Mike's 50 shades of mud, and shenanigans every once in a while
Discussion in '2nd Gen. Builds (2005-2015)' started by 11TRDTX, Jun 1, 2016.
  1. Aug 8, 2020 at 4:40 PM
    #441
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    sweet! so when do we go wheelin?
    beertimecontinuum likes this.
  2. Aug 8, 2020 at 6:01 PM
    #442
    11TRDTX
    11TRDTX [OP] bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    :notsure:
    taking it to Gatlinburg next month though
    KnoxTac0713 likes this.
  3. Aug 17, 2020 at 6:19 PM
    #443
    11TRDTX
    11TRDTX [OP] bruh
    Memphis, TN
    So i battled a seized tie rod nut when i attempted to align my truck when i put the new tires on, so i said screw it and ordered inner and outer tie rods for both sides. So in addition to getting the alignment right again, i got rid of one of the noises the truck had and also the play in the steering.
    totmacher and beertimecontinuum like this.
  4. Aug 17, 2020 at 6:24 PM
    #444
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Shotgun!!
  5. Oct 29, 2020 at 5:18 PM
    #445
    11TRDTX
    11TRDTX [OP] bruh
    Memphis, TN
    small shenanigans:
    I've always wanted a stubby antenna, but it's never been a priority. i could have ordered/bought one, but.... I had this little section of 3/16" steel bar left over from the rc trailer build, so I decided why not since I'm always tinkering with random parts?
    I threaded one end about 3/4"-1" up (5mm x 0.8 die), soldered a wire to it, and wrapped the wire around. Covered with heat shrink and stuck a vacuum hose nipple on top for a cap. I used a couple of washers and nuts to shim for fitment at the mount and covered with heat shrink.
    so once again, could I have bought one for cheap? sure... but why not go this route for the fun of it? plus the fact that it cost me nothing :D
    14Tacos4me and beertimecontinuum like this.
  6. Oct 30, 2020 at 6:41 AM
    #446
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    But does it work?
  7. Oct 30, 2020 at 6:45 AM
    #447
    11TRDTX
    11TRDTX [OP] bruh
    Memphis, TN
    it does. it picks up U of M's 91.7 clearly... that station is always weak and was nonexistent when i just had a bolt stuck in.
  8. Oct 30, 2020 at 9:56 AM
    #448
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
  9. Nov 14, 2020 at 4:59 PM
    #449
    11TRDTX
    11TRDTX [OP] bruh
    Memphis, TN
    did some shenanigans today... I got tired of having to pull out my air compressor from the behind the seat storage, unwind cables, unwind hose, clamp power clips to battery, use, let cool down (throw in the rear floor board temporarily), then put away later.... so i mounted it in the engine bay, wired to in cab switch with relay and all that jazz. cleaned up the switch wires while i was there.
    before:
    after: 20201114_114429.jpg
    self made mounting plate. note the 2 big holes... my marks were off and i realized after i drilled and went to mock it up :anonymous: so i made them freakin huge :D but it worked out, because it allowed it to be rotated to the desired position.
    so i now call it a partial on board air setup :cookiemonster:
    intention is to upgrade to a stronger/bigger compressor and tank setup eventually... I don't really use it all that much currently.
    beertimecontinuum and 14Tacos4me like this.
  10. Nov 14, 2020 at 5:38 PM
    #450
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Do you think that compressor will survive a few splashes through mudholes?
  11. Nov 14, 2020 at 5:47 PM
    #451
    11TRDTX
    11TRDTX [OP] bruh
    Memphis, TN
    :notsure:
    i wanted to put it in a storage container, but couldn't find the correct dimensions that i need/want.... will still keep looking. and what i forgot to add is that one of the cables that i had previously fixed broke at the fuse housing, so i needed to do something.
  12. Nov 17, 2020 at 6:09 PM
    #452
    11TRDTX
    11TRDTX [OP] bruh
    Memphis, TN
    *update*
    I've had a few questions about water/dust/mud, and like i mentioned, i wanted to put it in a container. i found an ammo box at rAcademy for $15.xx. it's a tad bit tight, but it fits and works. outside clearance from the intake tube is good. all sealed up and grommeted for the wires. i won't lie, it was a bit of a PITA, and i was on the verge of regretting the whole project, but i powered through and i happy with the result. all i have to do is connect the hose and turn on.
    i thought about painting it black, but I'm out of black paint and was really ready to be done with the project, so OD it stays.
    beertimecontinuum and totmacher like this.
  13. Dec 7, 2020 at 4:50 PM
    #453
    11TRDTX
    11TRDTX [OP] bruh
    Memphis, TN
    lit bro...
    and the house :santa2:
  14. Jan 31, 2021 at 4:47 PM
    #454
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Thought of you here...
  15. Jan 31, 2021 at 6:48 PM
    #455
    11TRDTX
    11TRDTX [OP] bruh
    Memphis, TN
    14Tacos4me likes this.
  16. Feb 1, 2021 at 7:02 AM
    #456
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Definitely needs googly eyes.
  17. Feb 1, 2021 at 7:48 AM
    #457
    11TRDTX
    11TRDTX [OP] bruh
    Memphis, TN
  18. Feb 8, 2021 at 4:11 PM
    #458
    11TRDTX
    11TRDTX [OP] bruh
    Memphis, TN
    bought a Barrett.... didn't have the $12k for a real one, so i got an airsoft version. it's a licensed functional replica that has a certificate of authenticity. i used to play back in the day, but shoot them for leisure now.
  19. Feb 9, 2021 at 5:58 AM
    #459
    14Tacos4me
    14Tacos4me Well-Known Member
    Daniel
    Hendersonville, TN
    2014 Blue Ribbon DCSB TRD OR 4x4
    -Fox 3 inch lift -SOS Streamline front bumper with Smittybilt x20 winch -Mobtown sliders -Mobtown IFS & Trans skids -DV8 Rear bumper - Look at the build thread
    Will this be coming to AOP?
    11TRDTX[QUOTED][OP] likes this.
  20. Feb 9, 2021 at 7:09 AM
    #460
    11TRDTX
    11TRDTX [OP] bruh
    Memphis, TN
    unfortunately no. i will be missing out again this year :pout:
    march has become a busy month for us within the last few years.
