Mid Travel with BS Thread
Discussion in 'Suspension' started by MightyMouse-SCT, Jan 25, 2012.
  1. Jan 25, 2012 at 4:53 PM
    MightyMouse-SCT
    MightyMouse-SCT [OP] Well-Known Member
    Gabriel
    O'SIDE CA
    MightyMouse-SCT - 2011 LT 4x4 Desert Runner
    Long Travel Total chaos kit, fox shocks, smp fab , dmz sua, glassworks, method wheels.
    Decided to make a thread for mid travel setups . Feel free to ask any questions you might have about products , installation , and performance of a MT setup.
    Member- Gelo760 (me)
    Suspension Mods- Front total chaos stock length upper and lower arms, fox extended travel 2.5" Coilovers with resi. Rear- deaver j66 leaf pack, fox 2.0 piggy back shocks and 2.5" stroke 2.0" fox bump stops with custom mounts and strike pad
    Member- Socalduckslayer (pelfreybilt offroad)
    Suspension Mods- Front King 2.5 RR C/O's w/ 700# springs
    Icon Tubular UCA's
    Rear King 2.0 x 12" RR smoothies
    Rear King 2.0 x 2.5 Bumps
    Member- Bullaculla's Mid Travel Truck
    Suspension Mods- Fox 2.5 IFP extended travel coilovers, Fox 2.0 extended travel FJC rear piggyback shock, Icon 3 leaf progressive mini AAL pack, Total Chaos UCAs.
    Member - Alfuh
    ICON Extended Travel Coilovers
    - Total Chaos UCAs
    - Maxtrac Spindles
    - AllPro 3" Standard Leafpack
    - Fox 2.0 RR 10" Shocks
    Member -Basikbiker
    09 access cab Trd offroad
    King 2.5's coilovers front 650# coils
    Camburg uniball upper arms
    Trailgear limit straps 10"
    TC spindle gussets
    TC cam tabs
    Wheelers superbumps
    Rear:
    King 2.0 12" remote resi
    BAMF Shock towers
    All pro standard springs
    U bolt flip
    Wheelers superbumps
    SOS shackle flip Hangars
    Member- Straycat241
    Parts- airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    Member- 12TRDTacoma
    Parts- running 2.0 Sway Away RR fronts, 14" 650 coils, Fox 2.0 2" air bumps and Dirt King UCA/LCA's. Rear is 2.0 Fox RR currently running Chevy Silverado polyfoam bumps soon to be switched to TC bolt on Fox 2.0 3" air bumps using a Icon U bolt flip kit striker plate, running Deavers F85 1.5" AAL with the overload retained,swaybar removed now
    Jake Denney likes this.
  2. Jan 25, 2012 at 5:05 PM
    YumaTRD
    YumaTRD Chewie is my Co-pilot
    David
    El Cajon, CA hometown Yuma, AZ
    SAS Yota
    SAS, Flat bed, 22R, BFG Muds,
    Cool.
    I'll start.
    Is there a way to get more travel from the rear? What setups/travel numbers have been reached with bolt on upgrades. (springs, extended shocks, shackle flip kit)
  3. Jan 25, 2012 at 5:09 PM
    chris4x4
    chris4x4 With sufficient thrust, pigs fly just fine. Staff Member
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    With a 2.5" front coilover, you arent going to be able to push it hard enough to over heat the shocks, thus possibly needing a remote/piggy back resi. Your more likely to heat the rear shock to a hotter temp than the front.
  4. Jan 25, 2012 at 5:12 PM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    Ha ! Good Post to start off the thread . I'm actually currently interested in that at the moment as well . I currently run a set of fox 2.0 piggy backs with stock leafs . I'm looking into upgrading my leafs to a deaver j66 pack .
  5. Jan 25, 2012 at 5:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I havent been able to compare a piggy back to a remote resi side by side. My set up (Icon 2.5" front, and 2.5" remote resi rears) when pushed as hard as I can, heat up to within 2 or 3* of each other. Im thinking a 2" rear may get about 10* to 15* hotter, given the lower oil capacity, and cooling surface area of the shock body.
  6. Jan 25, 2012 at 5:16 PM
    YumaTRD
    David
    SAS Yota
    I'm about to install the Allpro standard pack this coming week. I'll take measurements of the new shock lenght and leaf droop, It would be good to know what are the average gains from the aftermarket leafs.
  7. Jan 25, 2012 at 5:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    IN a fast off roading, hot environment, I think so. For crawling, and lower speeds, you wouldnt see much benafit.
  8. Jan 25, 2012 at 5:23 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    as soon as $$ comes my way, I'll MT my truck.
    one day..
    subd
  9. Jan 25, 2012 at 5:29 PM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    How about long runs on a offroad terrain where the shock is performing a lot . I'm thinking a resi would come into play there aswell .
  10. Jan 25, 2012 at 5:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That would be under the "Fast off roading) I meentioned.
  11. Jan 25, 2012 at 5:32 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    mine get really hot :anonymous:
  12. Jan 25, 2012 at 5:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Have you taken the temps? 130* can "feel" pretty hot, but its not. You have to get them over 180* or more before you can really feel a performance drop.
  13. Jan 25, 2012 at 5:35 PM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    Does anybody know what are the stock rear travel numbers ?
  14. Jan 25, 2012 at 6:03 PM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    Also in the mix with me replacing my rear leafs is a set of stock length Total Chaos lca's . They are pretty pricey but I'm sticking with my MT set up so I'm heavily considering them . Can either do lca's or j66 leafs at the moment .
  15. Jan 25, 2012 at 6:06 PM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    Might seem like a dumb question to you guys but my knowledge on suspension is limited at best. Whats the up side of having these instead of the stock LCA's?
  16. Jan 25, 2012 at 6:07 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I didnt take temps, but they were hot enough to steam dry and were too hot to touch. This was after using a non-maintained trail for a good 3 hours. Washboard surfaces make me want LT :mad:
    Guess that's not really scientific though...I'll have to bring a laser thermometer next time
  17. Jan 25, 2012 at 6:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, an IR thermo can be much more accurate. Figure water can evap pretty dam fast at 130*. Figure thats halfway to its boiling point.
  18. Jan 25, 2012 at 6:22 PM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    I was wondering how you would test the temp .
  19. Jan 25, 2012 at 6:24 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with lots of midtravel bling.
    uniballs and polybushings will give "cleaner" travel. The arms are also much stronger.
  20. Jan 25, 2012 at 6:41 PM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    Yeah those arms also allow you to keep your stock fenders and you can add a secondary shock to it as well . The bottom of the arm come with a skid .
