Mid Travel kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTNROMR, Sep 26, 2014.
  1. Sep 26, 2014 at 1:19 AM
    MTNROMR
    MTNROMR [OP] Well-Known Member
    Cy
    Jackson, CA
    2014 TRD Sport DCSB 4x4
    Build thread in signature.
    I was looking at maybe doing a Mid travel Icon shock, but I heard that you only gain an inch of travel. Is this even worth it? I do light off roading,so would a stock travel icon shock be better for me. If I only lift m truck to 2.5" and used stock travel I wouldn't need new UCA's, right? or would the truck sway all over the road. I want a great ride lift, but don't really want to do UCA's just for 1" more of travel due to my 100,000 mile warranty. Thank you for your help!
  2. Sep 26, 2014 at 1:30 AM
    bigtaco06
    bigtaco06 Well-Known Member
    Jared
    Nor-Cal
    13 TRD OR DBCB SB
    Floor mats, shorty antenna, brute force hybrid front bumper, ICON stage 3, method double standards, 285/75/16 KM2's, cool stickers
    It's worth the extra wheel travel. That 1 inch translates to much more droop than you would expect in actual wheel articulation. When I installed my kit I was suprised at how much more my front suspension would droop down opposed to stock. I have to stick a piece of 4x4 lumber on top of a normal floor jack to just get the tires off the ground.
  3. Sep 26, 2014 at 1:38 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What he said. ^^^
    Do the UCA. You will be happy with the increased droop, improved ride quality, and the additional caster adjustment that you will be able to get out of it over the stock one.
  4. Sep 26, 2014 at 4:03 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Just like holding a stick in your hand. The closer the stick is from your hand won't move as much. But towards the end of the stick, it moves almost a foot.
  5. Sep 26, 2014 at 4:04 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Not saying you're goijg to get another foot of travel. Lol but it does add up
  6. Sep 26, 2014 at 11:08 AM
    MTNROMR
    Cy
    Jackson, CA
    Does a mid travel extend the wheels out of the truck further like having a negative offset wheel? I wonldnt need glass fenders correct?
    Also, I decided to go Icon mid travel and LR UCA's. I figure even if warranty dosent cover it, no touch can go wrong with a 3" lift. Right? Thanks for the help!
  7. Sep 26, 2014 at 11:52 AM
    MTNROMR
    Cy
    Jackson, CA
    Also, If I just do 2.5" of lift and also add a diff drop, would my CV boots leak or any other complications? thank you
  8. Sep 26, 2014 at 10:20 PM
    bigtaco06
    Jared
    Nor-Cal
    13 TRD OR DBCB SB
    "Does a mid travel extend the wheels out of the truck further like having a negative offset wheel? I wonldnt need glass fenders correct?
    Also, I decided to go Icon mid travel and LR UCA's. I figure even if warranty dosent cover it, no touch can go wrong with a 3" lift. Right? Thanks for the help!"
    You will not need fiber glass fenders. You will have the same range of articulation as stock except the wheels will droop lower because the extra length of the shock. The wheels will not compress any higher due to the stock bump stop position.
    The only way you will have rubbing issues is if you have go with a wheel with more backspacing and/or a bigger tire such as a 285. If you find a shop that can set the alignment right you will be fine. It took 2 trys for me to get my alignment right. I took it to a Toyota dealership and they set it to stock specs which is fine but you will rub with a bigger wheel and tire combo. Then, I took my truck to a Americas Tire and I guy that understood uniball UCA knew how to adjust my my alignment to get it right. No rubbing and the truck rides smoother than stock.
    I wouldn't worry about the warranty. The only thing you will be voiding is the suspension components and maybe a little bit of the drivetrain components such as CV axles. To be truthful, in the event you do have issues a dealership is going to point at the lift and say "that's why.
    If you do your homework and know what you are talking about mechanically they can't touch you. Unless your lift actually caused said damage. Do you your homework and be educated to what you are doing to your truck and you shouldn't have any issues.
    Most guys will tell you not to go over 2.5 inches. I'm just under 3" but,I wouldn't go over 3". That's what the upper control arms are for is to be able to get the truck into alignment over 2.5'' becuase you lose caster.
    As far as the Cv boots, the beauty in adjustable coilovers isyou can fine tune your ride hieght. I jacked the truck up and slowly adjusted my CO's just enough to where I got the ride hieght I wanted but the CV boot fins where not touching. I would let the truck settle then adjust. As long as the fins on the boots aren't touching you will be fine. I'm right under 3''.
    DistortedAxis likes this.
  9. Sep 27, 2014 at 10:10 AM
    MTNROMR
    Cy
    Jackson, CA
    Thank you!!! Now with upper control arms should I get uni ball. I don't plan on beating my suspension. Lol
  10. Sep 27, 2014 at 11:24 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah, just get the uniball ones. They cost a little more but they are of higher quality then ball joints. The only thing is that they are not as maintenance free as ball joints because they are exposed to the elements where as the ball joints are sealed in a rubber boot encapsulated in grease.
