Mileage, Scan Gauge
Discussion in 'Technical Chat' started by mcgiiver, Aug 11, 2009.
  1. Aug 11, 2009 at 7:10 AM
    mcgiiver
    mcgiiver [OP] Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    Some people say they shift to neutral and coast to save on gas. On the '09 4 cyl's, wouldn't it be better to coast in gear, becasue when in gear, above 1000 rpm, and clutch up, the fuel flow to the engine is completely shut off as I understand the system. If coasting in neutral, fuel is still flowing to keep the engine idling.
    Maybe someone with more tech knowledge than me can shed some light on this.
    Maybe someone with a Scan Guage can check it out assuming a Scan Gauge measures instantaneous fuel flow, which I am not sure.
  2. Aug 11, 2009 at 7:12 AM
    Brunes
    Brunes abides.
    Rotorhead
    Coasting in neutral is illegal in many places...I don't know the benefits of gas savings from doing it...but it does put you in danger of not being able to control your car completely should the need arise.
  3. Aug 11, 2009 at 7:17 AM
    mcgiiver
    Princeton, NJ
    , but that wasn't the question.
  4. Aug 11, 2009 at 7:21 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    think about it...if fuel was compleatly shut off...so is your engine
  5. Aug 11, 2009 at 7:23 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    X1:cool:
  6. Aug 11, 2009 at 7:35 AM
    lasllc
    lasllc Well-Known Member
    SW Denver Burb
    13 SuperWhite DCSB Sport 4X4 Tow Pack
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    Scangage wont help much on this as it displays TPS as "number", might be throttle pecent open or might not be, it is simply a referance based on the trucks computer signal representing throttle opening and is set up out of the box at 22 or so I think; consequently , your IMG with foot off the throttle and coasting displays what Scangage is calculating based on the TPS you have set up (or not) not, necessairly, what the engine is actually doing; the default setting is good for most cars (it says) but it has no idea what the Tacoma, specifically, is doing.
    I know, I know, commen sense says that if you are coasting and the Scangage says 99.99 MPG the throttle is probably shut, but you can not assume that as it is a computer and we dont have access to the code. You dont know how Scangage is interprating the cars computer to calculate that 99.9 mpg - exactly when does toacoma completely shut the throttle body down? who knows ? Smog control comes into play here also.
    For example, when I installed mine i set the TPS cut off at 17 so that my AMG would incorporate the distance travelled while coasting, on the assumption that the throttle is still open a bit for the smog system to flush out the vapors etc and do whtever job it needs to do while coasting down. my Scangage does not display an IMG of 85 or more untill I am below approx 5 MPH.
  7. Aug 11, 2009 at 7:36 AM
    Brunes
    Brunes abides.
    Rotorhead
    IMO it does answer the question- I think what the fuel does doesn't matter...I want to be safe and in control of my truck...so I'll leave it in gear...no matter what a scanguage finds out.
    This makes sense
  8. Aug 11, 2009 at 8:07 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    I don't coast down every hill I come too, but when the right opportunity presents itself, yeah I will do it.
    Going down a hill and in gear my scangage will show somewhere around 60 MPG and as soon as I pop it out of gear it will jump up to around 80 or better.
  9. Aug 11, 2009 at 9:38 AM
    mcgiiver
    Princeton, NJ
    Thank you, this helps answer my question. My question had nothing to do with safety of coasting in neutral. I never even said I coast in neutral.
  10. Aug 11, 2009 at 3:49 PM
    spasur
    spasur Well-Known Member
    New Orleans
    02 PreRunner 4cyl
    not necessarily...assuming you are still in gear and all parts of your truck function normally as they should, the energy stored by your truck moving would keep the engine rotating as long as the engine speed is above idle. You can test this (I am not telling you to do this) in theory by driving down an empty road or a parking lot in 2nd or 3rd and shut off your engine...it will keep spinning, and you may need to change your shorts depending on the situation...I found this out by accidentally bumping the key with my knee once. It was not a tacoma.
    However, I have no idea if the ECM cuts fuel entirely when coasting, I would assume it keeps sending some fuel to keep the engine running smooth and in case you push in the clutch or apply the throttle. That little bit of fuel might be enough to give you the change in mpg that Snipe reported and therefore would be greater than the fuel needed to idle.
  11. Aug 11, 2009 at 3:54 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You're splitten hairs.....
    Should've bought a hybrid if you were that concerned about gas.
  12. Aug 11, 2009 at 5:02 PM
    mcgiiver
    Princeton, NJ
    The ECM can cut off the fuel entirely, but I am not sure it does. On my 1997 2.4 engine, in deceleration, in gear,the ECM would cut off the fuel entirely unless certain things happened like depressing the clutch (that's why there is a clutch switch), engine rpms drop below 1000 (ECM thinks the engine wants to idle or you put your foot back on the gas pedal. You cannot even tell the fuel is cut off, because your in gear the engine doesn't stall, but it needs no fuel whatsoever to continue to turn. As said the energy in the moving truck keeps it spinning.
    I suspect Snipe is correct in his observation that coasting in gear uses more fuel than coasting in neutral for the reason that the manufacturer wants the exhaust slightly rich during decel for emissions reasons.
    In either case we are talking miniscule amounts of fuel compared to that used in driving mode.
  13. Aug 11, 2009 at 5:31 PM
    williegator
    williegator Well-Known Member
    atlantic beach florida
    trd sport 4x4
    toytec Ultimate kit set @ 3 inches, Light Racing UCA's, HELO HE791 17X8 WHEELS, BFG 285-70-17's, secondary air filter removed, ARI drop in filter, Scan Gauge, Roll N Lock
    My scan gauge goes to 9999 MPG when coasting to a stoplight. Maybbe it's a 2009 4.0 thing. I did read either on here or another site that this is exaclty what the engine is doing, shut down the injectors....Oh and the GPH goes to 0.0 at the same time.
  14. Aug 11, 2009 at 6:03 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
  15. Aug 11, 2009 at 6:13 PM
    HBMurphy
    Paul
    So California Coast
    None
  16. Dec 11, 2009 at 7:39 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Above approximatly 1000 rpms, when you let off the throttle, a number of things happen. One of those things is the fuel is cut. The fuel injectors stop cyling, and do not inject fuel. On the auto V6, it's almost instant. On the 4 cyl manual, it takes a second or two. So the short answer is leave it in gear......To idle the engine in neutral consumes more fuel, (in this case). And it is idling, no mater how fast the vehicle is moving.....
