Mid travel overland-wheeler build with 35's and BS w/ SAS in the works
Discussion in '2nd Gen. Builds (2005-2015)' started by Acerwin, Nov 4, 2015.
Who's the sexiest?
  1. 2ndGenJonny
    2 vote(s)
    13.3%
  2. TacoFMS
    2 vote(s)
    13.3%
  3. Dan0mite
    1 vote(s)
    6.7%
  4. Sandman614
    0 vote(s)
    0.0%
  5. Chadspride
    10 vote(s)
    66.7%
  1. Aug 25, 2016 at 8:26 AM
    #6981
    Acerwin
    Acerwin [OP] The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    That's how I need mine....also need to hurry and buy rock lights
  2. Aug 25, 2016 at 8:39 AM
    #6982
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    let me know if I can help any more :thumbsup:
    The only thing I would really recommend is to leave your leads long behind the tail light so you can make your crimp connections from the pod to the wiring. you wont have room to feed crimps under the bed rail cap. SO Pod wiring goes in from the top, the your wiring fed in from the bottom, and make your connections behind the tail light.
  3. Aug 25, 2016 at 8:41 AM
    #6983
    cmack
    cmack Well-Known Member
    18 Burrito
    I also have the CBI brakets... it's a little more work. but they look the best IMO... trimming ain't so bad. no one can see the trimming unless the hood is open also.
    plus the CBI guys are solid people
  4. Aug 25, 2016 at 8:42 AM
    #6984
    ChadsPride
    Sponsored by TacomaWorld.com
    You a solid peephole
    cmack[QUOTED] likes this.
  5. Aug 25, 2016 at 8:46 AM
    #6985
    cmack
    18 Burrito
    tanks :homer::dancingbacon:
    ChadsPride[QUOTED] likes this.
  6. Aug 25, 2016 at 8:46 AM
    #6986
    ChadsPride
    :wink:
  7. Aug 25, 2016 at 8:46 AM
    #6987
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this. they are much more solid than the other versions that mount to the hood IMO. and.. they stay put when the hood is up. the trimming isnt a big deal at all either. if you take your time, test fit, cut, test fit, cut, etc.. it can come out clean.
    ChadsPride likes this.
  8. Aug 25, 2016 at 8:48 AM
    #6988
    cmack
    18 Burrito
    don't you threaten me with a good time!
    yep, I took my time trimming and test fitting before I got it where I want. the only word of advice is just be cautious when removing the clip that holds your windshield washer fluid hose. I broke mine, so now I have to hold the line every time I close the hood or else the washer no workie because it pinches..nota big deal, just something to be aware of
  9. Aug 25, 2016 at 8:59 AM
    #6989
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Awesome thanks
  10. Aug 25, 2016 at 9:34 AM
    #6990
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I knew a guy that had Famous Fab and they ended up cracking his windshield because the guys at Toyota didn't know it would hit so they quickly threw open the hood and crack....
    ChadsPride and scottalot like this.
  11. Aug 25, 2016 at 9:38 AM
    #6991
    BYJOSHCOOK
    Josh
    Check Out My Builds
    No not at all, I was simply adding to the fact that CBI are the easiest and best way to get ditch lights
  12. Aug 25, 2016 at 9:40 AM
    #6992
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I was eye balling yours at URE :anonymous:
    scottalot[QUOTED] and ChadsPride like this.
  13. Aug 25, 2016 at 9:42 AM
    #6993
    Spencer97TJ
    Spencer97TJ Well-Known Member
    Spence
    CT
    stock
    My Tacoma should be more like yours :) But, I already built a Jeep that I still have. Hard to justify :(
    Acerwin[OP], ChadsPride and scottalot like this.
  14. Aug 25, 2016 at 9:44 AM
    #6994
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Haha thanks buddy. Mines no where near like a lot of people's on here.
  15. Aug 25, 2016 at 9:45 AM
    #6995
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    @BYJOSHCOOK on your prinsu did you go with the black cross bars or "clear"
  16. Aug 25, 2016 at 9:46 AM
    #6996
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Black, looks better IMO. I'm a fan of contrast tho which is why nothing on my truck is color matched
  17. Aug 25, 2016 at 9:47 AM
    #6997
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I went with clear :anonymous: didn't know if there was a difference besides color
  18. Aug 25, 2016 at 10:02 AM
    #6998
    BYJOSHCOOK
    Josh
    Check Out My Builds
    That's the only difference mainly, but the paint on the black is really hard to mess up. I've thrown kayaks up there and haven't scratched shit
  19. Aug 25, 2016 at 10:02 AM
    #6999
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Also yesterday I did a rubber coating on my fender wells....was needed for a long time now.
  20. Aug 25, 2016 at 1:25 PM
    #7000
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Freshly rubber coated looks so good again
