Mild lift for new tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by glwood6, Dec 22, 2008.
  1. Dec 22, 2008 at 10:19 AM
    glwood6
    glwood6 [OP] Well-Known Member
    Gary
    Albuquerque, NM
    '13 MGM AC 4x4 TRD OR
    Husky front mud flaps, OEM bed mat, 3D floor mats, Wet Okole seat covers, fog lights anytime mod, rear diff breather extension, aluminum Relentless tailgate reinforcement, NWexpo corner gussets, 265/75-16 Hankook Dynapro ATM
    Gonna get a new set of probably BFG A/Ts next go round, thinking of getting 265/75/16. What is a reasonable inexpensive lift that is not going to change the ride characteristics, yet give me enough room for these? I know this has probably been discussed to death, sorry. My experience with lifts for the last decade has been exclusively with Jeeps...
    Any before and after photos of a 1st gen extended cab with a mild lift would be great!
  2. Dec 22, 2008 at 10:30 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    You don't have to lift to fit 265/75/16s.
    Though if you do want a mild lift you can get a set of Bilstien 5100s and set them at 1.75" up front. Then the truck will be nice and level.
  3. Dec 22, 2008 at 10:55 AM
    hardtaco
    hardtaco Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    How much do you think a set of those would cost? Ease of installation? Alignment necessary afterwards?
  4. Dec 22, 2008 at 11:01 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    I did have 265-75-16 on mine with no clearance problems whatsoever. I will be going back to that size soon. I am running the stock 265-70-16 right now but they are wasted! I will go with the additional 1" of overall diameter with the 265-75-16, since they will fit with no lifting required. Hope this helps.
  5. Dec 22, 2008 at 6:17 PM
    TuFF_Taco281
    TuFF_Taco281 Member
    Texas City, Texas
    SR5 3.4L V6 PreRunner Double Cab 2WD
    K&N Cold Air Intake, K&N Air Filter, Flowmaster 40 Series dueled out
    :thumbsup:
    I have BFG A/T KO 265/75/16 on my 2003 PreRunner Double Cab with no lift at all. Though I do recommend a leveling kit, because the fronts rub on sharper turns at a higher rate of speed. Not much to bother anything on the truck.
  6. Dec 22, 2008 at 6:18 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I got mine at allprooffroad.com for $99.99 a piece.
  7. Dec 23, 2008 at 8:35 AM
    glwood6
    Gary
    Albuquerque, NM
    Please excuse my ignorance...how does a shock absorber add any height?
  8. Dec 23, 2008 at 9:01 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    on the 5100's, there are 4 different spring seat positions on the shock. this preloads the spring and lifts the front of the truck to varying heights. the settins on the shock are 0.0, 0.85, 1.75, and 2.5 inches.
    here is a description from bilstein:
    http://www.bilstein.com/Height_Adj_5100-Feb06.pdf
  9. Dec 23, 2008 at 9:16 AM
    glwood6
    Gary
    Albuquerque, NM
    Does the higher setting make the ride harsher? This sounds too good to be true...:)
  10. Dec 23, 2008 at 9:29 AM
    NetMonkey
    Geogetown, TX
    from what people on this site have reported, the ride on the 0.85 and 1.75 setting is stiffer, but worth the added height and clearance. however, on the 2.5 setting the ride is much stiffer. on all the lifted settings, the "taco lean" is minimized or negated. the front of the truck will also not plow forward during moderate to heavy braking.
  11. Dec 23, 2008 at 9:31 AM
    Khaos
    Khaos Big Member
    Bryant
    Oh thank God. Thats one of the biggest issues I have with my truck is the damn lean when you hit the brakes.
  12. Dec 23, 2008 at 10:30 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Would an alignment have to be performed after installation? How about after each height adjustment?
  13. Dec 23, 2008 at 11:01 AM
    NetMonkey
    Geogetown, TX
    yes... each time you change suspension height or modify suspension components, you will need an alignment.
    from what i have read on this site, with the 0.85 and 1.75 settings, you can get a proper alignemnt. on the 2.5 setting, however, you may not be able to get a proper alignment unless you put on new upper control arms (UCAs) that are designed for the increased angles.
    if you go 3.0 inches in lift, you will definately need new UCAs to get a proper alignment.
  14. Dec 23, 2008 at 11:38 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    I think I will leave mine the hell alone!!!
  15. Dec 23, 2008 at 11:44 AM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    UCA's are not needed for 3 inch lifts on pre-05 Tacomas, as for the alignment, its recommended you get one but I put a 3inch spacer and only thing slightly out was the front toe, so I would say have it done, but not "needed"
  16. Dec 23, 2008 at 6:30 PM
    glwood6
    Gary
    Albuquerque, NM
    i'm with you on this, I've been down that road too many times. You change one thing, and it starts a domino effect, change after change.
  17. Dec 23, 2008 at 8:35 PM
    pittim
    pittim mittip backwards
    Pink slider.
    Yep.
    Was thinking about getting coilovers. So then I would need UCAs ($1600 for Icon C/Os and TC UCAs). Of course I'd need stuff for the rear. I'd get the Icon rear shocks and deaver leafs ($1000.) But if I upgrade the suspension all around I'll need armor. Sliders are like $400, full skids are around $500 (budbuilt.) Why not upgrade the bumpers while i'm at it. Shrockworks front bumper alone is $1000, haven't picked out what I want for the rear (can't really find anything for rear bumpers) Gotta get new wheels and tires for the truck now. Wheels (KMC Enduro (~$120 online)) and tires (not sure what yet, but assuming around $150 each) x5
    So my wishlist is up to ~$6500 for parts. No shipping, no installation.
    :help:
  18. Dec 23, 2008 at 8:42 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    hmm Im very happy with the setup I got so far.
    King c/o-400 off craigslist
    bilstein 5125 rear shocks-100 for both off craigslist
    rear AAL for rear lift-50-off craigslist
    wheels and tires-550 hook up at dealer for tires and wheelers.com for rims
    so with 1100 i have a pretty capable rig
    It doesnt take much, just look around for deals
  19. Dec 24, 2008 at 4:23 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    i put 265/70r17s BFG AT KO on my 04 taco trd and i think thats the biggest you can go without any lift. when i first put them on the front tires would rub when the wheels were turned all the way. i just cut out some of the plastic and cheap rubber moulding inside the wheel well to get rid of the rubbing though.
    i have the tires for life program at my toyota dealership so those tires cost me $88 dollars altogether. when i need new tires in the future i will probbaly go the next size up and get a very mild lift and level out the front so the tires will fit perfectly.
