Mid Travel with BS Thread
Discussion in 'Suspension' started by MightyMouse-SCT, Jan 25, 2012.
  1. Jul 11, 2013 at 7:39 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    goleta/santa barbara, ca
    97 5 speed 4x4 v6
    lt
    tightening the lower spindle bolts cured all of my popping...they weren't tight enough
  2. Jul 11, 2013 at 8:54 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    Fairfield, NorCal
    2015 TRD Sport 4x4 6 Speed
    Huh! I'll have to take a look at that! I have this crazy pop when I back up...just on the drivers side...might be a little slop in the uniball though...hoping its just something a little too loose :D
  3. Jul 11, 2013 at 9:44 PM
    genrec
    genrec Well-Known Member
    what bumper is this?
  4. Jul 11, 2013 at 9:55 PM
    M C M
    M C M Well-Known Member
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    All Pro
  5. Jul 11, 2013 at 10:03 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Blang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    i was gettting popping noises when i had to much preload on mine and it was causing the ball joint on the LCA to go bad. once i took the preload out, all popping when away.
  6. Jul 12, 2013 at 12:10 AM
    smkd13
    smkd13 Master Blaster
    Ben
    Provo, UT
    01 4Runner SR5
    TT Boss 3" Lift w/ LR UCAs adjustable Panhard
    Hmmm well that would make sense then
  7. Jul 12, 2013 at 12:51 AM
    T4C0CH40S
    T4C0CH40S RINZLER
    Stefen
    Tucson, AZ
    THE RECTIFIED PRERUNNER
    ADS Racing Shocks | Dirt King | KMF | Pelfreybilt | BruteForceFab | Total Chaos | HomerTaco | Toywerx | Tepui | Toyo Tires | Stealth Custom Series | Stealth Runner 8 | SDHQ | MaxTrac | TRS | Morimoto | Rigid Industries | VIP | Jumpers LEDs | Wet Okoles | Trailer Products | McNeil Racing | ECGS | AFe CAI | IAS | ...Check out my RECTIFIED BUILD>>>>>>>>>>>
    Thanks for the responses gents, im gunna dive into this taco within the next week and check everthing previously mentioned. ill report back with results
  8. Jul 12, 2013 at 12:18 PM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Went down and visited Micah and Neil over at DSM today, good guys and thanks for everything, including my new bitchen hat! :thumbsup:
    Also went over to All-Pro and picked up my stuff there!
    Just waiting on my rear shock relocation kit and I'll be ready to go!!!
    Mid-Travel here I come!!!
  9. Jul 12, 2013 at 1:36 PM
    MightyMouse-SCT
    MightyMouse-SCT [OP] Well-Known Member
    Gabriel
    O'SIDE CA
    MightyMouse-SCT - 2011 LT 4x4 Desert Runner
    Long Travel Total chaos kit, fox shocks, smp fab , dmz sua, glassworks, method wheels.
    Weld on bumps ?
  10. Jul 12, 2013 at 1:38 PM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road Vendor
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
  11. Jul 12, 2013 at 1:46 PM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    Oh he's going with your hoops ?
  12. Jul 12, 2013 at 1:48 PM
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Yes he is! =D
  13. Jul 12, 2013 at 1:48 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
    Nice meting you!
  14. Jul 12, 2013 at 1:50 PM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    Nice . Didn't know they were in production yet. You should also plate / box the frame area where the bump goes
  15. Jul 12, 2013 at 2:21 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    Icon Ext Travel Coils, Built right UCAs, nFab light bar, Fox 2.0 piggy backs, Demello Sliders, Weather Tech Liners, Wet Okole Seat Covers, AFE CAI, Magnaflow Mufler, 6000k HIDs Headlights, 3000K HIDs Fog Lights, Fogs Anytime Mod. Cluster LED Swap, HU LED Swap.
    What r the specs on those rear kings ?
  16. Jul 12, 2013 at 2:22 PM
    They are 2.0x12" travel to work with Tyler's rear mount kit.
  17. Jul 12, 2013 at 2:29 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    Can those b fox? Instead of kings? I'm thinking going the same route but with fox.
  18. Jul 12, 2013 at 2:46 PM
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    The kit comes partially assembled to allow for small differences like shock brand (ex. fox vs king is appx 1/2" diff comp/ext lengths) leaf pack thickness and consumers preferred bump height.
    The installing fabricator should cycle suspension to determine the proper bump height for their leaf pack. The droop may be limited by the leaf pack/shackle however limit straps are highly recommended to keep all components healthy.. The hoop orientation to the frame reinforcement plate and the lower shock mount axle tabs are all adjustable enough to get the sweet spot on any configuration leaf pack that is using factory hanger locations.
    example: my rear setup uses All Pro Expos, they bump just at beginning of negative arch and droop out all 12" of the shocks at the same point that the shackles and leafs run out of travel, limit straps stop all the suspension components appx 1/4"-1/2" prior to full droop.
  19. Jul 12, 2013 at 4:21 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    Would there b any issues if I install your kit having all pro standard pack and down the road I decide to go with the expos?
  20. Jul 12, 2013 at 4:44 PM
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    You may have to adjust the bump height slightly, no biggie
Products Discussed in this Thread