    Seeing that you live in Sac, you might as well get the Uniball, even if you go up to Tahoe every here and there just wash your undercarriage as I would expect you would anyways and spray out your wheel wells as well. Every here and there a spray of teflon spray on the ball itself and that's all the maintenance you will ever have to do.
  11. Sep 28, 2014 at 9:51 AM
    MTNROMR
    Cy
    Jackson, CA
    I actually live in Jackson about an hour from Sac, but do the uniball uppers make a lot of noise. I heard that was the down fall...
  12. Sep 28, 2014 at 12:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you run them dry, yes they will. Make sure you get uppers that have zerk fittings on them on the bushing side so you can grease them up every so often. That will be able to keep them noise free. As for the uniball making noise, like I said, a quick blast of Teflon spray and you are set to go. Super simple.
    I wouldnt worry about squeaks for a long time after the initial maintenance you give them, being you don't live in a salty area or have to deal with the ocean bearing salted wind of an area of, oh let's say Pacifica or Santa Cruz.
    Get Total Chaos, or Dirt King. They both have zerks on them. Dirt King is cheaper priced, it's what I have on my truck and it just screams quality.
  13. Sep 28, 2014 at 3:57 PM
    MTNROMR
    Cy
    Jackson, CA
    I may just end up doing total chaos and some external resi extended travel icons. I will be moving up by Oregon Coast, so I hope that isn't bad
  14. Sep 28, 2014 at 4:03 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    the down south motorsports uca's by desert products are awesome, mine have never squeaked and they also have zerks. send them a pm on here and they'll most likely hook you up.
    *but all of them are great, essentially the same stuff different companies. except camburg which uses a 1.25in uniball i believe.
  15. Sep 28, 2014 at 4:05 PM
    That1guy108
    That1guy108 What's a title?
    Josh
    Colorado
    2010 DCLB Sport 4x4
    Full OME Kit, Level 8 MK6 Wheels wrapped in 255/80/17 Cooper Maxxs, NWTI Plate Bumper, Flowmaster 40 muffler, Smittybilt X2O 10K winch.
    Not looking to thread jack you here OP, this is just very helpful as Im looking for the same as you right now.
    Since Im on the coast and deal with the salty winds, should I not go with the unibal? Also sometimes I end up balls deep in water or mud on trails so would that be hard on them too?
  16. Sep 28, 2014 at 4:12 PM
    G8keepr
    G8keepr Well-Known Member
    Rich
    North central mass
    2017 TRD OR
    Why not get icon uca's also? I put anti seize on bushings during install and no squeaks in 15,000 miles. Plus you can get a package deal.
  17. Sep 28, 2014 at 4:24 PM
    TaylorU
    TaylorU KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    Can you explain how to check the fins on the CVs or show what to look for? Pictures would be great. Or if this is already available elsewhere, a link would be great. I tried searching with no luck.
  18. Sep 28, 2014 at 4:28 PM
    G8keepr
    Rich
    North central mass
    2017 TRD OR
    Get under front of truck. Look at CV boots and you will know if they are touching or not. Very simple.
    Bird33 likes this.
  19. Sep 28, 2014 at 5:22 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Just take a look at them every once in a while. If you like to wheel, you should be looking at your rig and maintaining it anyways. It's not a big deal honestly.
    You sir are correct. It just depends if the OP is looking for the boxed look or the tubular UCA look. They are all overkill for our application in honesty, but Camburg does offer a larger uniball. I heard some people do not get a whole lot of alignment out of them (some don't even get any additional adjustment!) though, that's the thing.
    I would actually like to think you are better off GETTING a uniball config, because if you are driving in deep water, the boot for a balljoint setup is not waterproof and you can still seep water into there, which in the longterm could contaminate the grease and cause premature joint failure, with the uniball's they are exposed, so once you are done doing what you need to you could always just wash it all off, clean it then give it a nice spray down of teflon.
    As long as the uniball's are made of stainless steel you are golden, the other balls chrome steel are more prone to rust in your area of living. They are stronger then stainless (even then, stainless steel uni-ball's are super overkill for our application anyways), but not as rust proof.
    Because those cost big La Feria's $$$$ vs. the competition.
  20. Sep 28, 2014 at 10:14 PM
    bigtaco06
    Jared
    Nor-Cal
    13 TRD OR DBCB SB
    When checking CV angles you want to look at the fins on the boot that goes into the front dif because they are more prone to touching than the boot that goes into the spindle.
    I have ICON UCA's and havn't had a single sound from the UCA's. Just keep the uniballs clean and lubed. Be carefull with how much lube you use because it attracts dust.
