Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Mar 15, 2016 at 4:02 PM
    #1741
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    That answer would surely suffice for most people on this forum... :rolleyes:
  2. Mar 15, 2016 at 4:03 PM
    #1742
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Please refer to the limit strap question. If you have to ask you probably do need them.
    goblue82[QUOTED] and Blackout14 like this.
  3. Mar 15, 2016 at 4:42 PM
    #1743
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Didnt run them on my last build but have them on this one. When I bought my Icons for my 08 I couldnt be sold on resis because I was on a budget and I really wanted TC uppers and lowers.
    With this build I sold off those Icons and all my new OEM parts and was able to buy these Kings used. It was just in my favor that they came with for a great price.
    Can I tell the difference? Yes
    Is it cause the Kings are custom valved over off the shelf valving? Definitely
    Can I tell the resis are there? I honestly cant say yet.
    Ive had the rears on for 3 weeks but its all valving that my ass can feel. Im going to run a longer trail this weekend and see just how different it is. Until i can get these shocks cycling amd heated up for many many miles, Im not sure ill feel the resis. I am however looking fwd to some washboard just so I can see if this flutter stack eats it up like its set up to.
    goblue82 likes this.
  4. Mar 15, 2016 at 4:48 PM
    #1744
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    It all comes down to how you plan to use the truck. Resi's add more fluid allowing a longer time before the shock fluid get hot and you get fade. Mind you it's shaft travel speed that matters and not actual vehicle speed.
    So if you are planning on running the desert over whoops or on roads that are rutted bad or over small rocks that have the shock bouncing up and down the a resi is going to be beneficial.
    If you mostly drive on the free way or you off roading is more forest service roads or slow crawling then you could get away without a resi. Same if you are only going to do fast shaft speed stuff for a short period of time.
    So do you need a resi.....that's up to you and your preferred use of the truck.
    If you ask tacomaworld....it's get resi and might as well get clickers. Or better yet get triple bypasses!
    That's my understanding at least :)
  5. Mar 15, 2016 at 4:52 PM
    #1745
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Resi benefits:
    Increased oil capacity
    Less frequent rebuilds (due to increased oil capacity)
    Shocks are less susceptible to shock fade (due to increased oil capacity)
    Separate nitrogen and oil cavities (resi's have an internal floating piston "IFP" that separate the cavities. This prevents shock cavitation when compared to emulsion shocks. Note that some non-resi shocks can still have an IFP in the shock body itself, but it reduces oil capacity further).
    Allows for clickers which restricts oil flow through the adjuster orifice
  6. Mar 15, 2016 at 5:39 PM
    #1746
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    @12TRDTacoma pretty much nailed it. It all depends on terrain. If you don't see yourself going much over 20mph along fire roads or anything bumpier than that, then you probably don't need them. If you want to go have fun on a slow trail with frequent breaks and difficult terrain, you don't need them. They do allow for a longer rebuild time and such that Jason mentioned, but 90% of TW doesn't need them. If you're flying through the desert or over whups and such, like @12TRDTacoma, then you should probably go get some long travel. :anonymous:
    goblue82 and LTDSC like this.
  7. Mar 15, 2016 at 5:45 PM
    #1747
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So what I basically got out of that post was… oil capacity. :D
    Or not and say I did. :D
    Mr.PowerTrays likes this.
  8. Mar 15, 2016 at 5:46 PM
    #1748
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh hey speaking of which @VolcomTacoma. I got my poly steering rack bushings and the Supermoto/Bonzen poly motor mounts arrive tomorrow!
  9. Mar 15, 2016 at 5:48 PM
    #1749
    VolcomTacoma
    Jeff
    NorCal
    12TRDTacoma[QUOTED] likes this.
  10. Mar 15, 2016 at 5:49 PM
    #1750
    VolcomTacoma
    Jeff
    NorCal
    NICE. I need to install my cab and rack bushings and then order the trans mounts. I dont want to just install motor mounts and let the trans wobble all around.
  11. Mar 15, 2016 at 5:57 PM
    #1751
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I still gotta do my remaining 4 cab bushings as well They have been sitting in my toolbox for something over a year now. They just look a little excessive to do work wise and I don't got the time to be doing all that.
  12. Mar 15, 2016 at 6:09 PM
    #1752
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    If you want to do limit straps maybe we can get a mod day together and do several sets. I need to install them, and re-boot my CVs.
    Blackout14 likes this.
  13. Mar 15, 2016 at 9:40 PM
    #1753
    goblue82
    goblue82 Well-Known Member
    The Dude Abides
    Southern California
    Click muh sig
    Very good knowledge. You guys are great. Thank you for the knowledge.
  14. Mar 15, 2016 at 9:40 PM
    #1754
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    fawk, this is making me wish i had straps. going to be running my newish setup really hard soon
    LTDSC likes this.
  15. Mar 16, 2016 at 7:39 AM
    #1755
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    they're cheap and easy!
  16. Mar 16, 2016 at 10:09 PM
    #1756
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Dude that's lame. That's not what TW is about. Im headed out to Anza Borrego this weekend if you want to put that +2" kit to work. @Evenflow
  17. Mar 17, 2016 at 7:13 AM
    #1757
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Thanks for the invite but I am headed up to Woodward West in Tehachapi for a BMX event this weekend
    06HAOLE[QUOTED] likes this.
  18. Mar 17, 2016 at 10:15 AM
    #1758
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    BMX event? I wanna go and ride Woodward!
  19. Mar 17, 2016 at 2:15 PM
    #1759
    VolcomTacoma
    Jeff
    NorCal
    I used to have the same clunk with my TC uniballs going in reverse. It's something to do with the Uniballs binding IIRC. It happened maybe 1 in 5 times going in reverse to forward, and bugged the shit out of me, and then when I crawled underneath, everything was tight as can be and nothing was out of place. I just wrote it off as aftermarket suspension and checked tightness more often.
  20. Mar 17, 2016 at 2:35 PM
    #1760
    VolcomTacoma
    Jeff
    NorCal
    Easy fix for that, tighten your cam bolts. Shit I watched my last alignment a few weeks ago and the dude basically hung on the 2 foot breaker bar (he was a really short Asian dude lol) to get them tight. I was ok with that. Alignment seems fine still after a trip offroad.
