Mile Marker 10K winch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drtrider145, Aug 29, 2014.
  1. Aug 29, 2014 at 4:53 PM
    drtrider145
    drtrider145 [OP] Well-Known Member
    Phoenix Az
    Pre runner for sale , 2006 DCLB
    will a Mile Marker 10K winch fit on an undercover winch mount?
  2. Sep 2, 2014 at 4:01 PM
    Large
    Large Red
    No need for 2 threads. There are 2 vendors for our 2nd gens, one is here and the other here. I believe the mounting pattern for both is 4.5x10 or 4.5x8, you can find out by clicking the links I sent. You should also look up the winch you want, the mfg specs should tell you the mounting pattern, it has to have a removable solenoid for it to work under there if you don't want a headache.
    I did the research, the mile marker winch is 4.5"x10"
    Good luck.
  3. Sep 2, 2014 at 6:17 PM
    drtrider145
    Phoenix Az
    Ok thanks , where is the best place to buy a Undercover winch mount for an 05 dclb
