Midwest -> Moab March 24- April 2 2023
Discussion in 'Mid West' started by Supr4Lo, Oct 12, 2022.
  1. Feb 11, 2023 at 9:39 AM
    #281
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    As soon as you come home with the new one, you'll see the one you knew you had laying right out in the open. That's some bastard cousin of Murphy's Law.
    But you'll never find that 10mm socket.
  2. Feb 11, 2023 at 9:50 AM
    #282
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I have one and use the stink out of it. If it doesn't find a good home I will take it just to have one at each end so Jason (or whomever is handy) can get me out either way...
    Taco-Grinder likes this.
  3. Feb 11, 2023 at 9:51 AM
    #283
    pearing
    Wisconsin
    2015 SR5 quadcab
    Have two fire ex and a first aide kit
  4. Feb 11, 2023 at 9:52 AM
    #284
    pearing
    Wisconsin
    2015 SR5 quadcab
    Says the guy with 35's...
  5. Feb 11, 2023 at 9:54 AM
    #285
    pearing
    Wisconsin
    2015 SR5 quadcab
    Thats why my rear springs are 1200 lbs over factory...
    Pixeltim and Supr4Lo[OP] like this.
  6. Feb 11, 2023 at 2:50 PM
    #286
    pearing
    Wisconsin
    2015 SR5 quadcab
    Also have a jump pack! I am bringing a bottle of good whiskey as well... no tool kit is complete without a little medicinal.
    Taco-Grinder and Stoney Ranger like this.
  7. Feb 12, 2023 at 7:50 AM
    #287
    JOHNNYPICKLES
    JOHNNYPICKLES Well-Known Member
    Chicago
    2019 White Double TRD OR
    For tools and recovery I got some of the same. I don’t go anywhere without my tool box. I’ll have everything you need plus breaker bar in tools except for those bigger sockets. 30+. Got first aid kit. Was going to ask about hi lift Jack but saw it mentioned.
    I do have a couple questions. I did my 60,000 mile service on my truck yesterday. Noticed I got a torn boot on my tie rod. I’m going to replace it and save it for a spare. You guys have any suggestions for aftermarket tie rods? Best to keep OEM? Other spare parts we mentioned. Should some of try us to find some more?
  8. Feb 12, 2023 at 8:50 AM
    #288
    Supr4Lo
    Supr4Lo [OP] Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I have read that OEM are the best and Moog is next best, which is what I have for back-ups.
    Outter Tie Rod End
    Inner Tie Rod
    Between a few of us we already have 3 CV axles and I'll have 1 inner and outer tie rod. Those are the most common things to fail (specially if you have a front locker). Really the trails we're planning on doing so far shouldn't be too hard on the trucks.
  9. Feb 12, 2023 at 1:26 PM
    #289
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Busy weekend here.
    2 piece sleeping platform is done.
    Finish the roof top box mounts.
    Drained and filled rear diff.
    Come back into the house and toilet is leaking. Tear that apart and replace wax ring. Prior to going to Moab I want to replace the truck battery. Current one is over 5 years old.
    Supr4Lo[OP] and Stoney Ranger like this.
  10. Feb 12, 2023 at 1:48 PM
    #290
    pearing
    Wisconsin
    2015 SR5 quadcab
    I bought one this fall... fancy expensive Odessey AGM. Heavier but starts like a champ. Did NOT do the power upgrade for the alternator. I don't drive it much in the winter, so it sits and charges... Thats my two cents-go AGM. Heavier though... Very expensive too
    Taco-Grinder[QUOTED] likes this.
  11. Feb 12, 2023 at 1:53 PM
    #291
    pearing
    Wisconsin
    2015 SR5 quadcab
    Speaking of trails. Watched a video on steel bender: seems to me the ledge which seems to be the crux is not much worse than that rock @Supr4Lo and I found the first day at Tigerton. Vid showed a long bed doing it so not worried about Dan... food for thought on Thursday...
  12. Feb 12, 2023 at 1:54 PM
    #292
    Supr4Lo
    Surprise, AZ
    I agree with Pat, if you can go with an AGM. I got the X2 Power AGM from Batties Plus. X2 is a rebranded Northstar. Right now use code AUTO20 for 20% off. If you talk to @wi_taco he can point you in the direction for the voltage booster.
    Gunshot-6A and wi_taco like this.
  13. Feb 12, 2023 at 1:57 PM
    #293
    Supr4Lo
    Surprise, AZ
    Steel bender is close to our camp ground. I think you can get to it from the Gemini Bridges Trail. Which I'm hoping we can squeeze in also. It's another good easy Campground to town trail.
    Stoney Ranger likes this.
  14. Feb 12, 2023 at 1:58 PM
    #294
    Taco-Grinder
    Dan
    Fond du Lac, WI
    :thumbsup:
  15. Feb 12, 2023 at 2:53 PM
    #295
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I've been trying to stay away from AGM because of the weight and the voltage boost mod.
    I do have plans for some lighting upgrades. I'll have to think about it.
    Sometimes I think you guys work for the credit card companies.
    Supr4Lo[QUOTED][OP] likes this.
  16. Feb 12, 2023 at 2:57 PM
    #296
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    If you change your mind, voltage boosters are from HKB Electronics: https://www.hkbelect.com/products/toyota/?model=tacoma&year=2013
    24F AGM weighs about the same as a 27F lead acid, but going to 27F AGM will give you some extra reserve & depth of discharge. Yes extra weight, but not the worst thing to have for winching and lights.
    I have a spare MK3 fixed booster I'd part with if you want it. I switched to the MK4 adjustable just because I wanted more fine-tuned control. I'd still run either one though.
  17. Feb 12, 2023 at 3:37 PM
    #297
    Shellshock
    Iowa
    I also have one of those
  18. Feb 12, 2023 at 6:47 PM
    #298
    Stoney Ranger
    Stoney Ranger Pizza Cutters, Baby... and Lockers? Pffft
    Dave
    Driftless Area
    '18 Nauti Blue 4Runner SR5
    Full Armor-F/R Bprs Winch-ALF-Stickers
    If anybody would like me to snag them a campsite for Friday night, March 24th, I'll need your...
    Name
    Address
    Make/Model :rolleyes:
    Color
    Year
    License #
    I'll cover site fees for Fri. You can reimburse me when you see me. Send your info in a pm if you wish. Hopefully the campground will have enough sites for all of us. If anybody wants to share a site, let the others know. Some one may be interested.
    But I need to know how many sites to grab Friday night.
  19. Feb 13, 2023 at 9:47 AM
    #299
    Supr4Lo
    Surprise, AZ
    @BoostdDSM Plan on meeting at Kwik Trip in Verona, WI on March 23rd. As of now plan on meeting somewhere around 1-1:30pm. Once we get closer I'll get your phone number so on that day I can give you a more exact time estimate.
    I also added that Kwik trip to the agenda in the 2nd Post post to find it easy later.
  20. Feb 22, 2023 at 2:43 PM
    #300
    JOHNNYPICKLES
    Chicago
    I am happy to share a site with anyone that’s interested. Stoney Ranger I’m going to PM my info to you. I can send you money through Zelle Cash app or Venmo if you like.
    Supr4Lo[OP] likes this.
