Might buy a 2020 TRD OR this weekend
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoTruck, Feb 28, 2025.
  1. Feb 28, 2025 at 6:55 AM
    PNWTacoTruck
    PNWTacoTruck [OP] Well-Known Member
    Brent
    2020 Base TRD OR without tech package. 39k miles.
    Low miles, looks well cared for, clean carfax.
    It was traded in a the Dodge dealership so they have no idea about toyota trucks. Anything I should look for that could be a sign of $$ needed?
    BraveRifles3 likes this.
  2. Feb 28, 2025 at 7:02 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Look underneath for rust. That is a walk away situation. $ doesn't fix that. Other people can chime in with other tips. Good luck with the hunt. Mine is a base TRD w/o tech package. No complaints.
  3. Feb 28, 2025 at 7:25 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Don't trust carfax. Look for mis-aligned panels and hidden damage. Like said already, look for rust on the frame. Also, look at the power steering pump and see if there is any oil residue on it...that would show a timing cover leak that is thousands to fix.
    Jakerou and 23MGM like this.
  4. Feb 28, 2025 at 7:28 AM
    PNWTacoTruck
    Brent
    Anyone got a pic of power steering pump with or without oil on it?
  5. Feb 28, 2025 at 7:41 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Timing chain cover leak and coolant cross over pipe leak.
    BabyBilly likes this.
  6. Feb 28, 2025 at 7:52 AM
    TacoGuy2453
    TacoGuy2453 Active Member
    Central NJ
    2021 Tacoma TRD Off Road DCLB SSM
    The basics are always good to check regardless of the age of the vehicle. The level of all the fluids in the engine bay, check the dipstick for oil level and color. Check the wheels and tires for damage and air level. Make sure all interior controls operate, buttons/switches. There are plenty of checklists online you could print out and take with you when looking at the vehicle. That way you don’t miss anything you’d like to take a look at.
  7. Feb 28, 2025 at 7:58 AM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Also check the engine air filter. Bought a truck recently and it was missing.....
  8. Feb 28, 2025 at 8:00 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Don’t buy without an extended warranty these trucks have a lot of issues.
    TacoDell60 likes this.
  9. Feb 28, 2025 at 8:00 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Check the tierod boots for wetness. If they're wet see if you can get a rack replacement with the sale.
    Couldn't hurt to check the coolant crossover pipe and timing chain cover for leaks too
  10. Feb 28, 2025 at 8:31 AM
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    Check for rust, and any leaks.
  11. Feb 28, 2025 at 8:35 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    My first thought is if someone traded it for a Dodge stay away from it something has to be wrong with it. JMHO
    Kodiak420, Jakerou, D500 and 2 others like this.
  12. Feb 28, 2025 at 9:04 AM
    TacoDell60
    TacoDell60 Well-Known Member
    -Look for frame rust
    -Look for any crappy mods or crap quality aftermarket replacement parts (puck lift, diff drop, wheel spacers, chinese cv axles, etc.)
    -Look for leaking steering rack
    -Look for rear coolant bypass pipe leak, timing cover leak, upper oil pan leak, rear main seal leak
    -Test drive it and pay attention in acceleration between 30-45mph for torque converter shutter (if auto trans)
    -Check to make sure the vehicle can get in and out of 4hi & 4low range, also check to make sure the rear diff locker works as it should (only in 4lo)
    23MGM and t0p_d0g like this.
  13. Feb 28, 2025 at 9:06 AM
    MGMDesertTaco
    Not necessarily, it could have been bought at auction or someone needed a bigger truck or wanted a Jeep, ect.
    RIX TUX and 23MGM like this.
  14. Feb 28, 2025 at 9:29 AM
    FunknNasty
    FunknNasty Well-Known Member
    San Jose
    2022 Pro
    The safe bet is to buy from someone who knows the truck or knows Toyota Trucks. Myself, I only considered a Toyota dealership that certified the truck Toyota Gold or at the very least Silver.
    t0p_d0g likes this.
  15. Feb 28, 2025 at 9:41 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Post #1 “It was traded in at the Dodge dealership”
  16. Feb 28, 2025 at 9:53 AM
    MGMDesertTaco
    Alright, well
  17. Feb 28, 2025 at 9:55 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I can be wrong I was wrong once. Lol
    It was JMHO.
    I was just letting you know OP said it was traded in.
  18. Feb 28, 2025 at 9:58 AM
    MGMDesertTaco
    Well thanks for letting me know. I don't know how I would go about my day otherwise. :rolleyes:
  19. Feb 28, 2025 at 9:59 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    You’re Welcome!
    MGMDesertTaco[QUOTED] likes this.
  20. Feb 28, 2025 at 10:07 AM
    SnuggleTruck
    SnuggleTruck Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) 17x8.5" -12mm Trail Edition OEM replica wheels by FSW BF Goodrich KO2s (285 70 17) ECGS bushing OME carrier bearing drop kit TRD Pro skid plate Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
    Honestly, what a dumb post ^^^^. lol.
    I have a 2020 OR base model and have had 0 issues since day 1.
    If it doesn’t have stupid cheap mods and doesn’t have rust…. Just check the normal stuff and I’m sure you will be just fine.
    PiñonTaco, Jakerou and 23MGM like this.
