  1. Jan 2, 2022 at 6:13 PM
    bttrbsch
    bttrbsch [OP] Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    The time has come for me to sell various components that were installed on my truck for 7 months and approximately 8,000 miles. During that timeframe, the truck was primarily driven to and from work (it's my daily driver) and the occasional fire service road to go camping. With that said, these components have seen very little use and are like-new.
    Buyers who are local and can purchase multiple components together receive first priority.
    It goes without saying, but all items are discounted, tax free, and there is no lead time or shipping delays.
    Fox 2.5" Extended Travel Coilover with Reservoir and Compression Adjusters for 2005+ Toyota Tacoma (FOX-880-06-418): SOLD
    These front coilovers come with 600 lb. springs. I added factory orange decals and adjustors (I can provide the original yellow adjusters if needed). Comes with all hardware and reservoir mounting brackets. The hose clamps have shrink wrap applied to protect the reservoir body from the clamp biting into it.
    Fox 2.0 Rear shock with remote reservoir and compression adjuster for 05+ Tacoma (FOX-985-26-117): SOLD
    These are the extended version that work hand-in-hand with a 1.5-2" lift in the rear. I used rubber boot covers the entire time these were on, so there are no nicks or wear on the shafts. These have the compression adjustor on the reservoir. They come with piggyback mounts or mounts for the frame. Heat shrink has been applied to the hose clamps.
    JBA STD High Caster Upper A-arms for Toyota Tacoma "05" Plus, 4Runner "03" Plus, FJ Cruisers "07" Plus (JBA-7.0.HC.EZ): SOLD
    Allowed me to attain the high caster target with the lift installed. This is the updated version with the ball joint boots that do not crack.
    HeadStrong 3-Leaf Add-a-leaf for 05+ Toyota Tacoma (HS-TOY516-3AL): SOLD
    As far as I can tell, this 3 leaf AAL is identical to the one that Icon offers. Where as a single leaf AAL relies on the thickness of the leaf and positive arch to gain lift, the 3 leaf AAL accomplishes lift primarily by increasing the thickness of the existing pack. Quality of ride is maintained using thinner leafs which are pyramid stacked. This AAL design turns your factory leaf pack into a performance leaf pack without breaking the bank. The 3 leaf AAL was designed and intended to be used without the overload leafs and will provide approximately 1.5" of lift.
    Headstrong extended U Bolts (HSUB-2580B): SOLD
    I have old HS U-Bolt 9/16 2.5"x8" Black Coating. Has all nuts and washers. Also have the plates that attach to the bolts if needed. Will throw in stock bumps if you like. These U bolts are needed for the AAL.
    Icon Extended U-BOLT KIT (Un-used): SOLD
    https://www.iconvehicledynamics.com/accessory/15574/icon-accessories-toyota-rear-80-u-bolt-kit/
    Archive Garage Limit Strap Mount Tabs (comes with hardware): $25
    Archive Garage Upper Shock Mount Spacers: $10
    Extra Icon Leaf Parts: $10
    I have multiples of these baggies of spare parts, could be helpful for anyone sourcing random parts to assemble a leaf pack.
    Stock Tacoma Leaf Pack and Shackle: $40
    Please feel free to message if you have questions!
    tacoshell88 and uploadadventure like this.
  2. Jan 2, 2022 at 7:32 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
  3. Jan 2, 2022 at 7:45 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I'll take the JBA's if no one has claimed them and you are willing to ship to 87031. You can PM me with what you think
  4. Jan 2, 2022 at 7:54 PM
    OG_Tacoma
    OG_Tacoma Well-Known Member
    Nice ad/post
    GLWS
    bttrbsch[OP] likes this.
  5. Jan 2, 2022 at 7:57 PM
    goonsquad08
    goonsquad08 Well-Known Member
    Michigan
    ‘12 DCLB Tacoma
    Shocks and UCA look excellent. Would likely grab them all if local to me. Getting ready to replace my current shocks. Best of luck!
  6. Jan 2, 2022 at 9:09 PM
    bttrbsch
    Michael
    Bellingham, WA
    If these go unclaimed locally in a couple weeks I'll shoot you a PM!
    boostedka[QUOTED] likes this.
  7. Jan 2, 2022 at 9:10 PM
    delsanchi
    delsanchi Well-Known Member
    2019 Silver AC OR
    Ill take the leafs and rears if no one has yet.
    Edit: if you would like to
    ship
  8. Jan 3, 2022 at 6:20 AM
    boostedka
    James
    NM
    Sounds good
    :cheers:
  9. Jan 6, 2022 at 6:06 PM
    TacoDelcid
    TacoDelcid Well-Known Member
    Freddy
    Winchester, CA
    2017 Tacoma DCSB OR Inferno
    If you decide to ship I’m interested in the coilovers, shocks, AAL and UCA.
  10. Jan 7, 2022 at 10:11 AM
    bttrbsch
    Michael
    Bellingham, WA
    I'll look into shipping rates, will send you a PM!
  11. Jan 7, 2022 at 10:14 AM
    TacoDelcid
    Freddy
    Winchester, CA
    Sounds good!
  12. Jan 7, 2022 at 3:55 PM
    Adrian.Brewster
    Adrian.Brewster Well-Known Member
    Adrian
    2020 trd off road
  13. Jan 7, 2022 at 3:59 PM
    bttrbsch
    Michael
    Bellingham, WA
    Replied!
  14. Jan 9, 2022 at 12:14 PM
    bttrbsch
    Michael
    Bellingham, WA
    The front coilovers, rear shocks, upper control arms, rear AAL, and extended U-bolts have sold. Thanks for the interest everyone!
    goonsquad08 likes this.
