Mid-Travel: Too much caster?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bttrbsch, Jan 5, 2024.
  1. Jan 5, 2024 at 11:08 AM
    bttrbsch
    bttrbsch [OP] Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    Hi all,
    I'm running a 2.5" lift with aftermarket UCAs (Icon Delta Joint). I've driven my truck with low (~2.5°) caster and know first-hand how squirrelly the front end feels due to angle of the wheels (another thread referenced "shopping cart wheels" and that's an accurate analogy). I am running 4.5° of caster to push the wheel forward from the cab mount and so the truck tracks straight on the highway.
    However, there is now a "dead zone" when my steering wheel is centered (about 15 degrees in either direction). This is due to my wheels being brought forward - think like a mountain bike with slack fork, it requires more input at the handlebars to turn. The bump steer in my truck is quite bad due to the dead zone.
    Now for my question: Is 4.5 degrees of caster too much for a mid-travel setup? Is 3.5° a more reasonable target?
    Appreciate any input.
    71tattooguy likes this.
  2. Jan 5, 2024 at 6:20 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It’s not clear to me that ride height has any effect on the optimal caster. I would just keep it in factory specs.
    Personally, my caster is about 4 degrees, but that is only because the 4x4 shop set it up that way after I asked them to move the wheels forward to solve a rubbing issue.
    drizzoh and Tocamo like this.
  3. Jan 5, 2024 at 10:06 PM
    bttrbsch
    Michael
    Bellingham, WA
    A stock Tacoma with no lift should have a factory spec caster of 1.8-2.5 (or around that range). A lifted truck often requires more caster (and aftermarket UCAs to achieve that higher caster).
    @gudujarlson you're happy with the 4 degrees of caster? No bump steer or "dead" feeling in when the steering wheel is centered?
    Tocamo likes this.
  4. Jan 6, 2024 at 4:21 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    I would certainly bump it down a degree and see where that gets you. My Tacoma is stock but I’ve run nearly 6° in my mid/long travel GX without any weird return to center issues.
  5. Jan 6, 2024 at 6:15 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  6. Jan 6, 2024 at 6:54 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Following....
  7. Jan 6, 2024 at 9:54 AM
    gudujarlson
    Minnesota
    I think you might be misunderstanding what aftermarket UCAs are used for. When a taco is lifted, it loses caster and must be re-aligned to get it back into spec. If the truck is lifted high enough, it becomes impossible to align it back into spec. This is where aftermarket UCAs are needed. Many have 2 degrees of caster built in so that aligning into spec is possible again.
    My truck handles fine with 4 degrees of caster. When I first had it aligned I subjectively felt it took slightly more force to steer, but it was subtle. Now I never think about it. If I get it aligned again, I will tell them to try to keep it within spec while moving the wheel forward for clearance. I’m not sure the tech understood how to adjust SPC UCAs.
  8. Jan 6, 2024 at 8:32 PM
    bttrbsch
    Michael
    Bellingham, WA
    I understand what you're saying, but aftermarket UCA forces caster to become 3.5-4.5 degrees with the build in caster from the component design. In my mind, "spec" is what's recommended from Toyota, which is around 2.5 degrees.
    I digress, it sounds like I should shoot for 3.7ish-4ish degrees on next alignment. 4.5 is pretty dang high and produces bump steer for me.
  9. Jan 6, 2024 at 8:34 PM
    bttrbsch
    Michael
    Bellingham, WA
    Accutune always publishes great tech articles. I replaced my LCAs prior to alignment and slammed them as far forward as they could go. The alignment tech ended with 4.5 degrees of caster. I always thought more caster is better, but am learning there is a sweet spot. Possible to go too high on caster at 4.5 degrees.
    71tattooguy[QUOTED] likes this.
  10. Jan 6, 2024 at 8:37 PM
    AusBerg
    AusBerg Well-Known Member
    Austin
    North MN
    2022 TRD OR DCLB
    im on 2.5 caster and it feels awesome to me, accutune lift with kings here. steering is tight and rail straight going 63.
