Mild Lift
Discussion in 'Suspension' started by T Fades, May 18, 2012.
  1. May 18, 2012 at 9:18 AM
    T Fades
    T Fades [OP] Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Wanting a mild lift for my '11 DCLB SR5 PreRunner. I have searched and read probably dozens of threads now, and just looking for more confirmation if this setup is good. I know, I know
    :deadhorse:
    Would like to stay with a mild lift (1.5"-2") due to cost, I never offroad, and my daily commute is 70/day (so mileage is an issue), and would like to stay away from needing other parts like UCA's. I also really want to keep my ride as soft as possible. The only heavy lifting will be towing a 17' bass tracker in the future, and the occasional dirtbike in the back going to the desert.
    What are your thoughts on the following lift:
    - Billies all around, set at 0 for the front.
    - Eibach springs for the front.
    - Rear spring TSB.
    - Keeping stock OR wheels, and upgrading tires from stock 245s to 265/75/16.
    - Alignment.
    I think this would give me about 1.5" lift in the front, and maybe 1" in the rear, correct? Would I be sitting nose high when towing the boat?
    Also, how much do you think all of this will cost me? I will most likely take it to a shop to do it all (except the dealer will do the TSB and alignment).
    I really like the soft ride sitting stock now, but would like to get a little lift for looks, but don't want to regret stiffening the ride too much just for looks.
  2. May 18, 2012 at 11:01 AM
    T Fades
    Simi Valley, CA
    bueler...
  3. May 19, 2012 at 9:05 PM
    Nubes
    Nubes Tacoma Addict
    Texas
    2011 Silver TRD O/R DCSB PreRunner
    Gray WeatherTech's front and back, DeeZee bed mat, Foglight Mod, Magnaflow 12256, Debadged, Ammo Can Storage Boxes, Shrockworks Sliders.
    This is exactly what I was planning on doing as well, but I think I am gonna get the taco lean spacer too. Also wondering if the truck will be nose high when towing. If so I guess an add-a-leaf will be needed? As far as cost, eibachs are $160+ship from toytec, and $300 for billies from DSM with free shipping, then what ever your shop charges for labor. For tires I priced some Hankook ATm's for $600 installed at discount.
  4. Jun 14, 2012 at 4:17 PM
    T Fades
    Simi Valley, CA
    bumpski
  5. Jun 14, 2012 at 8:20 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    That's a great plan man....deff 265's as they are on the OR trucks so you'll be fine!
  6. Jun 14, 2012 at 8:26 PM
    JNome
    JNome Made in Maine.... Yessah bub!
    Jake
    Pace, FL
    '10 BSP SR5 4wd
    WeatherTechs, TRD Skidplate, Hidden Hitch Reciever, Tractor Supply Toolbox, Bedmat, Hayden Transmission Cooler, Leer 100R cap, yakima roof rack, Bilstien 5100's all around, Eibach lift coils, Toytec AAL w/ TSB springs, All Pro Flip Kit w/ Timbrens, Line X'd Rocker Panels, Magnaflow 17115 Exhaust, Cobra CB w/ PA Horn, Hi-Lift Jack w/ custom mount, Relentless Fab Sliders, Satoshi Grille w/ Hella 700's HID mounted behind
    I did the same lift but instead of Eibachs I had my billies set to the 1.75 notch to preload the springs. Ride feels fine to me. Also I am running TRD OR wheels with 265/75 16 and just had the TSB done so I am slightly higher in the rear. Alignment too. So far no issues. There are lots of threads and pics on here of guys running this same set up.
  7. Jun 14, 2012 at 8:35 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    New springs for less pre-load will be the better ride in general!
  8. Jun 14, 2012 at 8:55 PM
    JNome
    Jake
    Pace, FL
    '10 BSP SR5 4wd
    ^ Agreed if you have the cash to do it. I will be going that route in the future. Do they make an Eibach that gives you that short of a lift? I was under the impression that Eibach's only came in a 3 in lift size? I could be wrong... still learning bout this stuff myself.
  9. Jun 15, 2012 at 8:56 AM
    T Fades
    Simi Valley, CA
    I think the Eibachs give a 3" lift for 1st gens. For 2nd gens, it is around 1.6" (from what I have read on TW).
  10. Jun 15, 2012 at 9:37 AM
    JNome
    Jake
    Pace, FL
    '10 BSP SR5 4wd
    Agreed... did some research on Toytec last night. If used with the 5100's at "0" setting the Eibach coils provide 1.6" of lift. I think you will be happy with this lift, tire and wheel combo. I now I am with mine even though I have my stock springs preloaded at the 1.75" setting.
  11. Jun 15, 2012 at 9:51 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I have exactly what you are planning. I don't remember what I paid, but I think I had that done for around 500 or so. Great set up, doesn't really effect gas mileage at all, and rides real nice. Here's what it looks like.
  12. Jun 15, 2012 at 10:58 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If you want a soft ride, I wouldn't go with Eibach's. I'd instead consider OME 883's or 884's. For a double cab, the 883's will put you around 1.5" of lift, the 884's around 2". They're closer to the stock spring rate so if that's what you're accustomed to and would like to stay at, you might want to look into them.
    I've got 5100's and Eibachs and I'm not trying to bash the setup but it is noticably stiffer than stock anf if you ride rough, pothole riddled city streets, might be a little uncomfortable. On backroads or highways, they are awesome, very little truck roll and significantly reduced nose dive when braking.
  13. Jun 15, 2012 at 2:11 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    If the eibach's are not preloaded the 600lb spring and not the 650 would prob be good......or the OME like pugga said.
  14. Jun 22, 2012 at 3:44 AM
    AMSFLVA
    AMSFLVA Active Member
    Where did you get your lift from? What's your set up?
  15. Jun 22, 2012 at 3:52 AM
    AMSFLVA
    Newbie here I have been planning to do this modification for 2 years now lol. 884's OME? IDK after market coils?! I have a 2010 DC SR5 2WD without the TSB. I would like to do the same lift which company has the best deals or pricing? Sorry for the ?'s.
  16. Jun 22, 2012 at 5:21 AM
    Pugga
    Massachusetts
    F-150 Mod
    Not entirely sure what you're asking but OME = Old Man Emu. The 884 is a coil designation. OME makes 4 coils that fit the Tacoma, 883, 884, 885 and 886. The 883, 884 and 885 all have the same spring rate, the 886's are much stiffer and are intended to be used on a Tacoma with a heavy steel bumper and a winch (200+ lbs). On a Tacoma like yours, the 883's should give you around 1.5' of lift, 884's should give you right around 2", 885's should give you around 2.5 - 2.75" of lift. The OME coils can be paired with their own Nitrocharger shocks or with Bilstein 5100's.
    The lift that I have is Eibach coils on Bilstein 5100's. Eibach coils are stiffer than the OME coils and only give you 1.6" of lift on a double cab. You can kick the 5100 setting up to .85 and get closer to 2.5" of lift with these coils also.
    For Old Man Emu and Bilstein 5100 pricing, check out Toytec Lifts, Wheeler's Off Road or call Downsouth Motorsports. Eibach coils are exclusive to Toytec lifts.
    Check out this thread also, some good info here:
    http://www.tacomaworld.com/forum/suspension/11282-tacoma-lift-faq-guide-read.html
  17. Jun 22, 2012 at 5:31 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
