Mid travel overland-wheeler build with 35's and BS w/ SAS in the works
Discussion in '2nd Gen. Builds (2005-2015)' started by Acerwin, Nov 4, 2015.
Who's the sexiest?
  1. 2ndGenJonny
    2 vote(s)
    13.3%
  2. TacoFMS
    2 vote(s)
    13.3%
  3. Dan0mite
    1 vote(s)
    6.7%
  4. Sandman614
    0 vote(s)
    0.0%
  5. Chadspride
    10 vote(s)
    66.7%
  1. May 16, 2016 at 1:31 PM
    #5761
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    New truck = warranty. Take that shit in... :notsure:
    G.T. and scottalot like this.
  2. May 16, 2016 at 1:32 PM
    #5762
    Acerwin
    Acerwin [OP] The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    That's true...I guess they couldn't say anything about me taking off road and beating on some :fingerscrossed:
    JimboAnz likes this.
  3. May 16, 2016 at 1:33 PM
    #5763
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Boots arent covered, its a consumable
  4. May 16, 2016 at 1:35 PM
    #5764
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Fawk.
  5. May 16, 2016 at 1:37 PM
    #5765
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    I got mine from cvj for $115? I think. I posted in my build thread, OEM remans.
    Ha yea right. The dealership here wouldn't do anything about my bad add actuator even when my truck was stock.
  6. May 16, 2016 at 1:38 PM
    #5766
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Fawk x2
  7. May 16, 2016 at 1:41 PM
    #5767
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Boots should still be covered under the 3yr/36k "bumper to bumper" warranty which I'm sure he's still under. As long as they're not dicks, they should cover it.
    My dealership would.
  8. May 16, 2016 at 1:42 PM
    #5768
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    My dealership is cool. I'll see what they say. I'll clean it and see what it looks like after a few days
  9. May 16, 2016 at 1:44 PM
    #5769
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    So I'm guessing that you would expect the dealership to cover new brake pads and rotors if you rode the brakes for the first 20k miles? What about spark plugs? Not being a dick, just trying to explain what category they are going to lump in with.
  10. May 16, 2016 at 1:46 PM
    #5770
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    This is my first new vehicle so idk what exactly is covered and not.
  11. May 16, 2016 at 1:47 PM
    #5771
    2ndGenJonny
    Jon
    Gilbert, AZ
    I did see a local dealer cover the carrier bearing though
    Acerwin[OP] likes this.
  12. May 16, 2016 at 1:48 PM
    #5772
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
  13. May 16, 2016 at 1:49 PM
    #5773
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Seriously? Riding the brakes don't compare to CV boots leaking on a 2015 Tacoma with less than 36k miles. So I guess it's ok for the weather stripping on your windows and doors to leak water after a year since you open and close both the doors and windows regularly?
  14. May 16, 2016 at 1:51 PM
    #5774
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Not being a dick either, just making conversation. If it was a stock Tacoma, I guarantee they'd replace the boots. The hard part will be being assertive enough to get it done with the mods done to the truck.
  15. May 16, 2016 at 1:52 PM
    #5775
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    That's what I'm worried about.
  16. May 16, 2016 at 1:58 PM
    #5776
    TacoFMS
    Justin
    Louisa County, VA
    Weather stripping and seals aren't considered consumables. CV axles, whether just boots or the entire axle is considered a consumable. Not saying I agree just that I have run in to it. Plus he has modified the boot, hose clamp instead of a cv clamp, plus the lift. Just excuses/reasons they will most likely give you.
    Also, ace did you permanent the boot when you slid it? I'm guessing you didn't use the "vibration resistant" clamps? So they may have loosened and allowed the boot to leak grease.
    For the length of time it takes to actually wear through the boots with rubbing fins after a lift versus the large chance you take of them leaking or throwing a clamp after the boot slide mod I am actually a huge opponent of the mod.
  17. May 16, 2016 at 1:58 PM
    #5777
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    That's why I said it depends on if they want to be dicks or not. My dealership would do it without question because I bring all my vehicles there. They won't lie to Toyota or the warranty company for me, but they won't volunteer information either.
    scottalot likes this.
  18. May 16, 2016 at 1:59 PM
    #5778
    TacoFMS
    Justin
    Louisa County, VA
    Never thought you were and totally follow your attempt to further the discussion.
    dan0mite[QUOTED] likes this.
  19. May 16, 2016 at 2:00 PM
    #5779
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Just used a regular clamp. After looking at it again I believe the clamp loosened and caused the boot to leak.
  20. May 16, 2016 at 2:06 PM
    #5780
    2ndGenJonny
    Jon
    Gilbert, AZ
    Im still lost tho...
    Why did you remove the stock clamps?
