Mid Travel Shocks/Coils on Stock Arms?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tyler Sexton, Oct 28, 2022.
  1. Oct 28, 2022 at 9:13 AM
    Tyler Sexton
    Tyler Sexton [OP] Well-Known Member
    Tyler
    2004 Silver Tacoma TRD PreRunner
    Tires, bumpers, wheels, intake, extended throttle body and exhaust
    I am looking at the 25001-151-EXT king shocks and coils and it has the option for extended travel on aftermarket control arms (which I do not have) and i wanted to know if they would still work on stock control arms. I do plan to buy mid travel control arms after for these shocks and i plan to buy the CAM-310005 with the kings shocks but leave the control arms stock for now(probably until they break). Will this work?
  2. Oct 28, 2022 at 9:14 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Lower control arms are only needed (and provided) with long-travel kits.
    Mid-travel is simply...a little more shock travel but well within the geometries of the stock arms.
    Your lower control arms will not break.
  3. Oct 28, 2022 at 9:15 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You had a $6k+ budget, stated in multiple threads when you asked about long-travel and all that.
    Why don't you go with a quality set from ADS?
    They'll valve them to your needs as well.
  4. Oct 28, 2022 at 9:16 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I would second going with ADS, King front coilovers for 1st gens, even the extended travel ones are over 3/4" shorter than their ADS counter parts, given the lever ratio thats nearly 1.5" of lost wheel travel.
  5. Oct 28, 2022 at 10:00 AM
    Tyler Sexton
    Tyler
    I´m just looking at all my options and want to see what would be best for me. What ADS should I be looking at that would cost 2k because everything would cost 2k if I went with the kings?
  6. Oct 28, 2022 at 10:24 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You don't really have many options if you went with ADS so I don't know what you're asking?
    Kings would only set you back $1.2k unless you got them with the reservoir so a little more.
    Just call ADS and order via phone; those guys are suspension experts and anything gathered here would be less beneficial to you.
  7. Oct 28, 2022 at 11:12 AM
    Tyler Sexton
    Tyler
    If I got the ADS Shocks 96-04 Tacoma 2.5″ OEM Coilovers which is $500 more then the kings, what are the benefits to getting these, would I get more travel?
  8. Oct 28, 2022 at 11:23 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Those questions were literally already answered in the posts above.
  9. Oct 28, 2022 at 11:31 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
