Mileage and Larger Tires
Discussion in 'Wheels & Tires' started by billas333, Jan 22, 2009.
  1. Jan 22, 2009 at 8:48 PM
    billas333
    billas333 [OP] They Still Love To Hate Me! - T.O.
    Joel
    NorCal
    2008 4x4 Tacoma Sport
    Mods so far: Tube steps from toyota, Bed extender from toyota, Spare Tire lock, Sound System Makeover, Tacoma All-Weather heavy duty rubber floor mats. Rear TSB, Icon Coilovers w/ TC UCA's and 3inch rear block with rear 5100 bilstein shocks, Black Headlights, Grillcraft black grill, Devil Horns from Andres, Black Headlights, Chrome Liquid Metal Gatlins Wheels, 285/70R17 Nitto Tera Grapplers, Wet Okole Seat Covers! Seat Belt Chime Mod, Flowmaster 50 series dual exhaust, Debadged tailgate, TRD Decals, HID hi/low + fogs.
    Ok so I just upgraded from my stock 265/65R17 tires to some new nitto tera grapplers 285/70R17 and I always hear the complaint that larger tires will decrease your gas mileage and I was curious as to how much this truly affects it.
    So I am assuming that with every rotation of the wheel the odometer counts this distance traveled and the circumference of the stock 265/65R17 tires on the 2nd gen is 8ft. So therefor the wheel must rotate 660 revolutions to travel one mile.
    The 285/70R17's have a circumference of 8.56ft and must rotate only 617 revolutions to go one mile.
    Basically I calculated that for every mile traveled on the odometer you would in fact travel 1.07miles with the larger tires.
    Has anyone else done this or am I the only dweeb????.
    So it seems to me the gas mileage decrease should not be as bad as it sounds and I will be testing this.
    If you fill up your tank with larger tires multiply your mileage at fill up by 1.07 and that was your true mileage traveled. Then divide that by how many gallons you put in.
    Also larger tires it seems would benefit the miles recorded since you are traveling farther with every rotation.
    every 100,000 miles on the new 285/70 tires would actually be 107,000 miles.
  2. Jan 23, 2009 at 9:10 AM
    billas333
    Joel
    NorCal
  3. Jan 23, 2009 at 9:19 AM
    betz.steven
    betz.steven Well-Known Member
    Southern NJ
    2011 TE 4Runner
    So.... for warranty you would get an extra few thousand out of it? ;)
  4. Jan 23, 2009 at 9:23 AM
    Oh_Six_Taco_4x4
    Oh_Six_Taco_4x4 Professional High Fiver
    Orange Park, FL
    TRD Sport 4x4
    OEM skid plate. 3" Toytec lift with AAL. Trail Gear Rock Sliders Rechargable Maglite
    If a train leaves New York traveling 63 MPH.....:frusty:
  5. Jan 23, 2009 at 9:24 AM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    12 DCSB TRD Off-Rd 4x4, Roof Rack, Tube Steps
    K&N drop-in air-filter, extra D-rings, Custom Console lock-box, Leather heated seats, Studly Driver
    That is true if you have a tire that, while taller, weighs the same and is no wider than the first. Weight and width negatively affect mpg. Wider tire = more friction. Heavier tire = more juice to make it move. Normally the extra distance gained per revolution doesn't come close to the extra effort to start and keep moving.
  6. Jan 23, 2009 at 9:47 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    No, you're not the only one;). I use a similar equation to figure out my gas mileage, accurately that is, with the larger tires.
    I had also thought of using an on board GPS system to figure the mileage, but after some thought i concluded that this would not be as accurate as figuring the conversion without rounding too much, or at all for that matter. The problem with figuring mileage through GPS systems is that any system you could purchase for your vehicle runs in an Autonomous state. Your positioning is rarely, if ever fixed and definitely not going down the highway. Not only that, it can not accurately depict turns, due to taking multiple snapshots per minute. The only reason why i know this is because i specialize in GPS Surveying and automated machine control processes. Sorry for the rant, but I hear people doing this way too often.
  7. Jan 23, 2009 at 1:35 PM
    billas333
    Joel
    NorCal
    Dont know about the train one sorry lol
    just wanted to provide some insight because i remember longhorn saying he was down o 12mpg which i thought was nuts but who knows.
    i will have a decent estimate sometime in the next 10 days of where my mpg is using my lil equation =)
  8. Jan 23, 2009 at 1:43 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    In the end your gona lose 1-2 mpg
  9. Jan 23, 2009 at 1:47 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    FYI, there are tons of tire size calculators available on the web. They'll do the heavy math for you. You're calculations to figure out fuel economy are correct. On my 02, the 33/10.5/15 BFGs hardly affected the fuel mileage.
  10. Jan 23, 2009 at 2:01 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Actually a taller tire will be harder to turn even if the weight is the same as the shorter tire. Inertia increases as a square of the distance. An example is a figure skater. When the figure skater's arms are tucked in, she spins easily but when her arms are out it's harder to spin that fast. Whether her arms are in or out, she weighs the same. If you add weight, that will only compound the problem.
  11. Jan 23, 2009 at 2:21 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I use a similar factor when calculating my mpg. Since I have a 2wd base, the tire sizes aren't the same, but the formula basically is. I multiply by 1.117.
    Old size=215/70/15
    New size=30x9.5/15
    I don't know how bad the mpg suffered on mine. The tires were already on it when I bought it.
  12. Jan 23, 2009 at 2:37 PM
    williegator
    williegator Well-Known Member
    atlantic beach florida
    trd sport 4x4
    toytec Ultimate kit set @ 3 inches, Light Racing UCA's, HELO HE791 17X8 WHEELS, BFG 285-70-17's, secondary air filter removed, ARI drop in filter, Scan Gauge, Roll N Lock
    What if you used a Scangauge to give you fuel GPH and going down the interstate at 55 mph (based on a GPS and not your speedo). Then do your math based on results at a 55 only.
  13. Jan 23, 2009 at 2:54 PM
    cvillechopper
    Charlottesville, VA
    Good point. I wasn't thinking that a significant percentage of the weight of the tire is around the circumference.
  14. Feb 26, 2009 at 6:31 AM
    Hardcorehehaw
    Hardcorehehaw 1 man wolf pack
    Evan
    09 Magnetic Gray PreRunner
    Debadged, 20" Liquid Metal Magmas, Yokohama Parada Spec x 285/50/20, Llumar clear bra, Fold-A-Cover G4, Weathertech liners, Wet Okole seat covers, JBS technologies keyless entry keypad.
    So what did you figure out?
  15. Feb 26, 2009 at 8:59 AM
    billas333
    Joel
    NorCal
    18mpg before lift and tires, 17mpg after lift and tires, maybe even less now that I put on my exhaust. :-(
  16. Feb 26, 2009 at 9:00 AM
    Hardcorehehaw
    Evan
    I can live with 17, I may have to start shopping around for a lift :)
    Thanks!
  17. Feb 26, 2009 at 9:18 AM
    bwood_usmc
    bwood_usmc Wiskey Tango Foxtrot....
    Ben
    Clayton Ga / Clemson SC
    06 Tacoma TRD Off Road package
    3" Trux Lift, 285-75-R16 BFG All Terrains, K&N Cold Air Intake
    I figured this out an easier way.... the mile markers on the interstate.....lol.... that gave me a round about conclusion
