Mikuni Carb on my old school LT125 Quad
Discussion in 'All Terrain Vehicles' started by 2009Silver, Apr 2, 2012.
  1. Apr 2, 2012 at 1:51 PM
    2009Silver
    2009Silver [OP] Well-Known Member
    Wisconsin
    2009 Silver 4x4 DC TRD Sport
    WeatherTechs Bed Extender Bed Mat 3" Lift Spidertrax Clarion DVD HU Overhead Monitor
    Hey guys,
    Just looking for direction on what to check for. I have a mint 1986 LT125 Quadrunner I use for fun with my kids. Out of nowhere, it started pissing fuel out of the overflow line on the bottom of the carb.
    This is a small Mikuni carb. Could it be float related, or that little pin that the float is supposed to open and close?
    Sorry for the non-technical information...
    Just looking for somewhere to start checking. My kids are going to be crushed if Dad can't get it going soon.
    Thanks in advance!
  2. Apr 3, 2012 at 11:03 AM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    Sounds like an issue with the float. My 88 quad racer 250 did the same thing before I sold it
  3. Apr 3, 2012 at 11:05 AM
    tacoftw
    McDonough, GA
    05 Double Cab 4x4
    Your best bet with carbs is to just rebuild the whole thing. Rebuild kits run ~$20 and it will run better than it has in a long time
  4. Jun 28, 2012 at 9:04 AM
    2010TRD
    2010TRD Well-Known Member
    Thomas
    Waldo, FL
    2010 MGM trd offroad DCSB
    Billistein 5100 front/rears, Toytec 2" AAL Custom grill, All Pro rear bumper, All Pro sliders, Anytime elocker/foglights, Rear diff vent relocated, W/O seat covers, weathertech mats/visors, nfab tire racK, cobra 75 stealth CB, Custom engine/trans skids 3/8", Hella and HID behind grill, LED bar backup light, LED pods under cab (rocklights)
    Sounds like the floats have sprung a leak........if a float fills up with fuel, then it sinks, and the needle valve opens, allowing excess fuel into the bowl.......causing the excess fuel to flow out the overflow
    simply rebuilding the carb....wont fix this issue
    You will most likely need a new float.
    When you remove the float (to rebuild carb) shake the float around in your hands, and see if you can feel fuel/liquid inside the floats.......if so.....you need new float too.
    Most mikuni carbs on small 125's are the same, and have interchangeable parts like floats.
