Might need new alternator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tyler Krausz, Aug 22, 2018.
  1. Aug 22, 2018 at 9:14 AM
    Tyler Krausz
    Tyler Krausz [OP] Member
    Tyler
    2006 white Tacoma
    3in suspension lift, Bilstein 5100s in front and rear with toytec coil overs in front, and add-a-leafs in back. Falken wildpeak at3/w tires with method NV rims, DRL headlights and taillights from tacomabeast.com, pioneer 12in subwoofer and amp.
    So for the past three days or so, I've been hearing this weird whining noise coming from the engine bay. After some recent research, I have found the problem to most likely be the alternator. While driving, the battery light, abs light, and parking brake light came on within a 2-minute span of one another. I was wondering what recommendation do some of you have for a new alternator or what I should do about this problem. Any help would be greatly appreciated!
  2. Aug 22, 2018 at 11:00 PM
    HillJackJDS
    HillJackJDS Well-Known Member
    Dale
    2008 Tacoma 4WD
    Check the voltage at your battery when it is running and revving. Look for low output as well as possible poor regulation of output when doing so.
    You can identify many whines with a long screwdriver placed on your suspect item and the handle to your ear. Unless you have added A LOT of stuff to your vehicle, you probably have no reason to upgrade from OEM parts or recommended sizes. If you have a quality rebuilder nearby, sometimes parts are upgraded internally from OEM configurations with better parts and for less money than new offerings.
    I wouldnt replace the alternator until I knew for sure that yours was junk.
    whatstcp likes this.
  3. Aug 22, 2018 at 11:05 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Disconnect the fieldwire plug from alternator with the engine running. If the whine goes away then the alt is bad
    TheDevilYouLove and 12TRDTacoma like this.
  4. Aug 22, 2018 at 11:42 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The battery light alone indicates a bad battery or bad alternator. The whining sound would seem to pinpoint the alternator. Take truck to an autozone or the like; they will test the charging system at no charge with a handheld diagnostic tool. I've seen the tool up close and it is a nifty device. You could do your own simple tests with a voltmeter and do a load test. Simple to do once you do it. There are many utube videos on this - I like the Chris Fix videos the best.
  5. Aug 23, 2018 at 12:13 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This. Easy diagnosis for the win.
    TheDevilYouLove and HillJackJDS like this.
  6. Aug 23, 2018 at 4:19 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Get a voltmeter to check the battery voltage with engine off / idling and a mechanic's stethoscope or long screwdriver to pinpoint the noise. IMO, unplugging the alt won't rule out a faulty battery coupled with noise from another possible pulley such as alt, idler, tensioner, a/c, etc...
    Start with cleaning your battery terminals until sparkling clean and tighten before performing any other tests.
    HillJackJDS likes this.
  7. Aug 23, 2018 at 4:54 AM
    Petrol
    Petrol Well-Known Member
    Central Va.
    Tacoma
    /\ This is the winner /\
    There are a lot of possibilities for the type of alternator failure (worn brushes, bad rectifier, intermittent open circuit in one of the windings, bad regulator) but in the end those are all academic because the simplest solution is to just replace the alternator.
    There was a time when rebuilding alternators made more economic sense but in today's world it makes more sense to just swap out the alternator. On this note, I'm a proponent of replacing the brushes in an alternator as a preventative step before the brushes completely fail. However, that step is preventative maintenance and generally not a repair once the alternator has failed.
    Also, a battery that is nearing the end of its life will result in the alternator attempting to constantly charge it at a high rate. That can result in that whining noise as well. So if the OP has a battery in that 4-6 year life range, I would suggest load testing the battery as well. In fact, if the battery is beyond that 6 year mark, I would just go ahead and replace it now before the weather gets colder.
    You can get yourself into a vicious cycle with bad batteries & alternators. A bad alternator can cause a marginal battery to fail sooner and bad battery can work an alternator harder than normal resulting in a marginal alternator failing sooner than expected.
    b_r_o[QUOTED] likes this.
  8. Aug 23, 2018 at 5:03 AM
    Clearwater Bill
    Billy
    Largo Florida
    I've found that a local shop that specializes in such things can provide a much better value by rebuilding your current unit than buying a big box reman.
    Last one I had done they removed/rebuilt/replaced the unit for 2/3 the $ of buying reman and still having to do the R&R myself. Which, on that particular vehicle, wasn't all that simple.
    Something to investigate anyway, ie finding out if such a vendor exists in your locale.
  9. Aug 28, 2018 at 10:28 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    OP how many miles did you have before your alt went. Also anyone else welcome to chime in. I'm at 132500 now. Planning on brush replacement this weekend. Tried last weekend but of course lower bolt is rounded so had to get some Irwin extractors.
  10. Aug 28, 2018 at 10:46 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    original alt in mine and at 196k miles
    I keep my head lights, fog lights on and fan at III all the time
  11. Aug 28, 2018 at 11:00 AM
    Benny123
    Ben
    South Charlotte, NC
    Sweet. Never changed the brushes or otherwise serviced the alt?
  12. Aug 28, 2018 at 11:14 AM
    knottyrope
    Knotty
    Bahstun
    Nothing done to the alt yet
    never touched the alt in my 88 toy 4x4 or 99 i4 taco
    Benny123[QUOTED] likes this.
  13. Aug 29, 2018 at 1:08 AM
    Chuy
    Lakeside, CA
    Silver Taco
    @Benny123 Replaced my OEM alt at 155K with a 200-amp alt from eBay vendor BnR. They didn't required a core; so, I replaced the brushes in the OEM alt and have it as backup. As I recall the old brushes looked good.
    Benny123 likes this.
  14. Aug 29, 2018 at 2:17 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    If you do have a bad alternator, whatever you do, save yourself the headache and don't buy replacement from Autozone/Advance/Oriellys etc - they might look pretty but they are straight junk. Find a local rebuilder, or get a good used OEM unit from a pick-a-part. etc. I have had good luck with Alterstart on ebay as far as rebuilders go.
  15. Aug 29, 2018 at 9:29 AM
    Benny123
    Ben
    South Charlotte, NC
    @Chuy I was thinking about doing the same with an old alternator. The only thing I wondered is how long it can sit on a shelf before it goes bad?
  16. Aug 29, 2018 at 11:13 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I got about 330K on my ‘07s original alternator. No maintenance on it but I would’ve replaced the brushes if I knew that was an option...
  17. Aug 29, 2018 at 2:22 PM
    knottyrope
    Knotty
    Bahstun
    An alt is in your engine bay with heat, cold, water, dirt and stuff and maybe more
    on a shelf its protected from those elements
    Starter on my 69 140 is original.
    I bet an alt on the shelf will last 100 years or more so long as it isn't getting wet
  18. Aug 29, 2018 at 2:30 PM
    Benny123
    Ben
    South Charlotte, NC
  19. Sep 1, 2018 at 10:40 AM
    Chuy
    Lakeside, CA
    Silver Taco
    @Benny123 ... and protect it from critters moving in. I put the OEM alt in a heavy gauge plastic bag and threw that in the box I got with the replacement alt and threw it on the shelf.
