Mike singer voltage booster groupbuy feeler thread
Discussion in 'Deals & Coupons' started by ManBeast, Mar 28, 2018.
  1. May 4, 2018 at 2:16 PM
    #261
    TheTrooper
    TheTrooper Someone has to be part of the problem
    Nick
    Asheville, NC
    2015 Silver TRD Sport DCSB
    Access Cover; SOS Sliders; Pop'n Lock
    This is stage 1
  2. May 4, 2018 at 2:18 PM
    #262
    TheTrooper
    Nick
    Asheville, NC
    The voltage reading on my battery with stage 1 is higher than what the ecu or cig lighter shows. Cold start this morning for me was 15.1, quickly drops to 14.3-4
  3. May 4, 2018 at 3:13 PM
    #263
    Aw9d
    Aw9d That one guy
    Az
    Cold start was 14.1, then dropped to 13.5'ish. Battery (DMM), Torque App, and voltmeter all show the same numbers with a variance of .1. I emailed Mike about it just to see if he has any thoughts. My alternator has put out these numbers (without plug) since the day I got the truck.
    Remove the plug, 13.7 cold, 13.1-2 warm.
    I have a buddy with his Tacoma heading over in few to try the stage one plug on. See what voltage his truck gets.
    OBDII software ( Warmed up with stage one attached)
    Volt meter (warmed up with stage one attached)
    Plug removed (Warm)
  4. May 4, 2018 at 4:18 PM
    #264
    Joe23
    Joe23 Technically, alcohol is a solution
    Joe
    The Great White North
    2017 TRD Off-road DCSB
    Check build thread
    Did you end up getting this? I'm about to do a dual and dunno if which I should go with stage 1 or 2 and which type I need for the 3rd Gen.
  5. May 4, 2018 at 4:29 PM
    #265
    Joe23
    Joe
    Check build thread
    Problem I ran into with a similar type of product.
    I got a diode from hkb electronics. Was $80AUD and didn't work as the fuse you're supposed to replace doesn't exist in 3rd Gen. They were nice enough to refund me. But still looking for a solution to boost the voltage for the two North Stars I'm going to install.
    Scan gauge shows 13.7 idle and 13.8-.9 when throttle. Measured at the battery cold of 14.08V
    According to north star it's 13.4-13.8V float charge and 14.4 cycle.
  6. May 4, 2018 at 4:38 PM
    #266
    Joe23
    Joe
    Check build thread
    Dunno if it was mentioned but doesn't work for 3rd Gen. I bought one. They were nice enough to refund me though. Which is why I'm here and from the sounds of it this won't work with 3rd Gen either
  7. May 4, 2018 at 4:52 PM
    #267
    snwbrdr852
    snwbrdr852 Well-Known Member
    Utah
    '17 DCSB OR V6 AT 4WD
    I didn't take it any further after I found that part number and image, as that sounded like the nail in the coffin to me.
    Based on other research I've done, I believe the principle is still the same for 3rd gens. It would likely just take a different set of connectors vs the 2nd gens, but that still hasn't been physically verified.
    I think I've settled on a different approach now anyway - Redarc BCDC for my house batteries, based on it's ability to charge using profiles specifically designed for each battery type, as well as the solar input since I'll be adding some in the near future.
    I may revisit the diode idea at some point down the line, but would probably just wire it in myself if so.
    I'm definitely interested to hear anything more that you may find out though. Please keep us posted.
    Oh, and which stage you need depends on what battery type you have. For example, I think AGMs generally need ~14.6, but the standard flooded lead acid are more like ~13.8. (Don't quote me.) Just keep in mind that depending on how you wire everything up, your alternator will be sending a single voltage to both of your batteries, which is one of the reasons you should match them. Sounds like you'll already have that covered though.
    Joe23 likes this.
  8. May 4, 2018 at 4:54 PM
    #268
    Joe23
    Joe
    Check build thread
    Ya just bought $900 worth of batteries for this lol. Just need to make sure I'm getting the proper voltage to charge them .
    I'm now considering a different charger whether it's ctek our bcdc but I wasnt planning on doing solar
    My concern is it being AGM I'll have voltage and charging issues
  9. May 4, 2018 at 6:35 PM
    #269
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    ADS ext travel coilovers with clickers, Icon tubular UCA's Rear-ADS 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    It doesn't look like the booster is working. My stage 1 starts at 14.8 and drops to 14.1 after warm up. Without the booster my cold start was 14.1 just like your numbers.
    Aw9d likes this.
