mileage corrections.
Discussion in '1st Gen. Tacomas (1995-2004)' started by AlexanderD, Apr 7, 2010.
  1. Apr 7, 2010 at 7:41 AM
    AlexanderD
    AlexanderD [OP] Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    hey,
    so when changing to larger tires. from say my 235 70 r16s to say 31" tires there will be a change in gearing and therefor a change in odometer reading over a given distance. this will throw off a mileage calculation by a few points at least i would think
    calculations.
    235 70 r16
    235x.7=
    164.5 x2=
    329 / 25.4=
    12.95+16=
    28" dia
    28x3.14=
    90.95" circumference
    31"dia
    31x3.14=
    97.39" circumference
    that roughly a 6% difference
    thoughts?
    is there a way to match things up so the odometer will read correctly?
  2. Apr 7, 2010 at 7:45 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    As far as I know there is no way to correct the Odom in our trucks. However if you have a scanguage it keeps the correct mileage. I check the scanguage against my math everytime I fuel up.
  3. Apr 7, 2010 at 9:03 AM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    How does a scangauge know that you have a different tire size?:eek:
  4. Apr 7, 2010 at 9:11 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    You program it in on the initial setup.
  5. Apr 7, 2010 at 9:13 AM
    Chad
    Chad Well-Known Member
    Chad
    Raleigh, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- BHLM -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- 09+ Access Cab Rear Headrest Removal
  6. Apr 7, 2010 at 9:27 AM
    Chad
    Chad
    Raleigh, NC
    True, but still, it's nice to have everything synchronized with what it should be. MPG, Speed, Odo, etc. It also helps with the gears and shifting.
  7. Apr 7, 2010 at 9:27 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    yeah Id go scanguage 2. You can also customise some of your options on you Scanguage.
  8. Apr 7, 2010 at 10:51 AM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    I drive w/my GPS on. Good thing too. With 35" tires on my Gen 1, Speedo off appx 8mph. Big difference!! Is there really no way to recallibrate?
  9. Apr 7, 2010 at 12:07 PM
    AlexanderD
    Alex
    whitby Ontario
    i hope you use your gps for reference for your oil changes!
  10. Apr 8, 2010 at 5:27 AM
    AlexanderD
    Alex
    whitby Ontario
    the difference is actually a parabolic curve. so the faster you go the more the difference is from read to actual. at what speed is yours out by 8mph?
    there must be some way! how does the speedo actually work? is it electronic? or is it mechanically driven?
  11. Apr 8, 2010 at 7:01 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  12. Apr 8, 2010 at 7:19 AM
    AlexanderD
    Alex
    whitby Ontario
  13. Apr 8, 2010 at 9:16 AM
    Coolidge
    So Cal, Ca
    2003 Pre Runner
    Why? :confused:
    Just change your oil frequent/regularly
  14. Apr 8, 2010 at 8:21 PM
    dispatcher101
    dispatcher101 Active Member
    Dan
    Colorado
    1995 SR5 V6 EXTENDED CAB
    2" Body Lift, 2.5" Fabtech in Front, 3" Alcan in Rear, Lockrite in Rear, 33" BFG K2 Mudders, Sliders
    Just drive it like you stole it!!! GPS works too though. I have pretty much memorized the speed difference so I don't use it anymore. with 33's: 67 is actually about 75; and the difference gradually goes down from there.
  15. Apr 9, 2010 at 5:32 AM
    AlexanderD
    Alex
    whitby Ontario
    well say you have 35" tires and your odometer says 5000 miles you have actually gone 5857 miles. thats a big difference! not to mention the extra wear on your engine from trying to turn the big ass tires.
    might not make that much of a difference but...
  16. Apr 12, 2010 at 9:46 AM
    Coolidge
    So Cal, Ca
    2003 Pre Runner
    M'kay...
    I usually change oil @ 'around' 3K anyway
  17. Apr 12, 2010 at 3:49 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2018 WRX
    at 65 mph on the ODO my GPS reads 59mph
    30" tires
  18. Apr 12, 2010 at 8:26 PM
    AlexanderD
    Alex
    whitby Ontario
    Now that is kind of odd. Should be the other way around I think. Have you done any other gearing changes?
  19. Apr 12, 2010 at 9:35 PM
    mattleegee
    Tacoma, WA
    2018 WRX
    dunno just bought the truck
    we have a wired speedo cable right?
    cant we just get a built speed sensor for our gears/tire size?
  20. Apr 12, 2010 at 9:40 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    take the needle off, make sure its set at zero, put the needle back on to compensate for the MPH. worked for me
