Mid travel overland-wheeler build with 35's and BS w/ SAS in the works
Discussion in '2nd Gen. Builds (2005-2015)' started by Acerwin, Nov 4, 2015.
Who's the sexiest?
  1. 2ndGenJonny
    2 vote(s)
    13.3%
  2. TacoFMS
    2 vote(s)
    13.3%
  3. Dan0mite
    1 vote(s)
    6.7%
  4. Sandman614
    0 vote(s)
    0.0%
  5. Chadspride
    10 vote(s)
    66.7%
  1. Mar 24, 2016 at 3:30 AM
    #4861
    Acerwin
    Acerwin [OP] The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    I know. I'm going to stick with my dakars now since this shit came up. Cause I was wanting to use this money for full skids but that's not happening now
    Mothman[QUOTED] likes this.
  2. Mar 24, 2016 at 3:44 AM
    #4862
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    I got my bumps and extensions from trail gear for like 50 bucks... how much is your shackle flip gonna run?
  3. Mar 24, 2016 at 3:59 AM
    #4863
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    $220 from sos then gotta get shackles if I read it correctly...
  4. Mar 24, 2016 at 4:45 AM
    #4864
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    ATO... when will you learn? Go with ATO. Then if nothing else run your stock shackles for now to save monies.
  5. Mar 24, 2016 at 4:47 AM
    #4865
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I'm trying. I just saw a few running the SOS so I didn't know. What's the difference between all of them though?
  6. Mar 24, 2016 at 4:50 AM
    #4866
    3milecreek
    3milecreek MtnGoat
    Stephen
    Barnwell SC
    Heavily Modified 94 Yota
    Never the same
    Pretty sure you can run stock shackles on sos flip too but I could be wrong.
  7. Mar 24, 2016 at 5:48 AM
    #4867
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    It's the other way around :D
    scottalot[QUOTED] likes this.
  8. Mar 24, 2016 at 6:46 AM
    #4868
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I wonder where you saw this setup.. :spy:
  9. Mar 24, 2016 at 6:46 AM
    #4869
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    I dont see any issue running stock shackles on the SOS flip. I was thinking if doing that with mine just to lower the stink bug a bit, but its growing on me.
    I just need to drop my carrier bearing about 1.5" to make correct the extra DL angle thats causing a slight vib at launch.
  10. Mar 24, 2016 at 7:14 AM
    #4870
    Mothman
    Advance
    single cab
    2 piece driveshaft problems
    Base Camp likes this.
  11. Mar 24, 2016 at 7:27 AM
    #4871
    2ndGenJonny
    Jon
    Gilbert, AZ
    Very very true...
    Struggle is real
  12. Mar 24, 2016 at 7:52 AM
    #4872
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Uhhh
  13. Mar 24, 2016 at 7:56 AM
    #4873
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Ok so in the next few weeks I'm going to be ordering a shackle flip that reuses stock shackle to give me ~1.25" lift, all pro u bolt flip kit and wheelers super bumps to fix my problem. That seems like the best way after talking with a few people and taking measurements
    GARSHA91 and geekhouse23 like this.
  14. Mar 24, 2016 at 8:09 AM
    #4874
    2ndGenJonny
    Jon
    Gilbert, AZ
    And some new lower mounts or are you counting on the ubolt flip and bump to be enough to stop you from bottoming?
  15. Mar 24, 2016 at 8:10 AM
    #4875
    geekhouse23
    I thought he got the BAMF relocation around Christmas time like a few of us did (myself included) :notsure:
  16. Mar 24, 2016 at 8:16 AM
    #4876
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Won't you have to recycle everything once you put in a shackle flip to verify it is setup properly again?
    The shackle flip is going to effect the lower shock mount too isn't it?
    It's installed already
  17. Mar 24, 2016 at 8:16 AM
    #4877
    2ndGenJonny
    Jon
    Gilbert, AZ
    Right, but the issue is that his lower mounts are too high on the axle right now and not leaving a buffer against bottoming.
    If he puts the all pro flip on he will lift the bump by 1/4" but the wheelers stops are squishy, so im not sure he will still have enough buffer.
    Only one way to find out, measure and cycle it to be sure after the flips are installed. If its still going to bottom, he needs to cut the lowers off and remount.
    Acerwin[OP] likes this.
  18. Mar 24, 2016 at 8:18 AM
    #4878
    geekhouse23
    Ah right I didn't see how they were installed. When I did mine, we left about 2" of shaft exposed when it's fully compressed
  19. Mar 24, 2016 at 8:29 AM
    #4879
    2ndGenJonny
    Jon
    Gilbert, AZ
    Hmm, i had you pegged as a balls deep kinda guy. If i left 2" of shaft my lady wouldn't be happy at all with the 2" shes getting.
    :D
  20. Mar 24, 2016 at 8:35 AM
    #4880
    geekhouse23
    I'd like to say I expected differently but then I remembered is Acerwin's thread and I would just be lying to myself
    :luvya:
