Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Mar 9, 2016 at 2:25 PM
    #1641
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Ahh, my mistake.
    deeezy[QUOTED] likes this.
  2. Mar 10, 2016 at 5:19 AM
    #1642
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
  3. Mar 10, 2016 at 6:12 AM
    #1643
    Arcticelf
    Gladiator
  4. Mar 10, 2016 at 6:16 AM
    #1644
    spithead051
    Patrick
    Fairfax, VA
    That is correct, bought the standard length shocks while I was out of country after being told they would fit and guess what.... They don't, have about 3/4" of down travel from resting height.
  5. Mar 10, 2016 at 7:13 AM
    #1645
    Arcticelf
    Gladiator
    Then no upgrade for me. I have the icon smooth body 2" rears, but longer to work with Dakars. I'll dig for the PN is you want.
  6. Mar 10, 2016 at 7:21 AM
    #1646
    spithead051
    Patrick
    Fairfax, VA
    Once these sell I'm ordering a set of the 2.5's from DSM that are custom built for the Dakar's. Thanks for the offer though!
    Sadly it looks like selling these will be easier said than done.
  7. Mar 10, 2016 at 8:27 AM
    #1647
    Arcticelf
    Gladiator
    Can you return them? Paying a restocking fee might be easier than selling them.
  8. Mar 10, 2016 at 8:30 AM
    #1648
    spithead051
    Patrick
    Fairfax, VA
    Reached out to the vendor and haven't gotten a response yet. Considering they were ordered in December they may not be willing to take them back.
  9. Mar 10, 2016 at 7:39 PM
    #1649
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    What's everyone's favourite tire deflators and inflators?? Looking to get some when I get my air compressor just not sure what ones to get!?
  10. Mar 10, 2016 at 9:15 PM
    #1650
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Staun deflators are awesome. I love mine. Screw all 4 on, walk around the truck for a minute and then unscrew when they are done
  11. Mar 10, 2016 at 9:21 PM
    #1651
    kaptankaos
    kaptankaos Well-Known Member
    Martin
    Killeen, TX
    09 Prerunner
  12. Mar 10, 2016 at 9:26 PM
    #1652
    VolcomTacoma
    Jeff
    NorCal
    Yeah I've had a couple things like this, no offense, but when I was being cheap lol. Then I said F it and got the Stauns. You can set what pressure they deflate to, and then its just screw on and wait for air to stop coming out. No more having to pull it off, check pressure, put it back on, pull it off, oh youre close, use a screwdriver to bleed the rest.
  13. Mar 10, 2016 at 9:34 PM
    #1653
    kaptankaos
    Martin
    Killeen, TX
    09 Prerunner
    You can check the pressure with these on but being able to set it right of the back is definitely way more convenient!
  14. Mar 10, 2016 at 9:59 PM
    #1654
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    Man those are expensive 108$ canadian for them on Amazon :eek:
  15. Mar 10, 2016 at 11:37 PM
    #1655
    Mr.PowerTrays
    Mr.PowerTrays Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
    how long does the stauns take?
  16. Mar 11, 2016 at 3:23 AM
    #1656
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    I just use a Currie deflator. Its simple and works well. I also had a guy at Discount Tire give me a stem torque screwdriver also. This is more for piece of mind knowing you got the stem back in tight.
    Ive used the staun deflators and they are cool. You will have to set them up on a spare tire to get the psi you want 1st. This is the part that deterred me (and the 85$)
    My Currie was 30$ and has been perfect for many years.
  17. Mar 11, 2016 at 5:11 AM
    #1657
    VolcomTacoma
    Jeff
    NorCal
    Yeah but buy once cry once. Spent way to much time bending over trying to get the right pressure
    From the time I screw the first one on to when I'm taking them off, maybe 5 minutes TOPS. Each tire takes maybe 2-3 minutes to deflate. Mine came preset at 18 psi. They're super easy to set. You can do it on any trail pretty quickly. Hell I did on a camping trip a few months back. I let someone else use them and somehow they had unscrewed the set ring and caused one of them to lose the 18 psi setting. I just lined them all up, set the loose one at the same height as the others, tightened them all down just to be sure, threw it on the tire for a quick test and it didn't even open up. Good to go! Theres no need to drain a spare for these, you can literally just set it on the first tire you want to air down and just play with the set screw as it airs down until you're where you want to be, then just set the others at the same set ring height. Bam.
    goblue82 likes this.
  18. Mar 11, 2016 at 5:18 AM
    #1658
    goblue82
    goblue82 Well-Known Member
    The Dude Abides
    Southern California
    Click muh sig
    Link to these doohickeys?
  19. Mar 11, 2016 at 5:52 AM
    #1659
    VolcomTacoma
    Jeff
    NorCal
    Shitty internet at work, just go to Amazon.com and search for 'Staun Tire Deflators'
  20. Mar 11, 2016 at 5:53 AM
    #1660
    VolcomTacoma
    Jeff
    NorCal
