Mildew Smell after rain & car wash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tyler Andrews, Sep 6, 2023.
  1. Sep 27, 2023 at 12:58 PM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    You can't see the sealer. It is covered but the trim. That sealer on the light is where the tech didn't do a great job at cleaning up after the job was done.
    bkhlrTaco's[QUOTED] likes this.
  2. Sep 27, 2023 at 2:47 PM
    Tyler Andrews
    Tyler Andrews [OP] Well-Known Member
    Tyler
    Portland
    2018 Super White Sport 4x4
    I had thought it was this too, however, after truck sits through a rain I'll get in and it smells right away without either AC/heat turned on. Cabin air filter is dry as well.
    Woofer2609 likes this.
  3. Sep 27, 2023 at 2:48 PM
    Tyler Andrews
    Tyler
    Portland
    This is also what the service technician told me today. I feel I can put the 3rd brake light behind me as a culprit for water intrusion.
    rolled93slc[QUOTED] likes this.
  4. Sep 27, 2023 at 2:53 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    What did you all do during that detailing. Carpet cleaner?
    What cleaners and where did you use them. Wondering if something didn't dry out good from the detailing.
  5. Sep 27, 2023 at 3:22 PM
    Tyler Andrews
    Tyler
    Portland
    When I detailed last I just gave the interior a good vacuum, no carpet cleaner or liquid was used that wasn't first sprayed directly onto a microfiber towel.
  6. Sep 27, 2023 at 3:26 PM
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    check the cabin air filter. I had water get into it and since you had to pull all that junk out from under the hood, I would look there
  7. Sep 27, 2023 at 3:39 PM
    Williston
    Williston Unknown Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    Got it. You either have a hidden leak somewhere that has been there long enough to cause the stink, or an accumulation for rotting leaves and junk in a cavity somewhere. One other problem spot to inspect is the cavity in the fenders just in front of the doors. Open the doors and pull the rubber seal panel aside. On my truck the fender cavities were filled right to the top with crap, and the bottom third was basically muck. Obviously it had been accumulating for seven years since the time it was built. Clean out anything you find. I think you said you already checked under the plastic cowl trim under the windshield. Leaves, pine needles and other debris gets in there by the openings for hinges, and block the drains over time. Gently pour some water in that area and see how long it takes to come out behind the front tires: it should be immediate. If it's coming out slower than you are pouring it in: investigate why. Good luck. You'll find the source.
    Other than that, pull up the carpets next to the seats and see if you have a waterlogged carpet or insulation mat. These will get worse and worse over time and will never dry out unless they are removed. Gently pull up the edges of the plastic sill plates next to the seats and lift up the carpet. The sill pieces should pop right out.
  8. Sep 27, 2023 at 3:45 PM
    Tyler Andrews
    Tyler
    Portland
    I will try both of those ideas this evening, I appreciate the support with this. Will loop back around and let you know what I find out (Or not find out)
    Williston[QUOTED] likes this.
  9. Sep 27, 2023 at 3:55 PM
    Williston
    Sounds good! The best part of these threads in when the culprit/solution is reported. Water leaks can be a nightmare to find, especially since even a tiny one can wreck havoc over time. They can also travel a long way and end up soaking an area far from the source.
    Chew likes this.
  10. Sep 28, 2023 at 4:52 AM
    rolled93slc
    Jerry
    Lynchburg VA
    I think someone mentioned the evaporator cleaning kit that Toyota has. Also check to make sure that the evaporator drain tube. Make sure it hasn't come off. It's on the passenger side, toward the firewall. We have had a few that the internal drain in the evaporator box, wasn't drilled out completely/had plastic flash still in it, that would cause the box to leak water. But those all came in with customer complaints of water dripping on the floor.
    Tyler Andrews[OP] likes this.
