Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Mar 17, 2016 at 3:59 PM
    #1761
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    mine click/pops about 7/10 backing up. I honestly think its these shitty moog TREs. Or the uniball, everything is tight like a toiga.
  2. Mar 17, 2016 at 4:03 PM
    #1762
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You got a new setup? Pictures or GTFO Jay!!! :D
    Not easier than bolting the two eyelets up. ;)
    I think it actually has to do with a shoddy overall design which has a lot of sloppy tolerances built into it more than anything else. I have been chasing noises for a long time and sort of just gave up as everything is ridiculous tight.
  3. Mar 17, 2016 at 4:20 PM
    #1763
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You might want to try dousing your uniballs with the teflon spray. I have had instances where mine were so dry they were making odd noises due to insufficient lubrication. You would be surprised how many odd noises they can make.
  4. Mar 17, 2016 at 4:44 PM
    #1764
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I wouldn't even bother with that. What kind of control arms are you running?
  5. Mar 17, 2016 at 4:56 PM
    #1765
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Fk uniballs. They are fine. Don't replace them, like I said just lube the shit out of them. When is the last time you did? I ran mine dry for a long time and then they started freaking out making noises similar to yours because they were dry for so long.
    Bathing them in teflon fluid and flexing it tons of times (over the course of a few days actually) made the noises go away in time and now I lube them up once every 3 months or if I am feeling lazy, every 6 now.
    2ndGenJonny[OP] likes this.
  6. Mar 17, 2016 at 5:16 PM
    #1766
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    How did you guys have your exhaust rerouted? Extend it to go behind the transfer case is the only way I can see doing it.. Having mine done next week
  7. Mar 17, 2016 at 5:22 PM
    #1767
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    I need to get emissions tested every 3 years :mad:
  8. Mar 17, 2016 at 5:28 PM
    #1768
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Dude the Y pipe is so easy to swap out. Ive got the URD Y pipe as well with the stock one sitting on the shelf. 10 minutes easily. Its 6 bolts and the URD falls right out, then the stock one takes a hair of finesse to wiggle it in over the crossmember. Swapping them the first time took me maybe half an hour
  9. Mar 17, 2016 at 5:38 PM
    #1769
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    I'm in college and don't have room to keep it around, I'm not pre running at all and don't need that extra little bit of power, and it's 4x the price of a reroute. It would be nice to have that extra bit of power but don't need it.
  10. Mar 17, 2016 at 5:39 PM
    #1770
    VolcomTacoma
    Jeff
    NorCal
    :shrug: oki doki.
  11. Mar 17, 2016 at 6:54 PM
    #1771
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh well hell. You are good to go then.
  12. Mar 17, 2016 at 7:20 PM
    #1772
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Yup. Around the back of the tcase. Then just added a y back into stock. Can try to get a pic tomorrow if ya want
  13. Mar 17, 2016 at 7:25 PM
    #1773
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    That'd be awesome thanks! No hurry, not getting done until next Tuesday.
    tacomgee[QUOTED] likes this.
  14. Mar 17, 2016 at 7:31 PM
    #1774
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Mine isn't re-routed and they are all mounted :anonymous:
  15. Mar 17, 2016 at 7:32 PM
    #1775
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Is it touching or really close then?? :confused:
  16. Mar 17, 2016 at 7:36 PM
    #1776
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Oh it's touching, haha
  17. Mar 17, 2016 at 7:36 PM
    #1777
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    I just had them put in a flat pipe and move it up a bit. Super cheap and easy. :notsure:
    goblue82 and G.T. like this.
  18. Mar 17, 2016 at 7:38 PM
    #1778
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Haha You rattle can or PC your skids?
  19. Mar 17, 2016 at 7:39 PM
    #1779
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    We thought about that but I thought it might restrict flow a little?
  20. Mar 17, 2016 at 7:39 PM
    #1780
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Rattle can. Too cheap to pay for powder coating.
