Mid West 1st gen BS thread...
Discussion in 'Mid West' started by GQ7227, Aug 27, 2019.
  1. Mar 27, 2020 at 3:53 PM
    #61
    Saiko
    Saiko Well-Known Member
    Saiko
    Chicago
    00 2RZ w59 2wd
    what are you looking to bet done? swap out ur trucks bed?
  2. Mar 28, 2020 at 8:28 AM
    #62
    GQ7227
    GQ7227 [OP] mw survivor
    J A Y
    i have found quite a bit of old crunchy frame coating that is peeling off the metal and wanting to replace all of it in the back section
    some (most) areas are hard AF to attempt to get at unless i have more head clearance for safety
  3. Mar 28, 2020 at 11:06 AM
    #63
    Saiko
    Saiko
    Chicago
    00 2RZ w59 2wd
    i rent a storage unit that i use as my garage....did that cross your mind?
    if you need welding or frame repair, check out Destruction Warehouse they got only a FB page.
    Destruction Warehouse 847 406 9200
    GQ7227[OP] likes this.
  4. Mar 29, 2020 at 6:06 AM
    #64
    GQ7227
    J A Y
    i have a driveway and some decent ramps i have been using to get at underneath the cab, old bad neck and all, its always sore and stiff AF the next morning with headache after only a few hours under there the day before from last fall, most likely the same tortured thing this spring and early summer to finish under the cab.
    so far I have not encountered any areas in need of welding thank goodness! everything i have checked looks legit and structurally sound, right now it just needs the old peeling coating removed, sanded out any surface crust on the steel, zinc acid washed and a couple coats of extreme chassis primer. I ran out of good weather last fall to try the extreme chassis topcoat and see how that looks under there
    the jury is still out on exactly why this old frame coating is peeling off
    somebody on TW once told me its due to age :notsure:
    Saiko[QUOTED] likes this.
  5. Apr 1, 2020 at 11:20 AM
    #65
    GQ7227
    J A Y
    i just noticed you have a 2wd truck
    how do you make it around in the winter? it must take some skills
    i used to have that skill in the early 90s with a couple of RWD vehicles at the time, one had no working heat or defrost lol so there was another skill :drunk:
  6. Apr 2, 2020 at 8:47 AM
    #66
    Saiko
    Saiko
    Chicago
    00 2RZ w59 2wd
    i love it, i purposefully wanted a 2wd, i plan on doing a swap in the future so a 3s or a UR swap figured it would be easyer....its great in winter iv got all terrain tires iv got no problems, plus anything i ever drove is rwd, starting from ae86s, supras, cressidas, iam always rwd...i like this :burnrubber::yay:
    GQ7227[QUOTED][OP] likes this.
  7. Apr 4, 2020 at 2:17 PM
    #67
    GQ7227
    J A Y
    truck turned 140k under a blue Iowa sky today west of Missouri Valley,
    lovin' the 1.61 gas not seen locally since before Hurricane Katrina in '05
    this is what highway 30 looked like with the barriers in the '11 MO river flood via damn mismanagement upriver in SD
    gas was 3.50 here then, it sucked to fill that tank with fuel
    web pic
  8. Apr 8, 2020 at 1:33 PM
    #68
    GQ7227
    J A Y
  9. Apr 10, 2020 at 3:11 PM
    #69
    GQ7227
    J A Y
    there is some 91c fuel at this BP in WI currently .. 144c on 14.May .. 159c on 21.May .. 184c on 13.June ... 209c on 26.June
    https://www.gasbuddy.com/station/138361
    https://www.gasbuddy.com/station/75263
    144c in Chicago by O'Hare airport .. 1,87 2wks later, now 2,02 on 5-7, 2,07 0n 5-10 .. 213c 0n 5-21 .. 219c 0n 5-30
    https://find.shell.com/us/fuel/10008810-4-w-irving-park-rd
    https://www.google.com/search?q=she...8126],[41.87369374582089,-87.95480236513671]]
    99c in KCMO (or was!)
