Mid travel overland-wheeler build with 35's and BS w/ SAS in the works
Discussion in '2nd Gen. Builds (2005-2015)' started by Acerwin, Nov 4, 2015.
Who's the sexiest?
  1. 2ndGenJonny
    2 vote(s)
    13.3%
  2. TacoFMS
    2 vote(s)
    13.3%
  3. Dan0mite
    1 vote(s)
    6.7%
  4. Sandman614
    0 vote(s)
    0.0%
  5. Chadspride
    10 vote(s)
    66.7%
  1. Feb 3, 2016 at 6:49 PM
    #2881
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Do it! 4lb mini sledge and have your arm ready to swing. Plus a grinder with some good cutoffs to get through the cmc.
    After you get it chopped no reason not to put the 35s on!
    Acerwin[QUOTED][OP] likes this.
  2. Feb 3, 2016 at 7:35 PM
    #2882
    Acerwin
    Acerwin [OP] The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Getting the wheels mounted to the 35's hopefully this weekend. So then all I got to do is install a few things and I'm done for awhile
    Sacrifice[QUOTED] likes this.
  3. Feb 4, 2016 at 6:08 AM
    #2883
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    @Iggy. what clippers did you use to trim your fenders?
  4. Feb 4, 2016 at 6:47 AM
    #2884
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I also have came to the conclusion that when I get a snorkel I'm going to install 2 earth magnets to hold it to the apillar.
  5. Feb 4, 2016 at 7:01 AM
    #2885
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Chandler used sticky tape for the bracket. No scratches or anything and can be removed
  6. Feb 4, 2016 at 7:11 AM
    #2886
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Double sided is that what you mean?
  7. Feb 4, 2016 at 7:12 AM
    #2887
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Yup
  8. Feb 4, 2016 at 9:46 AM
    #2888
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Like edge trip or the clips to attach the fenders?
  9. Feb 4, 2016 at 9:54 AM
    #2889
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Yup its made by 3m used to hold 15lbs on a vertical wall so keeping the snorkel in place is no task. And it has a small layer or foam so it doesn't make any noise from the vibrations :thumbsup:
    llibrm and Iggy like this.
  10. Feb 4, 2016 at 9:55 AM
    #2890
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    I think he's referring to snips/shears
    Acerwin[OP] likes this.
  11. Feb 4, 2016 at 9:57 AM
    #2891
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    The clippers you used to trim where the snorkel is also.
  12. Feb 4, 2016 at 9:58 AM
    #2892
    Iggy
    Northern CA
    Check out the build
    Oh, I need to find where I got those. Google metal nibbler and you can find one that matches my photo. Mine's from Italy I think so I don't know where I bought it.
  13. Feb 4, 2016 at 10:09 AM
    #2893
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Sweet thanks!
  14. Feb 4, 2016 at 12:16 PM
    #2894
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Ok well I may or may not have a custom rear HC in the works :spy:
    Nate87 likes this.
  15. Feb 4, 2016 at 12:41 PM
    #2895
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Get your stuff installed before you order more!?!?! :goingcrazy:
  16. Feb 4, 2016 at 12:43 PM
    #2896
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Haven't ordered yet I have a buddy who makes bumpers and sliders and he's going to do one on mine. And everything except tires are getting installed Saturday
  17. Feb 4, 2016 at 12:44 PM
    #2897
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Oh, well carry on :popcorn:
  18. Feb 4, 2016 at 1:16 PM
    #2898
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
  19. Feb 4, 2016 at 1:28 PM
    #2899
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Yelp haha mine as well...already cutting the front up so why not the back
  20. Feb 4, 2016 at 1:34 PM
    #2900
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Also found out that where I go to do tire and wheels stuff said they don't have a problem setting my castor at 4 degrees...I was worried that they may would have had a problem.