  11. Jan 6, 2024 at 8:54 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    My caster is around that number as well drives so nice :thumbsup: accutune kings lift over here as well :cheers:
  12. Jan 6, 2024 at 9:24 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Post the numbers from the alignment and has any other work been done other than the UCA's? What wheels (back spacing/offset), tires etc. 4.5 degrees of caster should not be causing what you describe. I would be looking for something else. Depending on your tire size this may be of interest to you. HOWE TC Pump Steering Kit – JD Fabrication Looking at your profile. Are you running 285/70/17 KO2's and the ProComp 7069 wheels? Icon recommends a max of 4.75" back spacing the pro comps have 5.25". I would make sure the tire and or wheel is rubbing any where, especially the UCA. I would also make sure you don't have a tight ball joint.
  13. Jan 6, 2024 at 10:55 PM
    bttrbsch
    Michael
    Bellingham, WA
    This thread seems to be bang-on with my current thought process: https://www.tacomaworld.com/threads/caster-recommendations.730180/
    A member commented that 4.5 was too high and he was much more happy with 3.5.
    @AusBerg @71tattooguy when you say Accutune lift do you have the Icon Delta Joint UCA? I have the Accutune lift package with that as well.....
    @01_dhrracer you are correct with my wheel and tire setup. The wheels do not contact the UCA, I have double checked in the past. LCA ball joint is brand new, I grease the upper ball joint occasionally. I'll get photos of previous alignments uploaded. I still think that remove a degree of caster and setting my alignment at 3.5 might be the golden ticket.
    AusBerg and 71tattooguy like this.
  14. Jan 6, 2024 at 10:56 PM
    bttrbsch
    Michael
    Bellingham, WA
    Pro Comp wheels have 4.75 backspace: https://www.procompusa.com/product-...h-6-on-5-5-bolt-pattern-flat-black-7069-7983/
  15. Jan 7, 2024 at 4:46 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    I’m running dirt king UCA’s
  16. Jan 7, 2024 at 5:05 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    For mid travel 2” lift or higher, 3-4* caster with 3.8* being ideal.
    bttrbsch[OP] and 33yrsoftoys like this.
  17. Jan 7, 2024 at 7:10 AM
    AusBerg
    Austin
    North MN
    2022 TRD OR DCLB
    I have the accutune UCA's
  18. Jan 7, 2024 at 8:27 AM
    gudujarlson
    Minnesota
    Aftermarket UCAs do not force caster to 4 degrees. Caster can still be adjusted without a range of values. Case in point, with my SPC’s I have had 2 alignments, one with 2 degrees and one with 4.
    I had some tire rubbing with the first alignment, so I took it to a 4x4 shop and told them explicitly to move the wheel forward. I think they did that but then didn’t set the SPC into the neutral caster position, so now my caster is out of spec.
    AusBerg likes this.
  19. Jan 7, 2024 at 10:21 AM
    AusBerg
    Austin
    North MN
    2022 TRD OR DCLB
    While I may be wrong please take with a grain of salt, I too agree with gudujarlaon. My thoughts is the aftermarket UCA's allow for greater caster range, not 'forced'. And I thought the biggest advantage for a large caster # is to allow a larger wheel to fit with less cutting, as well as to avoid feeling squirrelly on the road. Which I do not experience at 2.5 degrees. I know I have the ability to go more, but I liked how it felt pre lift at 1.5 degrees so I wanted small incremental changes until I felt it was comfortable to drive.
    Sounds to me you may have some luck dialing the caster back a degree or two, then just see which you like better and go from there.
  20. Jan 8, 2024 at 9:44 AM
    bttrbsch
    Michael
    Bellingham, WA
    @AusBerg @gudujarlson you both are correct, I misspoke when I said aftermarket UCAs "force" caster. They simply open the door to higher caster being achieved.
    Yes, I've made up my mind that ~3.5-3.8° degrees is what I should go with next. 4.5 seems much too high.
    Thanks all!
    AusBerg likes this.
