Miles After Gas Light Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoman101, Nov 2, 2009.
  1. Nov 2, 2009 at 4:26 AM
    tacoman101
    tacoman101 [OP] Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    Usually, I drive my truck until the gas light comes on, and then proceed to fill it up. I'm just wandering with a 2001 Tacoma XtraCab with the 2.7 4 cylinder engine, w/4wd how long I can go with the gas light on?
  2. Nov 2, 2009 at 4:30 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    im pretty sure the low fuel light kicks on with 3 gallons left. so whatever your avg mpg has been, times that by 3 and that's roughly how many more miles you have to go.
    or you can just drive till the engine stops, then you will know how many miles you can get :p
  3. Nov 2, 2009 at 6:06 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    hahah fuel lights... I dont even have one of those.
    Wulf likes this.
  4. Nov 2, 2009 at 9:24 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    I would say never let the light come on.
    Some fuel stations are less then good when it comes to filtering the fuel from OLD tanks. So you can get sediment and other stuff building up in your gas tank..
    Once you get low that stuff can get into your system and clog the filter or worse..
    Try and fill up at the half way point for long life on the fuel filter and other parts...
    1997tacomav6 likes this.
  5. Nov 2, 2009 at 9:26 AM
    slickyd
    slickyd Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    isnt the opening of the fuel system at the bottom of the tank and wouldn't the dirt and crap go to the bottom of the tank?
    Thatbassguy likes this.
  6. Nov 2, 2009 at 9:28 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I can get about 50 miles when the light comes on.
    Boco10 likes this.
  7. Nov 2, 2009 at 10:41 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    haha X2. ;)
  8. Nov 2, 2009 at 11:47 AM
    RattleTractor
    Harry
    VT
    do you like to gamble and see how far below the E line you can make it?
    ive made it to .3 gallons left.
  9. Nov 2, 2009 at 11:49 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Agreed. The other thing is keeping your fuel pump cool. I try not to get it below a 1/4 tank. You can suck up all sorts of crap from the tank. Not a good idea.
  10. Nov 2, 2009 at 11:52 AM
    jab08
    jab08 Well-Known Member
    Alabama
    02 T4R 4wd
    Gas light?? What gas light??? My "gas light" is when the needle goes past the E mark, then its time to get some gas!!!!:D
  11. Nov 2, 2009 at 12:02 PM
    PrezidentRedz
    Redz
    Owings, MD
    not by much normaly have about 1.5gal left. but I also have a scan gauge.
  12. Nov 2, 2009 at 12:08 PM
    Foster9091
    Foster9091 Well-Known Member
    Upperco, MD
    01 Doublecab TRD
    deckplate mod, floor mats, hi lift, scanquage, and 2 in front leveling kit
    those lights dont mean anything u can drive forever:thumbsup:
    Stryker420 likes this.
  13. Nov 2, 2009 at 2:22 PM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    I try not to let it go below 1/2 tank, never below 1/4. For sedament reasons said above, and now with the cold setting in, water/condensation building up on the inner empty parts of the tank. So the les gas in your tank, the more water will build up and settle at the bottom and get sucked up when you try to get that light to go on.
    Abeyancer likes this.
  14. Nov 9, 2009 at 8:56 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    ...and you only have to change the oil if/when the oil light comes on too, right?...
    i dont trust my fuel gauge, i can go 120 miles on the first 1/4 tank and only 60 on the second quarter. i base my next stop for gas on the miles ive gone since the last stop not on what the gauge is telling me. i dont think ive ever seen the low fuel light on before.
    GQ7227 likes this.
  15. Nov 9, 2009 at 9:20 PM
    Nicky Lam
    Nicky Lam Dog Face Soldier
    Nick
    Somers Point/Mount Laurel, NJ
    2013 Blk DC Off Road
    NOV12: Front windows tinted to matched to rear windows 12NOV12: Fog light anytime mod DEC12: OME 885 w/ 25912 top plate spacers for full 3" lift OME Trim packer Dakar Rear 5 Leaf Packs Total Chaos Uniball Upper Control Arms 2.5° Degree Rear Axle Shims 18JAN13: 17x9 Fuel Kranks 17x9 4.5 BS -12mm Offset 285-70-17 Goodyear Duratracs 23JAN13: OME Carrier Bearing Drop Kit 05FEB13 TRD Aluminum Skid Plate 05FEB13 TRD Stainless Steel Cat Back Exhaust (2012 modified to fit 2013) Auto Mate 5304A (Viper 5704 Equivalent) 2-Way Alarm/Remote Start with Smart Start for iPhone De-Badged All Emblems 30JUL13 Go Rhino Stainless Steel Dominator II Side Steps *not yet installed: Stainless Steel Extended Rear Brake Lines
    lol
  16. Nov 10, 2009 at 6:42 AM
    apex9r
    apex9r mountain rover
    '97 4x4 2.7 5spd
    starting from scratch
    x2:rolleyes:
  17. Sep 8, 2019 at 4:38 PM
    busy_ g
    busy_ g New Member
    2008 Silver TRD Off Road
    BFG T/A KO2s
    20190906_122650.jpg I ran out of gas 1st time in my 2nd Gen 2008 2.4L six cylinder. The trip odometer I set to zero when light came on (as I read another Tacoma owner do also), had around 40 miles on that trip odometer. The used car dealer I bought my truck from, who specializes in Tacomas and Tundras, I thought told me 100 miles when light comes on, but that doesn't make sense. Yet, that was my MO on Friday when I ran out of gas, that I had another sixty miles available.
    GQ7227 likes this.
  18. Sep 8, 2019 at 4:47 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    your truck was in diapers almost the last time this thread was updated ten years ago lol
  19. Sep 8, 2019 at 4:59 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    This has been proven false by me.
    I NEVER get gas until the light is on, and usually push it another 10-20 miles before filling up. My 2003 4runner was still on the original fuel pump and filter at 257K miles. It ran perfectly when I traded it in.
    GQ7227 likes this.
  20. Sep 8, 2019 at 5:00 PM
    Thatbassguy
    James
    Haha! I didn't notice that either.
    GQ7227[QUOTED] likes this.
