Mid travel overland-wheeler build with 35's and BS w/ SAS in the works
Discussion in '2nd Gen. Builds (2005-2015)' started by Acerwin, Nov 4, 2015.
Who's the sexiest?
  1. 2ndGenJonny
    2 vote(s)
    13.3%
  2. TacoFMS
    2 vote(s)
    13.3%
  3. Dan0mite
    1 vote(s)
    6.7%
  4. Sandman614
    0 vote(s)
    0.0%
  5. Chadspride
    10 vote(s)
    66.7%
  1. Oct 22, 2016 at 5:04 PM
    #8201
    Acerwin
    Acerwin [OP] The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    I'll have to check them out. I was on there a little ago but only saw a plate to mount them on.
    ChadsPride likes this.
  2. Oct 22, 2016 at 5:06 PM
    #8202
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Thanks buddy and nah just rubbed it down real good with metal cleaner.
  3. Oct 22, 2016 at 5:07 PM
    #8203
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Yeah that's what I was thinking also
  4. Oct 22, 2016 at 5:11 PM
    #8204
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    It's still a tough spot to mount it cause you don't want it underneath to get ripped off when wheeling, I was thinking above or below one of the tag lights but think that may be too far off center. What about just above the plate in that space or would the tailgate hit it when you open it?
  5. Oct 22, 2016 at 5:28 PM
    #8205
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I'll have to check more tomorrow. Might install on my swingout beside the jerrycan
  6. Oct 22, 2016 at 5:42 PM
    #8206
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Oh yeah, forgot about the swingout. And I was gonna ask why you were relocating it. Haha :facepalm:
    Only thing is the wires when you swing it out, unless there is a part that stays put.
  7. Oct 22, 2016 at 6:04 PM
    #8207
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Idk maybe @Bsheriff11 can chime in since he done his not long ago
    SpruceTaco[QUOTED] likes this.
  8. Oct 22, 2016 at 6:07 PM
    #8208
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Wires will come from the passenger side. If you want it on the swingout and centered, you will have to extend the wires.
  9. Oct 22, 2016 at 6:08 PM
    #8209
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Yeah I plan to extend the wires
  10. Oct 22, 2016 at 6:09 PM
    #8210
    TacoFMS
    Justin
    Louisa County, VA
    Then you just need a new bracket.
  11. Oct 22, 2016 at 6:12 PM
    #8211
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Oh yeah that makes sense.
  12. Oct 22, 2016 at 6:18 PM
    #8212
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    What's brackets are need to hold the wire to the swingout?
  13. Oct 22, 2016 at 6:55 PM
    #8213
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I would think you could drill holes at each end of the tube & fish the wires through, that would look clean & protect the wires at the same time.
    ChadsPride and TacoFMS like this.
  14. Oct 23, 2016 at 4:25 AM
    #8214
    TacoFMS
    Justin
    Louisa County, VA
    Millions of options out there. Just choose the one that tickles your fancy. You could even just zip tie it.
    That is definitely an option!
  15. Oct 23, 2016 at 5:00 AM
    #8215
    TacoFMS
    Justin
    Louisa County, VA
    Btw you ever pick up your new fridge/freezer?
    @dan0mite
    dan0mite and ChadsPride like this.
  16. Oct 23, 2016 at 5:33 AM
    #8216
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Not yet been so damn busy with kids and stuff right now
  17. Oct 23, 2016 at 9:43 AM
    #8217
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  18. Oct 23, 2016 at 10:08 AM
    #8218
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Yeah I'm excited for this weekend coming up
  19. Oct 23, 2016 at 10:50 AM
    #8219
    cmack
    cmack Well-Known Member
    18 Burrito
  20. Oct 23, 2016 at 11:00 AM
    #8220
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Nothing to see. I did get my tcase skid installed, bumpstops and u bolt flip kit installed.
    ChadsPride and cmack[QUOTED] like this.
