Might buy a 2020 TRD OR this weekend
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoTruck, Feb 28, 2025.
  1. Feb 28, 2025 at 10:09 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Wow, thanks for sharing your profound insight!
  2. Feb 28, 2025 at 10:11 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Here is the original brochure for the 2020. Good luck with your purchase.
    https://www.toyotacertified.com/con...brochures/en/tacoma/2020_tacoma_ebrochure.pdf
    23MGM, FunknNasty and t0p_d0g like this.
  3. Feb 28, 2025 at 10:17 AM
    TacoOption
    TacoOption Well-Known Member
    Extended warranty is good advice. "These trucks have a lot of issues" is complete nonsense.
  4. Feb 28, 2025 at 10:20 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Almost every Tacoma 3.5 has timing chain cover leaks and crossover pipe leaks sooner or later. Toyota has known this for eight years and never corrected it. So I would call that an issue.
    TacoDell60 likes this.
  5. Feb 28, 2025 at 10:36 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Almost every? Hah.. that's wild fella. Even for a Friday.
    You mean later as in >350k miles?
    PiñonTaco, Jakerou and TacoOption like this.
  6. Feb 28, 2025 at 10:44 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    No, I mean almost every “sooner or later”!
  7. Feb 28, 2025 at 11:13 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Tacomas are pretty reliable with some issues but a lot less than other makes/models despite what some have said here.
    Saying a dealership doesn't know other makes is also not true.
    Companies make it a business to know their competition.
    People that work in the auto business move around and many have worked for virtually all manufacturers.
    Suggest checking the basics yourself and if your serious ask to take it to an independent shop for an inspection. If they say no, I would walk. You'll have to pay for inspection.
    t0p_d0g likes this.
  8. Feb 28, 2025 at 11:18 AM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    I have a 2020 TRD OR, 45000 miles, no issues yet. How much they asking?
    23MGM likes this.
  9. Feb 28, 2025 at 1:53 PM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    I purchased my Tacoma from a Honda dealership. They seemed to have a whole side business in Toyota trucks. They actually had a lot of relatively new used ones for sale and I think most of them were trade ins. Its not that weird or a bad sign. I don't understand people who only keep a truck for 2 years before selling but there seem to be a lot of them and if you are a must have a new vehicle type of person the reliability advantages of owning a Toyota aren't a big benefit.
    It sounds like the truck might be just barely under the original 5year power train warranty so if you notice any major power train issues Toyota will fix them. Check the original sale date of the truck though to be sure. The warranty does transfer to the new owner when sold.
    The OR trim is definitely the way to go with a used Tacoma. They actually beefed up a lot of things on the OR's and they have had fewer recalls than the base models because of it. Most of the recall fixes over the years have involved putting OR parts onto the truck.
  10. Feb 28, 2025 at 2:07 PM
    TacoDell60
    TacoDell60 Well-Known Member
    What did they beef up on the OR vs other trims? They're all basically identical mechanically, the OR just has the bigger 3rd member for the locker and the different brake booster setup vs SR, SR5, Limited etc.
    TRD trucks are all SR5's even according to Toyota's internal model naming codes.
    Chew, Canadian Caber and Jakerou like this.
  11. Feb 28, 2025 at 2:08 PM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
  12. Feb 28, 2025 at 2:16 PM
    Mach
    I havn't seem a comprehensive list but keep running across more and more little things. The OR has different cab mount bushings and the TSB for diff whine specs switching the truck to them to better isolate the cab. The OR also has frame differences with several extra pieces to beef it up. Some years (might have been second gen) used a different rear leaf spring on the OR which again was the fix when there was a recall on the non OR leaf springs. Better shocks. The beefier rear diff that you mentioned although it isn't just because of the locker as I believe the MTs also have the bigger rear diff and there are 3rd party lockers that will fit the smaller base model diffs. The beefed up brake booster setup you mentioned, also the beefed up cooling and alternator that go with the tow package that it includes. I know there were more little things that I have run into but can't think of them at the moment.
  13. Feb 28, 2025 at 2:17 PM
    PNWTacoTruck
    PNWTacoTruck [OP] Well-Known Member
    Brent
    https://www.carfax.com/vehicle/3TMDZ5BN3LM098200
    here's the ad. It's the lowest price DCLB TRD OR anywhere near me.
    Has PPF up front, body looks great, I couldn't see any evidence of the damage or repair to the rear drivers side. It seems to be well cared for but I didn't get under it or put a flashlight under the hood.
    If someone buys it out from under me this weekend, well, let me know how it works out.
  14. Feb 28, 2025 at 2:20 PM
    TacoOption
    Suspension is the biggest difference between OR and standard SR5. You can clearly tell the difference when you drive both of them.
    TacoDell60[QUOTED] likes this.
  15. Feb 28, 2025 at 2:22 PM
    #35
    TacoOption
    Great color! Good price, don't expect it to be sitting on the lot very long.
  16. Feb 28, 2025 at 2:23 PM
    #36
    Mach
    That is a good price. The long beds are hard to find on the west coast. Frame rust would be my biggest concern. Don't be afraid to crawl under it. Also you will see some rust covered parts as there is some unpainted steel on the truck but you don't want anything significant on the frame.
  17. Feb 28, 2025 at 2:29 PM
    #37
    TacoDell60
    Frames are identical on all trims. Auxiliary ATF cooler has been gone since 2019 in the two package. Rear diff whine TSB applied to all double cab 4x4 trucks between certain years (there's been a few of those TSB's since 2016).
    Leaf springs are different part #'s depending on trim tho.. OR and Pro have their own part number.
  18. Feb 28, 2025 at 3:04 PM
    #38
    Mach
    The frame differences may apply to all 4x4s and not just ORs but they definitely have some different bolted on frame braces and crossmembers.
    The ATF cooler is integrated into the radiator and there is also a power steering cooler and an oil cooler although I don't know if any of these were added to non tow package models at any point.
  19. Feb 28, 2025 at 10:13 PM
    #39
    hwntaco20
    Carfax show minor damage to the left side and rear. Did u see it in person?
  20. Feb 28, 2025 at 10:30 PM
    #40
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I wouldn’t pay over $32K because of diminished value. My 2 cents.
