milage, faked easily?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gearheadesw, Aug 13, 2014.
  1. Aug 13, 2014 at 9:54 AM
    BamaToy1997
    Bill
    Navarre, FL
    Obviously without knowing how you claim to do this, I can only conjecture, but I do not see any way to turn off the odometer without causing issues with the ABS, Cruise control, transmission, etc. I call this one out.
  2. Aug 13, 2014 at 11:08 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    and how the hell does one manage that?!?!
  3. Aug 13, 2014 at 11:33 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Its not that low. I bought my '06 in Feb. 2011 with 18,000 miles. Now it has 73,000 miles.
  4. Aug 13, 2014 at 11:41 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    No one ever said it didn't effect electronic systems, but the ones you have listed aren't all effected and some are that you didn't list :cool:
    Call me a liar all you want, but I'm not retarded enough to post a "how to" on disabling the ODO publicly nor do I really feel like sharing this info with people I don't trust/know just because they called me out on some forum :laugh:
    With a little help from my friends
  5. Aug 13, 2014 at 12:35 PM
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    You must drive a lot to have a car payment completely offset by fuel savings. How much do you drive a year/month?
  6. Aug 13, 2014 at 12:38 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    WTF do the aliens from Mars Attacks care about odometers?
  7. Aug 13, 2014 at 12:49 PM
    WThomas1250
    WThomas1250 Well-Known Member
    Wouldn't call that suspiciously low mileage. The PO of my truck had two trucks, when I was going through service records I saw that he only drove it about 55k miles in an 8-year period. It happens
  8. Aug 13, 2014 at 1:24 PM
    Andrewjl
    Andrewjl New Member
    My 2008 has 36k miles. Only car and totaly possible
  9. Aug 13, 2014 at 1:33 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I was going to say: check the pedals.
  10. Aug 13, 2014 at 1:39 PM
    whonoez
    whonoez Well-Known Member
    Jay
    Bay Area
    2013 Tacoma TRD Sport DCSB
    3"lift, Monster XD w/ 285/65/18 Nitto Trail Grapplers, Blacked out emblems, tinted front windows, BHLM
    Mileage isn't that low IMO... I have a 2010 Infiniti FX35 and I barely hit 45,000 miles.
  11. Aug 13, 2014 at 1:43 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Dont underestimate how easy it is to roll back.
    I've seen the mileage rolled back on our digital clusters, it's stupid easy with the right tool. Don't have to touch the ECU. It's all in the cluster readout. Could also swap in a different cluster with lower miles
    That being said 30k in 3-4 years isn't that bad
  12. Aug 13, 2014 at 1:46 PM
    TacoLlama
    TacoLlama Well-Known Member
    R.I.
    2019 SR5 DCSB
    I just grabbed a 2011 with 23k on it.Engine ticks,has random vibrations,radio is comparable to something in the 80's with mechanical knobs.Make sure you friend knows that these are all normal tacoma stuff. :D
  13. Aug 13, 2014 at 2:44 PM
    sabu
    sabu Squirrel Driver
    Ron
    So. Cal.
    MG 4x4 TRD OR AC
    XM Radio, Redline hood lifts, X-tra bed tie-downs
    My 09 just rolled 25k. Like others said, more than one car to drive, so the 4x4 sits in the garage.
  14. Aug 13, 2014 at 2:49 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    As previously stated, look for abnormal wear for that mileage, and Inspection / Maint. records
    I have 2010 Tacoma - 33,000 mi +/-
    2000 Solara - 30,000 +/-
    Both bought new, still look relatively new and driven primarily by myself.
    Also have other vehicles.
    So, with a similar scenario, the mileage could be accurate
    CC
  15. Aug 13, 2014 at 3:19 PM
    #35
    BamaToy1997
    Bill
    Navarre, FL
    First off, I think my post stating "issues with the ABS, Cruise control, transmission, etc." shows that I know there are more modules that can be affected. It is pretty easy for someone to come in and make a claim, but then deny how it can be done, thus making it impossible for someone to prove or disprove your claim. Besides, your "fear" of posting how is unfounded. There is no law or government entity that can do a thing to someone who posts "how to" do something, even if it is illegal. You can buy the Alchemist's Cookbook which shows how to build bombs. Bombs are illegal, but showing how to make them is not. If you want to put any weight behind your claim, then let's hear it. Otherwise it is simply smoke and mirrors. I have been working on these systems for many years, and I know exactly how they work, and how the information is handled. And until you can post proof otherwise, yes, I will call out your statement as false.
    I'm not doubting that an odometer in the cluster can be adjusted with the right software. My argument is that IF this is done, there would be a code set, and it would be too easy to prove the odometer was tampered with.
  16. Aug 13, 2014 at 3:21 PM
    #36
    T4RFTMFW
    T4RFTMFW Well-Known Member
  17. Aug 13, 2014 at 4:05 PM
    #37
    XXXX
    sKiP
    05 Prius
    This isn't the first thread I have commented on like this over the years.
    I'm not posting here to help you or one up you. Just trying to tell OP and everyone else to watch out because these trucks are super easy to run up miles on.
    Your lack of knowledge regarding this topic and calling me out has no effect on me. Ive seen it done by multiple people and I was shown how to do it by a pro. I know it has been done on trucks that were returned to Toyota with 50-60k less on the ODO then the truck actually had. Believe me or not I could care less.
    Bob would not want info on how to do illegal things posted on his site and doing so is against the COC.
    I am not the only person on TW who knows how to do this :spy:
    At least 450,000 care per year are sold with false mileage... do some research and you will find it's much easier than you keep making it out to be.
    These guys know their shit (professionals) and still look at seat and petal wear
    http://homepage.aiminspections.com/... Increase in Odometer Tampering - NYTimes.pdf
  18. Aug 13, 2014 at 4:38 PM
    #38
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    My 2012 purchased in May of that year has 14,000~ on it. So 27 months = 518 miles per month. If I drove that 2010, that lets say I purchase 1/2/2010 that would be 44 months. At my mileage level that would be 22,792. So, 30,000 seems well within reason.
    I don't commute to work and my mileage comes from running around town. Although we did drive it to New Orleans (from Fort Worth) which is about 560 miles each way, and to Kansas City which is about the same distance, so those two trips put on about 2,240 of those miles. Without those trips, I'd be at about 12,000 miles or 428 per month.
  19. Aug 13, 2014 at 5:25 PM
    #39
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    You are almost always correct in your knowledge on cars from what I have read previously but you need to see the dark side. Rolling back is easily done on the tacoma.
  20. Aug 13, 2014 at 5:43 PM
    #40
    XXXX
    sKiP
    05 Prius
    X2...without setting off codes or anyone knowing it was done. ECU shows updates.... single rewritten chips do not.
    BTW - I just asked a mod and posting any DIY methods on stopping the ODO or rolling it back are grounds for immediate perma ban. Even PM'ing the info can get you gone :)
    I'm done.
    Moral of the story - check for wear and don't trust the ODO.
    A drunken money could stop it from accumulating miles and a high school science nerd could roll back your ODO with free software and a excel spreadsheet.