  10. May 25, 2018 at 8:08 AM
    #270
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    just wondering if everyone who ordered got there booster? seems this thread kind of tapered off a bit. Came across this as I currently have a OGE dual battery set up with odysseys. looking to boost the voltage. not sure if this is still open for people to order?
    been playing around making my own just kind of curious what peoples thoughts are after install?
    currently I been just charging my batteries on a charger over night every couple weeks.
  11. May 25, 2018 at 8:14 AM
    #271
    Aw9d
    Aw9d That one guy
    Az
    Just email Mike Singer your order and mention the group buy.
    Coop68 likes this.
  12. May 26, 2018 at 10:26 PM
    #272
    tperks
    tperks Member
    Tyler
    2017 Tacoma TRD Off-Road; Quicksand
    Bummer, I found this by chance hoping it would solve my charging issues with my Odyssey in my 3rd Gen but I suppose not. Hopefully he can find a solution; for right now I just throw it on an AGM charger every weekend.
  13. Sep 23, 2018 at 8:58 PM
    #273
    chmura
    chmura Well-Known Member
    Orange County, CA
    I need to get this. Is he still selling these?
  14. Sep 24, 2018 at 5:14 AM
    #274
    jsucraig
    jsucraig Well-Known Member
    Craig
    Lynchburg, Virginia
    2013 Tacoma TRD Off-Road Double Cab
    Mudflaps removed, MESOJDM LED Interior lights, 886 Fog Lamps for Reverse Halogens, Redline Tuning Hood Struts, Garmin Dashcam 20, 17X8 Chrome Helo HE791 MAXX Wheels, Cooper Discoverer AT3 265/65R17, JBL Speakers, JL Sub, and Alpine & Memphis Amps, mattgecko LED Bed Light & Under Hood Kit, Truxedo Low Pro QT Tonneau Cover, OEM Bed Mat
    I emailed Mike about this last month. He is still selling them at the original price (not group buy price), of course, but he hasn't responded back to my order. I was going to try to order again sometime this week.
    seoulja99 likes this.
  15. Sep 24, 2018 at 8:24 AM
    #275
    jsucraig
    Craig
    Lynchburg, Virginia
    I just contacted him again via his emali: sales@singeralternators.com, we'll see if he responds.
    seoulja99 and DukesTaco like this.
  16. Sep 25, 2018 at 7:45 PM
    #276
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    so no known booster for 3rd gen yet?
    deeezy likes this.
  17. Oct 4, 2018 at 7:13 PM
    #277
    jsucraig
    Craig
    Lynchburg, Virginia
    October 4 and still no word from Mike Stinger on ordering this voltage booster.
  18. Nov 18, 2018 at 8:16 AM
    #278
    jsucraig
    Craig
    Lynchburg, Virginia
    Finally got mine in the mail Saturday November 17. I checked the voltage output to the battery without the booster, 13.9-14.0v, plugged the stage 2 booster in and and checked, 13.8v! I emailed Mike back to see what was up. I told him I will watch it on the way to work Monday 1hour (52 miles) to work and 1h30min (52 miles) home. I will monitor the voltage on my Pioneer DEH-80PRS Head Unit.
    ManBeast [OP] likes this.
  19. Jan 10, 2019 at 12:25 PM
    #279
    WifesTaco
    WifesTaco Well-Known Member
    James
    N. Texas
    2009 Tacoma, Blue, 4.0 DCSB TRD OR
    3" Icon front lift w/Icon UCA, All-Pro rear expedition leaf springs (HD version), Icon RXT rear shocks, 35” BFG KM3’s, ARB front locker, All-Pro front, mid, T-Case Skids & rock rails, TRD CAI, Viair dual 450C on-board air, Bruteforce front bumper w/10k X2O winch, FabFours rear bumper w/tire carrier, Odyssey and Optima Batteries, Blue Sea aux fuse box, Rigid light bar, Vision X 4.5 Cannon's, Rechelon Aesthetics HID retrofits, BajaDesigns Fogs, Archive garage Hammer Hangers, Trail Toys UHMW gas tank skid, docloco custom switch plate
    Did this get resolved?
  20. Jan 10, 2019 at 5:23 PM
    #280
    jsucraig
    Craig
    Lynchburg, Virginia
    Yes. Sorry I forgot that I never responded. Mike was great to work with. I emailed him and told him that I would monitor it. He gave me troubleshooting instructions and verified that the booster was defective from manufacture. I offered to fix it in the field to which he would not even think about, replacing it free of charge. The replacement worked as expected and now I have a Tacoma that runs 14.5-15.2 V.
