Mileage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fxrman, Jun 6, 2019.
  1. Jun 6, 2019 at 10:34 AM
    fxrman
    fxrman [OP] Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    So since this TRDORDC was new in 2016 I average 16 mpg. After OVTUNE I average 17 and as the factory Goodyear’s wore down I could get 18 on tank average. About 5000 mi. Ago I put on Falken wildpeak at3 265/75/16 tires and expected a mileage drop and it went down to 15 to 16 mpg tank average. But now it’s down to 14...
    I have 43,000 on the truck and keep up on service.
    First I checked the air cleaner for fowling but looks really clean so not sure why I’m experiencing even more loss. The air pressure is the same, my driving habits are the same and I travel the the same route daily...
    Any thought..?
    Thanks in advance.
  2. Jun 6, 2019 at 10:37 AM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    fxrman[OP] likes this.
  3. Jun 6, 2019 at 10:40 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    I'm surprised you've been getting such low MPG in general even with stock tires. I drive uphill both ways from work to home everyday and still get 21-23mpg sometimes on stock tires.
  4. Jun 6, 2019 at 10:41 AM
    Shellshock
    Iowa
    Did you put E or SL load range tires?
    Kyitty likes this.
  5. Jun 6, 2019 at 10:43 AM
    fxrman
    palm springs
    Sl load tires.
  6. Jun 6, 2019 at 10:44 AM
    fxrman
    palm springs
    I expected a mileage drop but not to 14.
    I can live with 16 to 18.
    For reference I’m on OVTune 1.03 91oct.
  7. Jun 6, 2019 at 10:45 AM
    fxrman
    palm springs
    Both ways to and from work...?
  8. Jun 6, 2019 at 10:51 AM
    LivinOnEdge
    Land of The Lost
    Yes, I drive up a up and over a mountain and the bottom where I work. I must then drive back up and down said mountain to go home.
  9. Jun 6, 2019 at 10:53 AM
    Shellshock
    Iowa
    You should update to 1.05. A LOT has changed since 1.03
  10. Jun 6, 2019 at 10:53 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    I logged my miles and divided the gallons for over a year and in mixed driving conditions my overall average is 19 mpg.
    That’s with the oem tires and under the 2yr Toyota care servicing.
    The computer would pretty consistently report higher tank averages than doing the math.
    Trying to get good mpg is tough, it’s a combo of driving habits, traffic conditions, idling time and good maintenance.
  11. Jun 6, 2019 at 10:55 AM
    tlp.wc
    tlp.wc WC Member
    California
    2018 DCLB SR5 SW
    Strange, I average 20-21 mpg on 87 octane, 285/60/18 BGF Ko2s D-rated tires, and in mixed driving situations. How fast are you going on the freeway? Anything over 65 mph+ will take a toll on mpg.
  12. Jun 6, 2019 at 11:02 AM
    fxrman
    palm springs
    Usually only 70 which is the posted limit but sometimes faster. The thing is I haven’t changed anything but the tires and knew I’d get some drop but after settling in on the the new norm it dropped another 1 mpg.
    Just seems awfully low.
    Going to try 1.05 soon.
  13. Jun 6, 2019 at 11:24 AM
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    I think my display stops at 19
  14. Jun 6, 2019 at 11:43 AM
    dirtyhesher603
    dirtyhesher603 Well-Known Member
    zack
    southern nh
    2018 cement grey tacoma TRD OR ACCESS CAB
    ST MAXX 255/85-16
    that's odd...I just switched from stock tires to 255/85-16 10 plys on my 18 and dropped from low 20s to about 19 (on the display)
  15. Jun 6, 2019 at 11:46 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    My first thought would be to get the birds out of the air cleaner! Then, do a plug change and MAF cleaning and see where that gets you.
    fxrman[QUOTED][OP] likes this.
  16. Jun 6, 2019 at 11:56 AM
    fxrman
    palm springs
    Not sure I need plugs yet but it’s possible.
    Thought about the MAF sensor though.
    Air cleaner checks out clean.
  17. Jun 6, 2019 at 12:00 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    So larger contact patch and heavier tires had no effect on your mpg, sounds impossible besides defying the laws of physics.
    Your taller tires throw off the odometer. I’m not sure if that can be altered in the computer at all.
    JNG likes this.
  18. Jun 6, 2019 at 12:03 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    There are only a few things that would have a mild negative affect on an otherwise healthy engine and not throw any codes: plugs, MAF, ECU, 02 sensors. I would agree that you should not need plugs or, certainly, 02 sensors. You might try and reset the ECU and see if that changes anything (force it to relearn).
    BassAckwards and fxrman[OP] like this.
  19. Jun 6, 2019 at 12:03 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have standard load Wildpeaks on my truck, last tankfull was 21.8 MPGs
  20. Jun 6, 2019 at 12:04 PM
    Brucey
    Brucey Well-Known Member
    Bruce
    2018 DC LB SPORT 4X4
    Ovtuned
    What is the air pressure in your tires? When i had 28 psi in my stock tire 19 mpg but when i up to 40 psi. I get about 21 mpg now.
    Dont know about your tires but i believe 50 psi cold is your max. You should be around 40 psi for normal driving.
