle stability control if i had to guess...?
  6. Mar 2, 2016 at 6:20 PM
    #1486
    deeezy
    Dana
    Hawaii
    I don't have a link to it but ozT has a write up on how to do it. Try search for that thread.
  7. Mar 2, 2016 at 6:20 PM
    #1487
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    i'll let you know how my regear goes. ordered my 4.56's from ecgs with my tax return. only running the 285's as of now, but the potential for 35's in the future. I wanted to go with 4.33's since they would theoretically better suit the 285's, but they don't offer them for the front diff. hopefully they get built this week and ship out so I can get them installed within the following week or two. I've noticed the continuing loss in power throughout my build, even with the s/c, but especially being up at 7k foot in flagstaff. hoping to get some of that back :burnrubber:
  8. Mar 2, 2016 at 6:27 PM
    #1488
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    nice! ok.. I will definitely be keeping a look out for your feedback then.
  9. Mar 2, 2016 at 6:30 PM
    #1489
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    This.
    It happened to me a good bit until I put the stiffer 700# coils on. Once when I did my most recent alignment, hasn't happened in a few months though. I took it to a dealer to zero out the VSC before the spring swap but I think it gets recalibrated after alignments?
  10. Mar 2, 2016 at 6:33 PM
    #1490
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    and if I get lazy over the next few weeks and you don't see anything, just pm me and start asking questions. I try to keep up to date on stuff, but nobody's perfect
  11. Mar 2, 2016 at 6:44 PM
    #1491
    336
    Kendrick
    Ashe/Boone
    4x4 6 Speed
    r
    Thanks for the info guys. Definitely checking into it come daylight. Can I do it myself or does it need to be taken to the stealership?
  12. Mar 2, 2016 at 6:45 PM
    #1492
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Not unless you have the appropriate tech stream software.
  13. Mar 2, 2016 at 6:45 PM
    #1493
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    will do man. I hear ya on that tho. Have a Prinsu rack still sitting in the box along with some lighting. procrastination.. ok maybe laziness.. is a sonofabitch.
  14. Mar 2, 2016 at 6:53 PM
    #1494
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    hey, life is f*cking busy, no way around it, and it's a fully acceptable excuse as far as i'm concerned
  15. Mar 2, 2016 at 7:29 PM
    #1495
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Haha probably sometime this year. Its not enough of a power loss to put regearing at the top of the lost, but its right under LT install, so Id say 6 months or so. Dual lockers, 4.56, the works. Dew it. I like the 295s, they fill the wheel wells perfectly, a bit of rub on the very back where the fender flares are, but gives me hope since my cab mount chop is a good inch behind those and I'm just barely rubbing the flares. (Glass is en route, booya). I figure get at least a good 30k-50k on the AT2s and then go for some 315s and see how I like them :). Supposedly 4.56/6 speed/35s is the sweet spot for OEM power
  16. Mar 2, 2016 at 7:30 PM
    #1496
    VolcomTacoma
    Jeff
    NorCal
    and thats why when I saw you climb that trail with a little bit of slipping I wasn't as scared :rofl:
  17. Mar 2, 2016 at 7:33 PM
    #1497
    VolcomTacoma
    Jeff
    NorCal
    Preachin' to the choir here, I literally have a 6' x 5' shelf in the garage just packed full of boxes for shit i need to install. Then I have to babysit, or do something with the dog, or go back to work, or omg. Someday I'll have a full free weekend with nothing planned and get proactive and install some shit
  18. Mar 2, 2016 at 7:37 PM
    #1498
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Right, because the extra inch helped you SOOOOoooo much. :rofl:
    It's not about the size, it's about the motion of the ocean. ;)
    This is also why I don't rock crawl and overland. Lol.
  19. Mar 2, 2016 at 7:38 PM
    #1499
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    f*ck you're doing better than me. well at least you got parts sitting around. I miss having money to throw at the truck. went from making 45k a year to 10k and being a student. but tax return finally made regearing an option. though still a long to do list for the truck
  20. Mar 2, 2016 at 7:38 PM
    #1500
    VolcomTacoma
    Jeff
    NorCal
    Well, yea it actually does lol, my tires are wider, and have much more aggressive tread. Sooooooo yea.
