Mike's 5lug Long Travel rear build
Discussion in '1st Gen. Builds (1995-2004)' started by MadTaco461, Jan 27, 2011.
  1. Jan 24, 2012 at 10:27 AM
    #41
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    When you only had one leaf pulled remember the 0.08 shim stack for compression valving actually worked. Now that you've removed three we finally got a stack of 0.10s in for compression. It's insane how quickly that 50t pack ramps up. Smooth as hell though now that you've got it tuned.
  2. Jan 24, 2012 at 10:30 AM
    #42
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    this is making me nervous lol. i might put solid cement blocks in the bed of my truck if i have too lol
  3. Jan 24, 2012 at 11:10 AM
    #43
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Nah it rides great with three leafs out. Mike has smaller spares though and they're not rated LT like yours I don't think. So... you'll have an extra 25-40 lbs more weight in the back between your heavier tires and cage work. I know the shackle he used contacted the frame so we had to knotch the frame where the shackle hits at full bump. That's at the appropriate angle suggested by engage too. I think a 13" shackle would be a good idea. The 12" works fine but I don't think it could be even a hair shorter without becoming problematic.
  4. Jan 24, 2012 at 11:13 AM
    #44
    MadTaco461
    MadTaco461 [OP] BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    You got more weight than me. Run 12" shackles. 13" is too long. Pull the 5th leaf for sure and maybe the 1st if you start bucking over whoops. If you run smoothies in back they are easy to valve with a few runs. If the pack is new it will settle 1 to 2"
  5. Jan 24, 2012 at 11:17 AM
    #45
    97yota4wd
    Eric
    Mesa, AZ
    why do you think 13 is too long?
    even with the extra weight i will have i should still pull some leafs?
    ill be running tripple bypasses.
  6. Jan 24, 2012 at 11:20 AM
    #46
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Hey Mike, wouldn't a longer shackle prevent it from contacting the frame? The leaf would become it's full length prior to the shackle rising high enough to hit if he used a 13" shackle.
    Just throwing out ideas. I don't design this shit or have an engineering degree so take it with a grain of salt. :D
  7. Jan 24, 2012 at 11:22 AM
    #47
    97yota4wd
    Eric
    Mesa, AZ
    i take all and any advice i can get!but the thing about the 13 inch shackle is i will be a half inch taller in the rear with it.
  8. Jan 24, 2012 at 11:22 AM
    #48
    MadTaco461
    CA
    Kinda stock
    Pulling a leaf will help reduce your spring rate. It gets stiff fast. I'm running 12" and my truck got lifted pretty high. You might be stink bugged with 13's
  9. Jan 24, 2012 at 11:24 AM
    #49
    97yota4wd
    Eric
    Mesa, AZ
    okay, im also a 6 lug 4wd 4 banger if that makes a difference. i guess ill figure it out when i actually install it.
  10. Jan 24, 2012 at 11:24 AM
    #50
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    X2
  11. Jan 24, 2012 at 11:41 AM
    #51
    MadTaco461
    CA
    Kinda stock
    Good luck man, tcyota is also running the pack fyi. you are more close to his setup. Check out his DR build.
  12. Sep 10, 2012 at 6:55 PM
    #52
    nhurt
    nhurt Well-Known Member
    N8
    San Diego, CA
    98 5 Lug
    total chaos, Fabtech spindles, F67 deaver leafs, dual spares, hella black magic's, 55w HID's, sound system, AEM intake, magnaflow, pacesetter headers, electric fan, optima battery, tach, oil water temp and voltmeter gauges, 4.56 gears, loc-rite locker,
    Nice truck man, Im running F67's on my single cab 5 lug. took 3 leafs out still a tad stink bug but i think after I go with 33's as spare vice my 31's and mount a jack between them Ill be good.
  13. Jun 18, 2016 at 8:31 PM
    #53
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Is you battery box just bolted to the bed? Ever had a problem with that?
