Midland MXT275 to my battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kyle_, Sep 27, 2022.
  1. Sep 27, 2022 at 7:43 AM
    Kyle_
    Kyle_ [OP] A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    The midland mxt 275 has a cigarette lighter plug that comes wired to the head unit. Can I just cut the positive and ground wires where it connects to the cigarette lighter plug then wire it directly to my battery?
    it has an inline fuse so as long as I keep the fuse, am I all set?
    Do I need to wire up a relay or anything?
  2. Sep 27, 2022 at 7:49 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    Yep, you can do just that. It's what I, and my friends, do.
  3. Sep 27, 2022 at 7:51 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    You don't need to relay as long as you remember to turn it off open( I can't remember if that radio has a proper battery protection) . If you want to turn it off with the ignition then yes, wire a relay in between.
    In any case it would be an awesome idea to put an inline fuse close to the battery, in case of any kind of a short or an issue not to burn up your truck
  4. Sep 27, 2022 at 7:56 AM
    Kyle_
    Kyle
    SoCal (805)
    @tacoma.kyle on IG
    Thanks for the point with having the fuse closer… I may cut the wires after it then but I need to completely decide before half-assing it…
    Bastek[QUOTED] likes this.
