Mild Lift vs shock length
Discussion in 'Suspension' started by Flyin Brian, Oct 3, 2011.
  1. Oct 3, 2011 at 1:13 PM
    Flyin Brian
    Flyin Brian [OP] New Member
    Brian
    Bend
    00 Tacoma TRD
    Hello all, first time poster here. I've searched through the threads for this but I've had no luck so far.
    I just picked up a 2000 Tacoma xtra cab TRD 4x4 with the 3.4.
    First thing I need to do is get new shocks for her. So my question is this..
    In the future I plan on putting a mild lift (under 3"). From reading through the forums I'm thinking of doing the Bilsten 5100 coils up front and an AAL in the back. If I stay under 3" of lift do I need to buy rear shocks that are longer or will the stock length be Ok? At what point do the stock length shocks limiting travel?
    I'm starting with purchasing rear shocks then moving on to the front.
    Any help would be appreciated..
    Cheers,
    Brian
  2. Oct 3, 2011 at 6:28 PM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Yes you will need to buy longer rear shocks, i belive the 5100's rear are for 1" or so. You might want to look into the 5150 series. Once you go over 1" or so you can hear the shocks overextending and slamming out.
  3. Oct 3, 2011 at 6:34 PM
    wolfman00
    wolfman00 Well-Known Member
    matt
    Annapolis
    '17 BRM SR manual 4x4
    stock
    you can also look into 5100s from the front of a jeep wrangler. they are 24.6" extended. I called DSMS and marco set me up with those. So far they have been great. Also, fully compressed they have 1.5" of shaft left while bottomed on the bumpstop.
  4. Oct 4, 2011 at 6:58 AM
    Flyin Brian
    Brian
    Bend
    00 Tacoma TRD
    Thanks for the info guys! So I take it a longer shock will be ok prior to installing the AAL? I would think it should be...
  5. Oct 4, 2011 at 8:51 AM
    brianpdx
    brianpdx Well-Known Member
    1999 SR5 TRD 4x4
    Huh? From Toytec's website:
    "Rear D560 extended length 5100 Bilstein shocks work great with 1 to 2 1/2" lift."
    From DSM's website:
    "This 5100 Front/Rear Package is recommended when installing an AAL/Shackle in the rear."
    5150's aren't necessary for a simple lift.
  6. Oct 4, 2011 at 7:43 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Ohh i got them confused
