Mid travel overland-wheeler build with 35's and BS w/ SAS in the works
Discussion in '2nd Gen. Builds (2005-2015)' started by Acerwin, Nov 4, 2015.
Who's the sexiest?
  1. 2ndGenJonny
    2 vote(s)
    13.3%
  2. TacoFMS
    2 vote(s)
    13.3%
  3. Dan0mite
    1 vote(s)
    6.7%
  4. Sandman614
    0 vote(s)
    0.0%
  5. Chadspride
    10 vote(s)
    66.7%
  1. Nov 28, 2016 at 3:05 PM
    #8921
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    The super cool 10.5" out of the 5.7L Tundras?
    ...not that I'm aware of, but super curious.
    ChadsPride likes this.
  2. Nov 28, 2016 at 3:08 PM
    #8922
    Acerwin
    Acerwin [OP] The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Just been thinking. Could sell my e locker rear axle and replace it with a tundra axle since they're known less likely to grenade like ours with a elocker and 35"+ tires. Thinking to get a rear arb locker and rear tundra axle. I emailed ECGS and seeing what they think would be best to do.
    ChadsPride and 4Running Daily like this.
  3. Nov 28, 2016 at 3:18 PM
    #8923
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Anything can be done. Just fab work.
  4. Nov 28, 2016 at 3:40 PM
    #8924
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    If I'm not mistaken I think @Rattletrap66 just installed 14" with his 63's & didn't go though the bed.
    Edit: yep found it.
    https://www.tacomaworld.com/posts/13706137/
  5. Nov 28, 2016 at 4:28 PM
    #8925
    TheNatural
    Fort Nelson, BC
    '12 DCLB
  6. Nov 28, 2016 at 4:32 PM
    #8926
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Tundra axles are 4" wider than ours brahhh.
  7. Nov 28, 2016 at 4:35 PM
    #8927
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Perfect match for your +2 LT?
  8. Nov 28, 2016 at 4:37 PM
    #8928
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    What's wrong with that?
  9. Nov 28, 2016 at 4:37 PM
    #8929
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Yeah but no reason unless you blow up the rear.. only people I've known to blow up the rear:
    A) don't know how to wheel and think speed is the answer for everything
    B) keep the rear locked around tight turns and grenade the gears out of their own stupidity
    C) run 37's combined with answer A and/or B
  10. Nov 28, 2016 at 4:40 PM
    #8930
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    The rear would be 4" wider than the front...
    And I thought you want to "eventually" solid axle? So why not just put a 1 ton rear axle in instead and save Money?
  11. Nov 28, 2016 at 4:42 PM
    #8931
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Even the older model tundras?
  12. Nov 28, 2016 at 4:44 PM
    #8932
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Andrew would prefer to not blow anything up. Hence his re-re-doing things he has not yet done.
    BYJOSHCOOK and ChadsPride like this.
  13. Nov 28, 2016 at 4:44 PM
    #8933
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    10.5" rear Tundra diff is same size as a Dana 60.
    Older Tundras use smaller diffs that prolly aren't worth the trouble?
  14. Nov 28, 2016 at 4:47 PM
    #8934
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    I guess if you want to mismatch axles then go for it. But its still 4" wider than our axles, he'd have to run 2" spacers to even it out
  15. Nov 28, 2016 at 4:47 PM
    #8935
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Thanks. For the info that's all I was wondering as I know some 1st gen tacomas use tundra axles.
  16. Nov 28, 2016 at 4:49 PM
    #8936
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    +2 LT before he goes SAS!!
  17. Nov 28, 2016 at 4:52 PM
    #8937
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Let's all not get butt hurt here
    SC2SC and ChadsPride like this.
  18. Nov 28, 2016 at 5:05 PM
    #8938
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Plus 5 lug, unless you mean first gen tundras
  19. Nov 28, 2016 at 5:06 PM
    #8939
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    That's what I was looking at
  20. Nov 28, 2016 at 5:07 PM
    #8940
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Hey don't taunt me. That's my plan lol back off