    https://www.gasbuddy.com/Station/138612
    https://www.gasbuddy.com/GasPrices/Missouri/Kansas City
    119c in Denver (arvada) ... or was...
    https://www.google.com/maps/place/S...44068630f681e!8m2!3d39.7939816!4d-105.0785402
    https://www.gasbuddy.com/GasPrices/Colorado/Arvada
    128c shell in gregory SD as of 14.May
    https://www.gasbuddy.com/GasPrices/SouthDakota
  10. Apr 14, 2020 at 7:09 AM
    #70
    GQ7227
    J A Y
    the last time i put 1.25 per G taco fuel there were NO 2nd gens on the road lol
    it was in December 2oo3, over 16 years ago!
    at that price i can get 1000 miles for roughly $66, even less if i had different tires than the duraTracs (which somehow have been sucking 2 or 3 MPGs on me for almost 30k miles :()
    throughout most of the last decade+ it would cost in excess of $150 to get 1000 miles on the truck
  11. Apr 14, 2020 at 8:28 AM
    #71
    Shellshock
    Iowa
    should have gotten falkens. they wouldn't have killed your mpgs
  12. Apr 14, 2020 at 8:36 AM
    #72
    GQ7227
    J A Y
    i shall be looking into getting those on the next set! i am trying to estimate how far the duraTracs can go before needing replaced
    either those or the hankooks
    or perhaps get another set of used wheels and have 2 sets, one for highway and the other for offroad / blizzard conditions
    how many approximate miles are the falkens rated for?
  13. Apr 14, 2020 at 8:37 AM
    #73
    Shellshock
    Iowa
    I got 56,000 out of my first set.. .they could have kept going honestly but I wanted new ones before winter
  14. Apr 14, 2020 at 12:06 PM
    #74
    GQ7227
    J A Y
    can i check out those falkens on yours at a safe six+ foot distance, bring some binoculars?
  15. Apr 14, 2020 at 12:10 PM
    #75
    Shellshock
    Iowa
    uploadadventure likes this.
  16. Apr 25, 2020 at 1:35 PM
    #76
    GQ7227
    J A Y
    good times in the windy city this past week, 2 nights on the concrete trail, cheap af taco fuel not seen since the truck was damned near new!
    $25 per night lodging + cook county tax was not bad at all! very clean and comfy room
    and $4.50 per hour meter parking, only spent an hour parked 11pm-midnight
  17. Apr 26, 2020 at 10:08 AM
    #77
    Saiko
    Saiko
    Chicago
    00 2RZ w59 2wd
    anyone of you ever meet? or plan on?
  18. Apr 26, 2020 at 10:20 AM
    #78
    GQ7227
    J A Y
    the only other regional 1st gen active on TW i recall at the moment meeting once outside of the St Louis area last summer was @JTFisherman
    it was very brief though
  19. Apr 26, 2020 at 12:31 PM
    #79
    JTFisherman
    JTFisherman Well-Known Member
    Jake
    Texas / Missouri
    4Runner
    Yep not a ton of super active first gens in the Midwest that I know of. There are a few guys in STL that pop in from time to time but not with much consistency.
  20. Apr 29, 2020 at 7:13 AM
    #80
    GQ7227
    J A Y
    dammit i am happy af i seized the opportunity and banked some good taco miles on the 'cheap'
    the shell gas station by Chicago O'Hare i found for 1.43 last week is now at 1.68, now 1.75! ... now 2.02!
    the hands were getting a bit raw from all the sanitizer i was using lol
    https://www.google.com/search?q=shell+gas+prices+in+chicago&npsic=0&rflfq=1&rlha=0&rllag=41824073,-87657879,12135&tbm=lcl&ved=2ahUKEwjCqoi2zu_oAhUXbc0KHS-lBMYQjGp6BAgLEDM&tbs=lrf:!1m4!1u3!2m2!3m1!1e1!2m1!1e3!3sIAE,lf:1,lf_ui:4&rldoc=1#rlfi=hd:;si:1581119011073481367;mv:[[41.98760945387374,-87.76975140078126],[41.87369374582089,-87.95480236513671]]
    last weeks pic
    never let a crisis go2 waste
