Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Mar 11, 2016 at 6:43 AM
    #1661
    HHIRunner
    HHIRunner Former Heep Traitor
    Jake
    ATX
    ‘20 Taco
    I use the ARB deflator, same thing as the Currie one. I like it and it works well but takes a little longer than the Stauns since you can only do one tire at a time
    ckeene9 and 2ndGenJonny[OP] like this.
  2. Mar 11, 2016 at 6:53 AM
    #1662
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Seeing that most TW mees to wheel there is always someone late (shit happens) we usually tag team the trucks and get it done quick.
    The stauns are cool once they are set tho.. But not 80$ cool. Ill stand and watch my Currie, it only takes a few min.
  3. Mar 11, 2016 at 6:57 AM
    #1663
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i've never had good success with the tire deflators. They usually take too long and are slower than what i can do myself. I usually just use my stem wrench and twist the stems out a bit on all 4. Once they air out a bit i tighten them up and check them. After a few times ive gotten pretty good with knowing when to pull it. This last trip to Pismo it took me 5 min to go around and air down.
  4. Mar 11, 2016 at 7:03 AM
    #1664
    HHIRunner
    Jake
    ATX
    ‘20 Taco
    I always wheel with my dad and end up having to do all 4 of mine and all 4 of his while he BS's with whoever so it's kind of a pain but it's nice because I can have us at different PSIs without having to fiddle with the Stauns
  5. Mar 11, 2016 at 12:13 PM
    #1665
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    how often should you change out the upper arm bushings? Mine dont appear damaged but they creak and make a ton of noise. They're greased heavily and properly with the bolt loose and then grease and tighten. Curious if my bushings are just shot.
  6. Mar 11, 2016 at 12:13 PM
    #1666
    la0d0g
    running for the hills
    For crawling not hauling
    When I go wheel I'm relaxing so I DGAF if it takes a couple minutes longer with the currie. Same thing goes for airing back up, I choose a compressor over CO2.
    tacomgee and deadhed61 like this.
  7. Mar 11, 2016 at 12:28 PM
    #1667
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Everything suspension aftermarket makes noise.
  8. Mar 11, 2016 at 12:28 PM
    #1668
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    driver side is dead silent.
  9. Mar 11, 2016 at 12:29 PM
    #1669
    VolcomTacoma
    Jeff
    NorCal
    How many miles? How long have they been on? Any rust or pitting on the uniballs? How tight are the UCA bolts? Too tight and they will make the shit creak. To loose and it can bang around a bit and wreck the bushings.
  10. Mar 11, 2016 at 12:30 PM
    #1670
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    roughly 20k miles.
  11. Mar 11, 2016 at 12:32 PM
    #1671
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I had to actually take the bushings off, clean, grease real good, and reinstall them to get mine to stop creaking. Even though I loosened the bolt to grease them through the zerks, some parts of the bushing weren't getting grease because it still had pressure on them from being a tight fit in place.
    LTDSC[QUOTED] likes this.
  12. Mar 11, 2016 at 12:38 PM
    #1672
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    That's weird, I've always been able to fill them until grease spews out from all angles and that's worked so far. Thanks for the reminder too, cause mine just started up, it's grease time for me!
    LTDSC likes this.
  13. Mar 11, 2016 at 12:48 PM
    #1673
    deeezy
    Dana
    Hawaii
    Yeah, inner side of my control arms are pretty tight in place without tightening the bolt. So the inner bushings have pressure on them, the outers don't, so all of the grease from the zerk goes to the outer side of the bushings.
  14. Mar 11, 2016 at 12:53 PM
    #1674
    VolcomTacoma
    Jeff
    NorCal
    Ok so the easy was to do it is to loosen the UCA bolt, squeeze grease out until it comes out everywhere, if your UCAs are too tight, throw a flathead in there lightly and add more grease till it comes out on that side, then do the other side. Sometimes those UCAs are a hair tweaked and fit SUPER tight around the coil bucket. Ive installed a couple, sometimes they just go right on and other times its toit loike a toiger.
    Silver02Taco likes this.
  15. Mar 11, 2016 at 12:57 PM
    #1675
    deeezy
    Dana
    Hawaii
    It ain't that hard to just slide the bolt out and inspect and lube the bushings.
  16. Mar 11, 2016 at 12:58 PM
    #1676
    deeezy
    Dana
    Hawaii
    I can't do that on mine. Too tight of a tolerance. You would end up fucking something up.
  17. Mar 11, 2016 at 1:03 PM
    #1677
    VolcomTacoma
    Jeff
    NorCal
    Then you got a super fucked up set of UCAs and someone had to take a crowbar to get them in. Trust me, you can get a small flat head in there enough to ease a little strain and squirt some grease out.
  18. Mar 11, 2016 at 1:04 PM
    #1678
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't even grease my bushings at all. Lol. They have always been quiet as hell. My balls on the other hand, those know how to squeak CORRECT.
  19. Mar 11, 2016 at 1:05 PM
    #1679
    VolcomTacoma
    Jeff
    NorCal
    It is for some people. You and I might be able to just pop that bad boy off, but I've definitely seen people dry humping the shit out of their fender for 2 hours trying to get a bolt out lol. Much easier to loosen a bolt and squirt some grease. Easy way to tell if your bushings are toast....
    They aren't even anymore (Excessive wear)
    They are bulging like crazy
    They are in pieces
    They are not there
    deeezy[QUOTED] likes this.
  20. Mar 11, 2016 at 1:06 PM
    #1680
    VolcomTacoma
    Jeff
    NorCal
    Damnit Rob. Come over on Saturday, we need to grease your UCAs and get some bushings installed on both trucks :D
