Mid-travel setup
Discussion in 'Suspension' started by RenoTacoma, Dec 25, 2011.
  1. Dec 25, 2011 at 1:39 PM
    RenoTacoma
    RenoTacoma [OP] Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    I have been searching an researching a mid travel setup that will be daily driven.
    I intend to wheel but nothing extreme. I am a little unsure of whats too much for me and whats not enough, I'm also going for the front wider fenders.
    I understand I will need new ucas as I am a 4x4.
    Here my current list
    -Ucas, not sure of what brand will work. I was looking into camburg and spc
    -Coil overs, not sure if Remote Reservoirs are needed also the size?.
    -Wheel spacers, I understand they put more wear on certain parts but I want to be able to fill out the wide fenders.
    -Rear shocks, I have no idea what would suite my needs.
    I am going for a basic mid travel setup that will be daily driven.
  2. Dec 25, 2011 at 1:45 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    If you're going a basic set up you could just do bilstein 5100's with eibach coil overs with 5100 bilsteins in the rear with an AAL. And camburg UCA would work perfect. People in the baja 1000 run wheel spacers, nothing wrong with them.
  3. Dec 25, 2011 at 1:47 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    why do you think you need wheel spacers, what are the current wheels that you have now..particularly the back spacing?
    UCA's come down to what you prefer as they are good quality
    i would suggest in getting front coil overs with a reservoir- at a later time you'll have buyers remorse if you hadn't got them.
    any top brand for the rear, again all good quality. i would recommend something with a reservoir. the rear ends of our taco's needs all the help they can get
  4. Dec 25, 2011 at 2:07 PM
    RenoTacoma
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    I have Trd sport rims I intend to use. I just do not want the fenders not to be filled out.
  5. Dec 25, 2011 at 4:37 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    Just make sure if you get UCA's that you get extended travel coilovers to utilize the extra travel you can get out of the UCA. If you are getting coilovers I would definetly spend alittle extra money for coilover with ressies.
  6. Dec 25, 2011 at 5:17 PM
    RenoTacoma
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    Im currently looking at getting camburg 1" uniball ucas from a member on here
  7. Dec 25, 2011 at 5:32 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    my set up, Icon exteneded travel remote resi's, TC UCA's,
  8. Dec 25, 2011 at 5:50 PM
    atvlifestyle
    Michigan
    01 trd tacoma
    im very happy with my camburgs. I have fox RR but im a first gen.
  9. Dec 25, 2011 at 10:09 PM
    RenoTacoma
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    Ill see if I can get resi's but no guarantee, is there a huge difference?
  10. Dec 26, 2011 at 4:45 AM
    atvlifestyle
    Michigan
    01 trd tacoma
    for high speed yes for anthing else not so much. If you plan on keeping the setup for awhile you are spending enough that for the little added cost its worth it. Also you wont regret not getting ressies the first time.
  11. Dec 26, 2011 at 5:23 PM
    RenoTacoma
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    Is there a limit to how big of wheel spacers I can use until it gets unreliable? I was planning on some 1.5-2 in spacers
  12. Dec 27, 2011 at 11:49 AM
    RenoTacoma
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    bump....
    Im getting some camburg 1" ucas from a member on here :)
  13. Dec 27, 2011 at 12:23 PM
    Sunner
    Sunner Well-Known Member
    You might be ok just going with Supra's suggestion and save ALOT of money if you do not plan on wheelin much, mid travel might be overkill, but it is best to do it right the first time instead of having to do it again, I plan on getting Icon RR ext travel all around with Dakars leafpack and AP 2in Fenders, probably CB UCAs as well. Good luck!!
  14. Dec 27, 2011 at 12:27 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Not sure why you want LT fenders on a MT setup... doesn't make sense to buy spacers just so you can fill out LT fenders....if you had lowers and extended half-shafts it would make more sense...
  15. Dec 27, 2011 at 12:34 PM
    Steezyskis
    Steezyskis I ski I work I'm rad
    Spencer
    Lake Tahoe (west shore)
    Black 05 DC 4x4 sport SB
    Tuff country front bumper, Walker Evans 2.5 coilovers, Allpro 3" rear leafs with 5100s and an Allpro U-bolt flip kit, K&N CAI, 16x8 Raceline raptor wheels wrapped with 285 Toyo ATs, Sockmonkey bed decals, Softtopper camper shell, half debadged with black painted tacoma emblems, B.A.M.F rock sliders, GT covers, BHLM, PIAA lights and more to come.
    Hey sloan If you decide to use wheel spacers i just got new rims and im selling mine. I have a pair of 1.25" hub centric with extended nuts for thicker alloy rims from allpro. Only 2-3k miles of use on em.
  16. Dec 27, 2011 at 12:43 PM
    Steezyskis
    Spencer
    ^^^^ On a side note. I was cleaning shit from christmas and can you guess what I stumbled across?
  17. Dec 27, 2011 at 12:49 PM
    rcfreak201
    rcfreak201 Well-Known Member
    with just coilovers i was rubbing alot while offroading and i know a couple of my buddies are full mid travel and got glass to eliminate rubbing. Its also easier to clear bigger tires. I was able to clear my 35s with a tiny bit of rubbing with my coilovers set at 2.5", afterwards i got spindles which filled in the fenders very nicely.
    i run spacers and it looks wider than the fenders at ride height. Btw im running fiberwerx 6" fenders and i have coilovers, spindles, and spidertrax.
    OP isnt getting 6" fenders im sure hes getting glassworks 4" fenders which are very easily to fill. :cool:
    wheeliest likes this.
  18. Dec 27, 2011 at 12:53 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Makes sense, I've been contemplating 35's myself, didn't realize glass would work for that.
  19. Dec 27, 2011 at 12:54 PM
    RenoTacoma
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    What? :boink:
    I want the wide fenders for looks I will admit it and also for big tires.
    I thought about getting billies but I do plan to wheel. I will also be getting the 4" fenders, 6" would be over kill for what I want to do.
  20. Dec 27, 2011 at 12:56 PM
    rcfreak201
    yeah once i got glass it gave about 1.5-2" of clearance, then i got the cab mount chopped completely and i bearly rubbed at full lock at an angle.
